I'm using RoboHelp HTML 9 and Word 2010.
I generate a Word doc (.docx) as one of my outputs. The Word TOC works -- that is, if I Ctrl-Click one of the items in the TOC, I'm taken to that item.
A user just came up to me asking why the page numbers are off. Here's what I see.
I use SSL to generate the Word doc.
In the TOC, I look for the topic "Setting Up Comments." It's listed as being on page 30.
I Ctrl-Click that TOC item and it takes me to the topic, but when I look at the footer, it says this is page 28.
If I go back to the TOC, right-click, and choose "Update page numbers only", Word updates the TOC, which now shows the correct page number, page 28.
In other words, generating my printed doc is now a multi-step process:
Shouldn't the TOC be right the first time around? Am I forgetting to do something?
Very occasionally I have seen people report this before.
Check to see if it is all projects or just this one. I suspect the latter in which case all I can suggest is creating a new print layout, not a duplicate.
Since we have only one project here at the moment, I opened the RH sample Employee Care project. I used the Printed Documentation Location Based US layout.
The topic Contacting Human Resources is listed as page 20 in the TOC, but when I go to that topic using Ctrl-Click, the footer says page 15.
If I update the TOC, the TOC now says page 23. If I go to that page using Ctrl-Click, the footer says 23.
In other words, it seems to be a problem in the RoboHelp sample.
Your example was not the best, many chapters have such a topic. However, I am seeing issues there.
In another project I am finding the page numbers correct so I will need to do some more digging.
Meantime, given the problem can be recreated using the sample, you should report it as a bug.
Please follow this link.
http://www.Adobe.com/cfusion/mmform/index.cfm?name=wishform&product=38
I think I may have identified the problem here but it will take more testing.
If you create a new project with some simple topics, I think you will find the numbering is correct.
In your project, are you mapping to the Style Mapping template? If so, make a copy of your project and in that trash the template so that RoboHelp has to copy a new one in. See if that is any different.
This is very strange, and I might try it again later today if I have time.
As you suspected, if I create a new project, everything works fine.
I made a copy of my project and deleted the Style Mapping template I was using (I had edited the original RH template and renamed it).
Then I opened my project by double-clicking the .xpj file in that directory, just to make sure I was opening the correct project.
When I used my Printed Documentation layout, it asked me to locate a Style Mapping template. I navigated to the one from the new proejct, which was working fine in that project.
I still had the same problem!
My workaround: I found a Word macro that will regenerate the TOC. I just added those steps to the macro I'm already using to add page numbers.
I'd be curious if anyone else is having the same problem.
In your existing project try creating a new print layout, not a duplicate of the current print layout.
In my existing ("real") project, I created a new layout. For the mapping doc, I used the StyleMapping.dot file that was created when I created a new project (May 9, 2012 11:19 am).
Same result:
Rats!
I will poke around some more when I get a chance but for now there's nothing else to suggest. I will also be reporting this to Adobe. However, you should do the same.
The more people who report a bug or request a feature, the more likely it is to be actioned. Please follow this link.
I did report it, as you suggested. If no one else is experiencing this bug, don't poke around on my account. I've got a workaround (update the TOC either manually or using a macro), so it's not halting progress.
Thanks so much for your help, Peter.
