22 Replies Latest reply on May 8, 2012 4:48 AM by Jonathan Fortis
    displaying and echo in the body
    Jonathan Fortis Level 1
      i have the echo no results being displayed but when its run  it currently displays at the top of the page
      if(count($results) > 0){
               echo implode($results);
           else {
               echo "No results were found.";
      how do i show the No results were found. in the contents
      thanks in advance
        • 1. Re: displaying and echo in the body
          sudarshan.t Level 6
          Try this. Be sure to post the code where you want the result to be displayed
          $noresults = "No results were found!";
               else {
                   echo "<p>$noresults</p>";
          • 2. Re: displaying and echo in the body
            sudarshan.t Level 6
            This is because currently, I guess you're echoeing from within the PHP function code that you have all the way in the beginning of your code. This considers that the echo is a part of the function - hence it displays at the top of the page
            • 3. Re: displaying and echo in the body
              ok great....see what you done and it works thanks for your help
              • 4. Re: displaying and echo in the body
                sudarshan.t Level 6
                You're welcome
                • 5. Re: displaying and echo in the body
                  i still have a problem with the
                          <?php
                       else {
                  it is showing even if there are results. i think i have to put it somewhere else in the code?
                  • 6. Re: displaying and echo in the body
                    sudarshan.t Level 6
                    Are you using an if else condition? If you don't PHP will display this even if there are results found.
                    • 7. Re: displaying and echo in the body
                      no im not but was unsure where this went
                      this is the header content
                      <?php
                      if (!function_exists("GetSQLValueString")) {
                      function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
                        if (PHP_VERSION < 6) {
                          $theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
                        $theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
                        switch ($theType) {
                          case "text":
                            $theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
                            break;
                          case "long":
                          case "int":
                            $theValue = ($theValue != "") ? intval($theValue) : "NULL";
                            break;
                          case "double":
                            $theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
                            break;
                          case "date":
                            break;
                          case "defined":
                            $theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
                            break;
                        return $theValue;
                      $currentPage = $_SERVER["PHP_SELF"];
                      $maxRows_Recordset1 = 5;
                      $pageNum_Recordset1 = 0;
                      if (isset($_GET['pageNum_Recordset1'])) {
                        $pageNum_Recordset1 = $_GET['pageNum_Recordset1'];
                      $startRow_Recordset1 = $pageNum_Recordset1 * $maxRows_Recordset1;
                      $var_SalaryReq_Recordset1 = "xxxxx";
                      if (isset($_GET['SalaryReq'])) {
                        $var_SalaryReq_Recordset1 = $_GET['SalaryReq'];
                      $var_skills_offered_Recordset1 = "xxxxx";
                      if (isset($_GET['skills_offered'])) {
                        $var_skills_offered_Recordset1 = $_GET['skills_offered'];
                      $var_location_Recordset1 = "xxxxx";
                      if (isset($_GET['location'])) {
                        $var_location_Recordset1 = $_GET['location'];
                      $var_PositionReq_Recordset1 = "xxxxx";
                      if (isset($_GET['PositionReq'])) {
                        $var_PositionReq_Recordset1 = $_GET['PositionReq'];
                      mysql_select_db($database_hostprop, $hostprop);
                      $query_Recordset1 = sprintf("SELECT ID, userid, FirstName, Surname, SalaryReq, PositionReq, location, otherComments, skills_offered FROM think_signup WHERE SalaryReq LIKE %s OR PositionReq LIKE %s OR location LIKE %s OR skills_offered LIKE %s", GetSQLValueString("%" . $var_SalaryReq_Recordset1 . "%", "text"),GetSQLValueString("%" . $var_PositionReq_Recordset1 . "%", "text"),GetSQLValueString("%" . $var_location_Recordset1 . "%", "text"),GetSQLValueString("%" . $var_skills_offered_Recordset1 . "%", "text"));
                      $query_limit_Recordset1 = sprintf("%s LIMIT %d, %d", $query_Recordset1, $startRow_Recordset1, $maxRows_Recordset1);
                      $Recordset1 = mysql_query($query_limit_Recordset1, $hostprop) or die(mysql_error());
                      $row_Recordset1 = mysql_fetch_assoc($Recordset1);
                      if (isset($_GET['totalRows_Recordset1'])) {
                        $totalRows_Recordset1 = $_GET['totalRows_Recordset1'];
                      } else {
                        $all_Recordset1 = mysql_query($query_Recordset1);
                        $totalRows_Recordset1 = mysql_num_rows($all_Recordset1);
                      $totalPages_Recordset1 = ceil($totalRows_Recordset1/$maxRows_Recordset1)-1;
                      $queryString_Recordset1 = "";
                      if (!empty($_SERVER['QUERY_STRING'])) {
                        $params = explode("&", $_SERVER['QUERY_STRING']);
                        $newParams = array();
                        foreach ($params as $param) {
                          if (stristr($param, "pageNum_Recordset1") == false &&
                              stristr($param, "totalRows_Recordset1") == false) {
                            array_push($newParams, $param);
                        if (count($newParams) != 0) {
                          $queryString_Recordset1 = "&" . htmlentities(implode("&", $newParams));
                      $queryString_Recordset1 = sprintf("&totalRows_Recordset1=%d%s", $totalRows_Recordset1, $queryString_Recordset1);
                      and this site in the body
                      <?php
                           else {
                      • 8. Re: displaying and echo in the body
                        sudarshan.t Level 6
                        Post your full code so I'll know the location of your noresults code.
                        • 9. Re: displaying and echo in the body
                          <?php
                            switch ($theType) {
                              case "text":
                                break;
                              case "long":
                              case "int":
                                break;
                              case "double":
                                break;
                              case "date":
                                break;
                              case "defined":
                                break;
                            return $theValue;
                          }if (!function_exists("GetSQLValueString")) {
                            switch ($theType) {
                              case "text":
                                break;
                              case "long":
                              case "int":
                                break;
                              case "double":
                                break;
                              case "date":
                                break;
                              case "defined":
                                break;
                            return $theValue;
                          <?php
                          // *** Validate request to login to this site.
                          if (!isset($_SESSION)) {
                            session_start();
                          $loginFormAction = $_SERVER['PHP_SELF'];
                          if (isset($_GET['accesscheck'])) {
                            $_SESSION['PrevUrl'] = $_GET['accesscheck'];
                          if (isset($_POST['userid'])) {
                            $loginUsername=$_POST['userid'];
                            $password=$_POST['password'];
                            $MM_fldUserAuthorization = "";
                            $MM_redirectLoginSuccess = "signup/signup-complete.php";
                            $MM_redirectLoginFailed = "failed.php";
                            $MM_redirecttoReferrer = false;
                            $LoginRS__query=sprintf("SELECT userid, password FROM think_signup WHERE userid=%s AND password=%s",
                              GetSQLValueString($loginUsername, "text"), GetSQLValueString($password, "text"));
                            $LoginRS = mysql_query($LoginRS__query, $hostprop) or die(mysql_error());
                            $loginFoundUser = mysql_num_rows($LoginRS);
                            if ($loginFoundUser) {
                               $loginStrGroup = "";
                                    if (PHP_VERSION >= 5.1) {session_regenerate_id(true);} else {session_regenerate_id();}
                              //declare two session variables and assign them
                              $_SESSION['MM_Username'] = $loginUsername;
                              $_SESSION['MM_UserGroup'] = $loginStrGroup;
                              if (isset($_SESSION['PrevUrl']) && false) {
                                $MM_redirectLoginSuccess = $_SESSION['PrevUrl'];
                              header("Location: " . $MM_redirectLoginSuccess );
                            else {
                              header("Location: ". $MM_redirectLoginFailed );
                          <?php
                            switch ($theType) {
                              case "text":
                                break;
                              case "long":
                              case "int":
                                break;
                              case "double":
                                break;
                              case "date":
                                break;
                              case "defined":
                                break;
                            return $theValue;
                          } else {
                          BODY HERE
                          <div id="CandidateSearchResCont">
                                  <?php
                               else {
                                    <?php do { ?>
                                      <table width="655" border="0" cellspacing="5" cellpadding="0">
                                        <tr>
                                          <td colspan="2" class="Titlegreen"><table width="100%" border="0" cellspacing="0" cellpadding="0">
                                            <tr>
                                              <td align="left"><a href="candidate-information.php?ID=<?php echo $row_Recordset1['ID']; ?>" class="joblinks"><?php echo $row_Recordset1['PositionReq']; ?></a></td>
                                              <td> </td>
                                              <td align="right"><?php echo $row_Recordset1['skills_offered']; ?></td>
                                              </tr>
                                        </table></td>
                                        </tr>
                                        <tr>
                                          <td colspan="2" class="textblack"><?php echo $row_Recordset1['otherComments']; ?></td>
                                        </tr>
                                        <tr>
                                          <td width="250"><a href="candidate-information.php?ID=<?php echo $row_Recordset1['ID']; ?>" class="smallTXTlinksBlack">more info</a></td>
                                          <td width="405"><div align="right"><span class="pos_salary"></span><span class="pos_location"> <?php echo $row_Recordset1['SalaryReq']; ?>/<?php echo $row_Recordset1['location']; ?></span></div></td>
                                        </tr>
                                      </table>
                                      <?php } while ($row_Recordset1 = mysql_fetch_assoc($Recordset1)); ?>
                                    <p>
                                    <table border="0">
                                      <tr>
                                        <td><?php if ($pageNum_Recordset1 > 0) { // Show if not first page ?>
                                            <a href="<?php printf("%s?pageNum_Recordset1=%d%s", $currentPage, 0, $queryString_Recordset1); ?>" class="smallTXTlinksBlack">First</a>
                                            <?php } // Show if not first page ?></td>
                                            <a href="<?php printf("%s?pageNum_Recordset1=%d%s", $currentPage, max(0, $pageNum_Recordset1 - 1), $queryString_Recordset1); ?>" class="smallTXTlinksBlack">Previous</a>
                                        <td><?php if ($pageNum_Recordset1 < $totalPages_Recordset1) { // Show if not last page ?>
                                            <a href="<?php printf("%s?pageNum_Recordset1=%d%s", $currentPage, min($totalPages_Recordset1, $pageNum_Recordset1 + 1), $queryString_Recordset1); ?>" class="smallTXTlinksBlack">Next</a>
                                            <?php } // Show if not last page ?></td>
                                            <a href="<?php printf("%s?pageNum_Recordset1=%d%s", $currentPage, $totalPages_Recordset1, $queryString_Recordset1); ?>" class="smallTXTlinksBlack">Last</a>
                                      </tr>
                                    </table>
                                    </p>
                                  </div>
                          • 10. Re: displaying and echo in the body
                            sudarshan.t Level 6
                            I see you haven't defined the variable $results anywhere else in your code. The following PHP function tells the system to count your variable results and if the count is more than 0 in our case, it implodes the results into your table. If the count is not more than 0, then it echos the variable noresults which says 'No results were found'.
                            <?php
                                 else {
                            In your case, since you haven't defined the results variable, the PHP script just echos the noresults variable as it doesn't find the results variable anywhere in your code.
                            • 11. Re: displaying and echo in the body
                              so i presume i need to add
                                   else {
                              in the php code at the top of the page? but wheree
                              • 12. Re: displaying and echo in the body
                                sudarshan.t Level 6
                                You have to define $results as a variable before you add this code anywhere on your page. You should tell the system what value it should assume as $results.
                                • 13. Re: displaying and echo in the body
                                  would i have to add something like
                                  $results = "No results were found!"
                                  • 14. Re: displaying and echo in the body
                                    no i tried that and it come back with error
                                    i am unsure what i need to put in there as this was not correct
                                    i know i havee to insert $results =
                                    but dont know what needs to come after this
                                    • 15. Re: displaying and echo in the body
                                      i have looked at many variations and they all seem simple but i dont know where to put the code
                                      i obviously need to add the varialble to the sql in the top of the page and the echo in the body
                                      <?php
                                           else {
                                      but what goes where i am unsure of...i have tried variations but non work
                                      any help would be very gratful
                                      thanks
                                      • 16. Re: displaying and echo in the body
                                        i have just tried this in the php at the head of the document
                                             else {
                                        } else {
                                        and this in the body
                                        <?php $noresults = "No results were found!";?>
                                        but this didnt work
                                        • 17. Re: displaying and echo in the body
                                          sudarshan.t Level 6
                                          Sorry for the M.I.A. Personal emergency.
                                          results should be a variable before you can use that variable to manipulate data strings.
                                          For example,
                                          <?php
                                          $a
                                          [0] = 1;
                                          $a[1] = 3;
                                          $a[2] = 5;
                                          $result = count($a);
                                          // $result == 3
                                          In this $result is defined as a total count of all $a values. This is static PHP. However, in your case, you should define $result to be the value of the actual results of your search query. For example, if you want to validate if your total rows returned from your sql query to be the markup for your PHP function, your code will be as follows:
                                          $result = $totalRows_Recordset1
                                          In this, we define the totalRows in Recordset1 as the total number of all rows in Recordset1. We then use that value as the $result. If you run a count function here, you could say if count is >, return a message saying there are rows present in the table. Else, echo that there are no rows.
                                          Trust this helps.
                                          • 18. Re: displaying and echo in the body
                                            i thiank you so much for you r help, i understand the concept of
                                            <?php
                                            $a
                                            [0] = 1;
                                            $a[1] = 3;
                                            $a[2] = 5;
                                            // $result == 3
                                            and
                                            but i have added this code to my code and it doesnt work, I think i am placing it in the wrong area of the code
                                            i tried adding an else statement..thinking it will read this then move onto the next this but i am getting errors in the code
                                            if
                                            $result = $totalRows_Recordset1;
                                            else
                                            } else {
                                            in the bosy i have
                                            <?php
                                                 else {
                                            so i removed the else and just added what you sent
                                            } else {
                                            and even if there are results it is still showing there arent any results?
                                            thanks again for you time
                                            • 19. Re: displaying and echo in the body
                                              Also no problem on the replies i hope your Personal emergency wasnt too serious!
                                              thanks
                                              • 20. Re: displaying and echo in the body
                                                sudarshan.t Level 6
                                                You have the answer to this in your question itself!
                                                Look at how you've configured newParams
                                                You're first querying your DB and you've defined $newparams as an array. Then, you're running a validation on it to find out its count.
                                                Your $results variable should be configured in a very similar manner.
                                                • 21. Re: displaying and echo in the body
                                                  ok, but this code was genertated by dreamweaver.
                                                  • 22. Re: displaying and echo in the body
                                                    got it sorted thanks you
                                                    in the header
                                                    $results = mysql_num_rows($Recordset1);
                                                    $noresults = 'No results found';
                                                    } else {
                                                    in the body
                                                    <?php
                                                    if($results == 0) {
                                                    thanks so much for your help
                                                    1 person found this helpful
