13 Replies Latest reply on Apr 15, 2015 9:23 AM by LightCapturedByDamian
    Export and File Size Limit Problem
    Joerg.Lang
      Hi there,
      im currently using LR 4.0 and found a problem with file export, I dont understand.
      I have two tiff files:
      Tiff 1: 283MB, full resolution ( 2336 x 3504 )
      Tiff 2: 233MB, full resolution ( 2336 x 3504 )
      Export witht: 574 x 1000 image width
      JPG 1: 168kb
      JPG 2: 194kb
      Both jpegs have 600px x 887px (fram with mogrify plugin#) and 100%jpg quality.
      Whe I set a limit to file size of 154kb, I receive following:
      JPG 1: 102kb
      JPG 2: with error ( couldn't create jpg which fit's the file size limit of 154kb )
      But why?
      If I export the second tiff manually with 90% jpg quality and no filesize, I get:
      JPG 1: 114kb
      JPG 2: 135kb
      So it seems that the "limit file size" isn't really working.
      Anyone have seen this?
      Also it seems that Valus between 92 and 100 ends in: same as 100.
      Why?
      Jörg
        • 1. Re: Export and File Size Limit Problem
          dj_paige Level 9
          Why? Since the programmer at Adobe probably isn't going to pop in here and explain, we will probably never know.
          Quality levels between 92 and 100 probably are the same. There really aren't 101 different quality levels, there are probably only 13 distinct quality levels.
          • 2. Re: Export and File Size Limit Problem
            Joerg.Lang Level 1
            then no one need the option for setting the leven in so granulate values.
            how ever, the current algorythem seems not to work anyway, as I can proof that if the value auf quality is set to 90, 91 or 92, the jpg-size will be below 154kb, so it's possible to do it.
            • 3. Re: Export and File Size Limit Problem
              areohbee Level 6
              I had major problems using file-size limiter when I tried it (a good while ago, probably Lr3)
              Inexplicable results, and worse - inexplicable errors.
              Perhaps some people have had better experiences with it?
              Rob
              • 4. Re: Export and File Size Limit Problem
                Joerg.Lang Level 1
                If the current behavior  is "working as expected" then it's completly useless.
                I will create a bug for this.
                • 5. Re: Export and File Size Limit Problem
                  -Agfaclack- Level 3
                  that´s old news.
                  http://regex.info/blog/lightroom-goodies/jpeg-quality
                  Conclusions
                  First of all, you can't directly compare Lightroom's JPEG quality settings with any other application. The settings may well map directly to Photoshop's save-as-JPEG 0〜12scale, and they may well partially map to Photoshop's “Save for the Web” settings, but all bets are off when it comes to the JPEG quality setting on non-Adobe applications. They're just totally unrelated to how Adobe does it. (I should make it clear that the difference is neither good nor bad; I've presented nothing here about how any other application creates JPEGs, so there are no conclusions to draw about which might be better or worse than Lightroom; the important point is to recognize that the scales, even if sharing the same “0〜100”labels, are absolutely completely unrelated.)
                  The Lightroom default JPEG export quality of 75, falling in the 70〜76range, seems to provide for as good a visible result as the highest quality setting for all the samples except for the bridge, which seems to suffer at least slight posterization banding at all levels, including even“lossless TIFF”. The file size, even at this relatively high 70〜76setting, is still about one third that of the 93〜100setting, so is well worth it in most situations. Those who blindly use the maximum setting for their exports likely waste a lot of local disk space, upload bandwidth, and remote storage space. But conversely, those who blindly use some lesser setting risk posterization in the occasional photo with an unlucky sky gradient.
                  • 6. Re: Export and File Size Limit Problem
                    Joerg.Lang Level 1
                    I have read this... so it clear why 93-100 are compltelty identical.
                    However, des "limit to size" isn't working
                    • 7. Re: Export and File Size Limit Problem
                      -Agfaclack- Level 3
                      yep possible you encountered a bug with the 100% setting.
                      • 8. Re: Export and File Size Limit Problem
                        Joerg.Lang Level 1
                        if the feature "size limit" is aktivated, the quality slider is getting disabled.
                        I have created a request at supput to check this out.
                        workarround could be to stay for 92 on export an hopeing that alle images will be exported to the size I need.
                        • 9. Re: Export and File Size Limit Problem
                          Swizzy Level 1
                          Agreed that the file size limitation in both LR3 and LR4 simply does not work, giving significantly lower file sizes than what is input within the export dialogue box. Use the save for web command within PS if you need to limit file size.
                          • 10. Re: Export and File Size Limit Problem
                            Joerg.Lang Level 1
                            Hey Stephen,
                            sorry but
                            stephen zimic,
                            is absolutley no option.
                            I'm using often virtual copys and generating everytime a tiff/psd (and deleting it), just for exporting to the needed file size is absolutely no option.
                            Especially when a number of images has to be exported.
                            • 11. Re: Export and File Size Limit Problem
                              Hey all,
                              I have a similar problem. I am with the latest version of Lightroom for the moment, version 5.7.1. That's the one coming with Photoshop CC as a bundle.
                              I am exporting files to a service that accepts only sizes up to 20MB. When I do not use the "Limit File Size to:" option and JPEG quality is set to 100, my file gets over 20 MB so I need to limit its size.
                              The problem is that once I put "20000" in the "Limit File Size to:" field, the exported file then becomes about 12 MB which is way below what I am asking for. Notice that again, as you've described above, the quality slider becomes disabled, which is logical since you're passing the quality control to the software.
                              So it seems this is a long standing issue?
                              Any workaround? I would rather not spend hours interpolating that number to get the size I want.
                              Any help is appreciated.
                              • 12. Re: Export and File Size Limit Problem
                                dj_paige Level 9
                                I don't think this is a bug nor is it a problem in my opinion.
                                JPG file sizes don't smoothly increase so that you can set the options to get exactly 10.3MB or 19.9MB or 20MB or whatever. They are limited to whatever the JPG algorithm will produce, which is probably discrete size increments, and for some photos, you probably can't expand the file size to exactly (or even approximately) 20MB. In fact, for some photos, 12MB, which you are getting, is probably the max you can get. In other words, starting from your photo in Lightroom, there IS NO WAY to obtain a 20MB JPG photo, not in Lightroom and not in any other software. If you want more detail, please read Jeffrey Friedl's Blog » An Analysis of Lightroom JPEG Export Quality Settings
                                Lastly, don't make the mistake that others have made to think that your 12MB JPG is somehow lower quality than a 20MB JPG. The megabytes of the photos do not indicate quality. They do not indicate quality. Oh, I said that twice redundantly. But I'll say it again, your 12MB photo is not somehow lower quality than if you could get a 20MB JPG from your original.
                                • 13. Re: Export and File Size Limit Problem
                                  LightCapturedByDamian Level 1
                                  Thanks, DJ, I came to the same conclusion few moments ago.
                                  I started decreasing the quality value. For the values of 100 to 93, it stays the same size, above 20MB. But once I changed the value to 92%, I saw the already familiar size of 12MB for that particular file. So this is what the software does behind the scenes as it seems.
                                  Generally, JPEG is a compression with loss of quality, so it is obvious that 100 > 92 and 20MB > 12MB even if the human eye can be fooled there is no difference, right?
                                  I have to tune up my workflow, i.e. export all files with max quality first, then check the export folder for files with size>20 MB and only re-export those with the 92% preset I created.
