5 Replies Latest reply: May 3, 2012 6:35 PM by zyhsu RSS
    javascript, text input
    zyhsu Community Member
      Dear sir:
      If I want to getTextString directly from keyboard input, not from textfield,
      Can I do that?
      thanks!
        • 1. Re: javascript, text input
          Ned Murphy ACP/MVP
          You would need to store the characters that are being typed into a String variable. So you need to capture which keys are being used and add the characters for them to the string.
          • 2. Re: javascript, text input
            sinious MVP
            Is this input inside Flash or just a standard HTML <input type="text" ..> situation?
            • 3. Re: javascript, text input
              Dear Ned:
              Thanks for your reply!
              So, It will not like we use "scanf" in  C ,  we can have the program hold, wait for our input,
              then tab return, the function will scan what we input and take it as variable?
              thanks!
              Ze-Yi
              • 4. Re: javascript, text input
                Ned Murphy ACP/MVP
                I cannot speak for what you do in C.  What you do in Actionscript depends on what version you are using, but for any version it boils down to having a listener assigned for keyboard input when you want keyboard input to be monitored.  In AS3 you would assign a listener for a KeyboardEvent and then have the event handler function determine which key was used and add it to the string.  Here is a very basic implementation to demonstrate (be sure to disable keyboard shortcuts in the player when you test it in Flash using Control -> Disable Keyboard Shortcuts).
                var str:String = "";
                stage.addEventListener(KeyboardEvent.KEY_UP, keyUsed);
                function keyUsed(evt:KeyboardEvent){
                     str += String.fromCharCode(evt.charCode);
                     trace(str);
                • 5. Re: javascript, text input
                  Dear Ned:
                  Thanks a lot! this exatly I am looking for!
                  Ze-Yi Hsu
