6 Replies Latest reply on May 5, 2012 6:53 AM by nnmk
    FMS updates 4.5.1 4.5.2
    nnmk
      is there a way to do the update without unistalling previous version and then installing the new version?
      Concretely, i'm asking this for versions 4.5.1 and 4.5.2.
      Thank you in advance.
        • 1. Re: FMS updates 4.5.1 4.5.2
          ShivenK Level 3
          Let me know what data you want to hold back and we can work that out.
          • 2. Re: FMS updates 4.5.1 4.5.2
            nnmk Level 1
            Well, all the applications and configuration files for FMS and apache.
            What i do usually with these updates is make a backup of what i need and then uninstall old, install new version, then copy the backuped files back.
            While this is working ok, i'm interested if there is another way of doing this - like really having an update rather than a completely new installation.
            • 3. Re: FMS updates 4.5.1 4.5.2
              ShivenK Level 3
              Hmmm. I'm afraid there isn't any way to just simply update.
              What best you can do is:
              Install the new FMS (say 4.5.2) in a different location and replace the binaries of the old installation with the new ones.
              Binaries to replace:
              FMSMaster.exe
              FMSCore.exe
              FMSEdge.exe
              FMSAdmin.exe
              1 person found this helpful
              • 4. Re: FMS updates 4.5.1 4.5.2
                nnmk Level 1
                I'll try that, thanks.
                If these exe files are the only updated files between versions - why not distribute the update that way - it should be fairly simple to pack an installation that does this....
                But ok, i'll try manually.
                • 5. Re: FMS updates 4.5.1 4.5.2
                  ShivenK Level 3
                  Hey,
                  This is certainly NOT the recommended way to update FMS though.
                  This way you will have the changes that have gone into FMS but you will miss out on the changes in other modules. And if you are using HDS, HLS (where FMS has hardly any role), i will recommened for you to follow standard procedure, which is to have a clean installation and then make use of backed up your apps and conf files.
                  Thank You!
                  • 6. Re: FMS updates 4.5.1 4.5.2
                    nnmk Level 1
                    ok ok, i get that.
                    I only wish there was a update system within fms...
                    Thank you.
