1. Re: Resource Manager and Images
Captiv8r May 2, 2012 5:40 AM (in response to MPizanti)Hi Morven
Why not try just saving the modified image and replacing the existing one without the delete and replace hokey pokey. Resource Manager should sense the change and update accordingly.
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7, 8 or 9 within the day!
2. Re: Resource Manager and Images
MPizanti May 6, 2012 3:35 AM (in response to Captiv8r)Hi Rick,
First of all thanks for the answer.
Your answer makes me suspect that I am doing things differently.
When you save the modified image and replace - are you doing this in RoboHelp or in Windows Explorer directly?
I think my current method is cumbersome because I am trying to do the replacement within RH itself.
Morven
3. Re: Resource Manager and Images
Captiv8r May 6, 2012 5:21 AM (in response to MPizanti)Hi Morven
In my own experience, it really shouldn't matter where you update the image, as the Resource Manager is a two way street. If you update in RoboHelp, it should be sensed and the updated image copied from your project to replace and update the centralized image. And likewise, if you update the centralized image, Resource Manager should update your project to match the updated centralized image.
Again, I woudn't want to first delete the image followed by saving a new one using the same name. I would either open one of them (centralized or project) and edit as needed. Or edit a copy, make edits, then save using the same file name so the existing image is replaced.
To the best of my knowledge, Resource Manager should sense the change as the date/time stamp should be different as well as possibly the size. Then the automation should kick in to update the image's counterpart and synchronize everything nicely. The only fly in this ointment would be if the new image were different in size from the pixel measurement standpoint. If the new image is wider or taller or narrower or shorter, you would need to ensure that you reset the sizes in your project so they match the new dimensions. Otherwise they will be a bit skewed and have the fun house effect. I believe RoboHelp supplies a script for this.
Cheers... Rick
