6 Replies Latest reply: May 3, 2012 7:35 PM by Pete.Green RSS
    Crash while transforming Shape Layers in group <bug report>
    Jeff Holter Community Member
      I've had a consistent crash today while trying to scale a group of simple shape layers: specifically, 2 x 2px strokes making a simple bevelled edge, contained in a layer group folder.
      What happens:
      1. have two vector shape layers in a layer group
      2. Select and try to scale vertically
      3. Set height to 4 pixels
      4. Crash.
      What should happen?
      Those simple shape layers should scale with no trouble at all. For some reason it causes PS to crash every time.
      I can do a free transform to any vector object or shape layer and scale with no problem. If I set a height or width in the tool bar it will crash.
      The vector objects do not have any effects, styles or even strokes. They are just simple filled vector shapes approximately 2 px H X 20 px W.
      Processor  2 x 2.4 GHz Quad-Core Intel Xeon
      Memory  24 GB 1066 MHz DDR3 ECC
      Graphics  ATI Radeon HD 5870 1024 MB
      Software  Mac OS X Lion 10.7.3 (11D2001)
        • 1. Re: Crash while transforming Shape Layers in group <bug report>
          Pete.Green Adobe Employee
          I'm unable to reproduce the crash on my end using the steps detailed here in the report.
          Can you record the crash using a screen capture application like Jing and show it to us?
          http://www.techsmith.com/jing.html
          Pete
          • 2. Re: Crash while transforming Shape Layers in group <bug report>
            Sorry it took so long... busy busy busy work day!
            I captured a video clip of the bug in action. Here's a link to screencast: http://bit.ly/JfX4p0
            It's nearly consistent. If I transform the shape layers by putting a value in the width field, it will occasionally work. If I transform vertically by adding a value to the height field, it will crash instantly.
            I'm not sure how much good the video will do but at least you can see it in action.
            • 3. Re: Crash while transforming Shape Layers in group <bug report>
              Thanks for the Video Jeff. It's helpful to see what's happening. I'm still unable to reproduce on my machine.
              Sidenote: Whoa -- the music was blaaaastin -- Getting your daily metal fix, I see hear.
              Back to the issue:
              Can you reproduce this with a new document?
              I've been creating 2 shape layers 1 pixel'ish each, and grouping them, then free transforming using Height as you are there.
              Works for me both with width, and heigth.
              I see the crashes happening on your end though, and is curious.
              Can you post your system info from Photoshop's Help > System Info dialog?
              Is your video card driver up to date with the latest?
              • 4. Re: Crash while transforming Shape Layers in group <bug report>
                Hi Pete -
                I apologize for the soundtrack... it was my first time using Jing and I was trying to capture the bug while I was trying to get two jobs out the door!
                That was Ministry, btw. I find it relaxing and soothing.
                All my hardware, software, graphics cards and drivers are up to date. My machine (the one I'm working on currently) is a new Mac Pro (all the specs are pasted at the end of this post). The issue also appeared on my old Mac Pro Quad Core, 2 x 2.66 GHz.
                I've had the issue happen in multiple documents, both existing and new. For awhile it only happened when changing the height. Then it happened a few times when adding a specified width. It hasn't happened at when transforming manually by dragging, only when entering a value to the height or width fields.
                After I sent the video last night I was able to transform again using the same group of shape layers, in the same document, and it worked consistently several times. At the time I wasn't trying to reproduce the bug, I was just working, but when it worked I had to try it a few times to see what would happen and it worked.
                Today I remembered one setting that I changed and checked it out. In prefs, one of the new options, "Snap Vector Tools and Transforms to Pixel Grid", was originally checked/on. A couple days ago I had to turn it off while setting up some UI graphics for an iOS app. I found this setting really useful for doing UI design since most of the graphics in an app, especially icons and the like, have to be very precise or things begin to appear fuzzy. However, transforming a vector object that's only 36 x 36 px tends to really jump around a lot when dragging to transform, so for the comp stage I turn it off. Last night I had to whip out some rough layouts really quick and turned it off. That's when I noticed it stopped but didn't realize it until today. As it was happening, so were all the crashes and restarts so it was difficult to keep track.
                I think if you take a look at that new setting option you'll find the root of the problem.
                Let me know if you can reproduce the bug with that setting on.
                Here's my system info:
                Adobe Photoshop Version: 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00) x64
                Operating System: Mac OS 10.7.3
                System architecture: Intel CPU Family:6, Model:44, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
                Physical processor count: 8
                Logical processor count: 16
                Processor speed: 2400 MHz
                Built-in memory: 24576 MB
                Free memory: 14531 MB
                Memory available to Photoshop: 23183 MB
                Memory used by Photoshop: 68 %
                Image tile size: 1028K
                Image cache levels: 6
                OpenGL Drawing: Enabled.
                OpenGL Drawing Mode: Normal
                OpenGL Allow Normal Mode: True.
                OpenGL Allow Advanced Mode: True.
                OpenGL Allow Old GPUs: Not Detected.
                OpenGL Version: 2.1 ATI-7.18.11
                OpenCL Version:
                Video Card Vendor: ATI Technologies Inc.
                Video Card Renderer: ATI Radeon HD 5870 OpenGL Engine
                Display: 3
                Display Depth:= 32
                Display Bounds:=  top: 180, left: 2560, bottom: 1260, right: 4480
                Video Renderer ID: 16915201
                Video Card Memory: 991 MB
                Video Rect Texture Size: 16384
                OpenCL Version:
                Display: 2
                Display Depth:= 32
                Display Bounds:=  top: 113, left: -1920, bottom: 1193, right: 0
                OpenCL Version: 1.1 (Dec  4 2011 16:53:18)
                Display: 1
                Main Display
                Display Depth:= 32
                Display Bounds:=  top: 0, left: 0, bottom: 1440, right: 2560
                Serial number: Tryout Version
                Application folder: BearOSX:Applications:Adobe Photoshop CS6:
                Photoshop scratch has async I/O enabled
                Scratch volume(s):
                  640, 595.9G, 120.8G free
                  ArchiveDrive, 465.4G, 204.1G free
                  BearOSX_backup, 232.0G, 165.6G free
                  Media, 463.7G, 164.8G free
                  BearFiles Backup, 935.7G, 448.1G free
                  Media Backup, 460.7G, 460.3G free
                  SpeedOne, 118.6G, 112.2G free
                Required Plug-ins folder: BearOSX:Applications:Adobe Photoshop CS6:Adobe Photoshop CS6.app:Contents:Required:
                Primary Plug-ins folder: BearOSX:Applications:Adobe Photoshop CS6:Plug-ins:
                Additional Plug-ins folder: not set
                Installed components:
                   adbeape.framework   adbeape   3.3.8.19346   66.1025012
                   AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.2.29.18602   66.490082
                   adobe_caps.framework   adobe_caps   5.0.11.0   1.256674
                   AdobeACE.framework   AdobeACE   2.19.18.19243   66.492997
                   AdobeAGM.framework   AdobeAGM   4.26.17.19243   66.492997
                   AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
                   AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
                   AdobeBIB.framework   AdobeBIB   1.2.02.19243   66.492997
                   AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   66.492997
                   AdobeCoolType.framework   AdobeCoolType   5.10.31.19243   66.492997
                   AdobeCrashReporter.framework   AdobeCrashReporter   6.0.20120201
                   AdobeExtendScript.framework   AdobeExtendScript   4.2.12.18602   66.490082
                   AdobeJP2K.framework   AdobeJP2K   2.0.0.18562   66.236923
                   AdobeLinguistic.framework      17206
                   AdobeMPS.framework   AdobeMPS   5.8.0.19463   66.495174
                   AdobeOwl.framework   AdobeOwl   4.0.93   66.496052
                   AdobePDFL.framework   AdobePDFL   10.0.1.18562   66.419471
                   AdobePDFSettings.framework   AdobePDFSettings   1.4
                   AdobePIP.framework   AdobePIP   6.0.0.1642
                   AdobeScCore.framework   AdobeScCore   4.2.12.18602   66.490082
                   AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
                   AdobeXMP.framework   AdobeXMPCore   66.145661   66.145661
                   AdobeXMPFiles.framework   AdobeXMPFiles   66.145661   66.145661
                   AdobeXMPScript.framework   AdobeXMPScript   66.145661   66.145661
                   ahclient.framework   ahclient   1.7.0.56
                   aif_core.framework   AdobeAIF   3.0.00   62.490293
                   aif_ocl.framework   AdobeAIF   3.0.00   62.490293
                   aif_ogl.framework   AdobeAIF   3.0.00   62.490293
                   AlignmentLib.framework   xcode   1.0.0.1
                   amtlib.framework   amtlib   6.0.0.75
                   boost_date_time.framework   boost_date_time   6.0.0.0
                   boost_signals.framework   boost_signals   6.0.0.0
                   boost_system.framework   boost_system   6.0.0.0
                   boost_threads.framework   boost_threads   6.0.0.0
                   Cg.framework   NVIDIA Cg
                   CIT.framework   CIT   2.0.5.19287   145486
                   data_flow.framework   AdobeAIF   3.0.00   62.490293
                   dvaaudiodevice.framework   dvaaudiodevice   6.0.0.0
                   dvacore.framework   dvacore   6.0.0.0
                   dvamarshal.framework   dvamarshal   6.0.0.0
                   dvamediatypes.framework   dvamediatypes   6.0.0.0
                   dvaplayer.framework   dvaplayer   6.0.0.0
                   dvatransport.framework   dvatransport   6.0.0.0
                   dvaunittesting.framework   dvaunittesting   6.0.0.0
                   dynamiclink.framework   dynamiclink   6.0.0.0
                   FileInfo.framework   FileInfo   66.145433   66.145433
                   filter_graph.framework   AdobeAIF   3.0.00   62.490293
                   hydra_filters.framework   AdobeAIF   3.0.00   62.490293
                   ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
                   ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
                   image_compiler.framework   AdobeAIF   3.0.00   62.490293
                   image_flow.framework   AdobeAIF   3.0.00   62.490293
                   image_runtime.framework   AdobeAIF   3.0.00   62.490293
                   LogSession.framework   LogSession   2.1.2.1640
                   mediacoreif.framework   mediacoreif   6.0.0.0
                   PlugPlug.framework   PlugPlug   3.0.0.383
                   UpdaterNotifications.framework   UpdaterNotifications   6.0.0.24   "6.0.0.24"
                   wrservices.framework
                Required plug-ins:
                   3D Studio 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
                   ADM 3.10x16, Copyright © 1987-2008 Adobe Systems Inc.  All rights reserved. - from the file “AdobeADM.bundle”
                   Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Average 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Average.plugin”
                   Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Camera Raw 7.0 (308), Copyright © 2012 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                   Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Cineon 13.0 20120305.m.415 2012/03/05:21:00:00  ©2002-2012 Adobe Systems Incorporated - from the file “Cineon.plugin”
                   Clouds 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
                   Collada DAE 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Crop and Straighten Photos 13.0 20120305.m.415 2012/03/05:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
                   Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Dicom 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “dicom.plugin”
                   Difference Clouds 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
                   Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Eazel Acquire 13.0 20120305.m.415 2012/03/05:21:00:00  ©1997-2012 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
                   Embed Watermark NO VERSION - from the file “DigiSign.plugin”
                   Enable Async I/O 13.0 20120305.m.415 2012/03/05:21:00:00  © 2004-2012 Adobe Systems Incorporated - from the file “Enable Async IO.plugin”
                   Entropy 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   FastCore Routines 13.0 20120305.m.415 2012/03/05:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “FastCore.plugin”
                   Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Flash 3D 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Google Earth 4 KMZ 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
                   IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   JPEG 2000 13.0 20120305.m.415 2012/03/05:21:00:00  ©2001-2012 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
                   Kurtosis 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
                   Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
                   Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
                   Matlab Operation 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                   Maximum 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Mean 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Measurement Core 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
                   Median 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Minimum 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
                   MMXCore Routines 13.0 20120305.m.415 2012/03/05:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MMXCore.plugin”
                   Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Multiprocessor Support 13.0 20120305.m.415 2012/03/05:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
                   Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   NTSC Colors 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
                   Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
                   OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   PCX 13.0 20120305.m.415 2012/03/05:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PCX.plugin”
                   Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Photoshop 3D Engine 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
                   Picture Package Filter 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                   Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Pixar 13.0 20120305.m.415 2012/03/05:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “Pixar.plugin”
                   Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Portable Bit Map 13.0 20120305.m.415 2012/03/05:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PBM.plugin”
                   Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Radiance 13.0 20120305.m.415 2012/03/05:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “Radiance.plugin”
                   Range 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Read Watermark NO VERSION - from the file “DigiRead.plugin”
                   Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
                   ScriptingSupport 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
                   Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Skewness 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Solarize 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Solarize.plugin”
                   Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Standard Deviation 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Summation 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   U3D 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
                   Variance 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Wavefront|OBJ 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Wind 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Wireless Bitmap 13.0 20120305.m.415 2012/03/05:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “WBMP.plugin”
                   ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                Optional and third party plug-ins: NONE
                Plug-ins that failed to load: NONE
                Flash:
                   Mini Bridge
                   Kuler
                Installed TWAIN devices: NONE
                • 5. Re: Crash while transforming Shape Layers in group <bug report>
                  Chris Cox Adobe Employee
                  I prefer a softer style: Motorhead or TMBG randomness.
                  • 6. Re: Crash while transforming Shape Layers in group <bug report>
                    After a few more repeated attempts, it's crashing for me too
                    Nice find. Thanks for letting us know about it!
