do CFOBJECT work in CFC File ?
Oct 19, 2006 Oct 19, 2006
Hello,
I have problems with implement cfobject in component.
Ex :
<cfcomponent>
<cffunction name="GetInfo" access="remote" returnType="numeric">
<cfobject name="acti" component="flashservice.test" >
<cfset tret=acti.Info()>
<cfreturn tret>
</cffunction>
</cfcomponent>
The same function work in .CFM and here an error My.CFC have not GetInfo method.
Sébastien
Advanced techniques
946
What is the code you're using to call the getInfo() method, and what
precise error do you get (copy it from the screen and paste it in here).
Adam
This service is call from client flash in actionscript :
var IntroService= _root.gatewayConnnection.getService("flashservice.coolf", this);
IntroService.getInfo();
Here coolf is CFC
And the 2nd call (cfobject...) to test. ASR
If I call directly test.ASR from Client -> All ok
The client can call CFC or ASR as the same.
But on server CFC can call ASR !
I don't know if calling CFC From a ASR is possible
Thanks Adam
Sébastien
Oct 20, 2006 Oct 20, 2006
OK, well I'm out of my depth now.
What happens if you write a CF test rig for it, and call it?
Adam
When I call CFC from CFC with <cfobject type="component">, the call work fine
The problem is when <cfobject> call ASR service from CFC.
Sébastien
Can you post your CF test rig.
It's easier if you provide the code and the errors, rather than describing
what you're doing.
Adam
Oct 23, 2006 Oct 23, 2006
HI,
I have a problem, test.asr have more 22000 lines and the CFC components more 10 000.
The summery is as this :
Seb
And the error is :
> Could not find the
> ColdFusion Component flashservice.bullengine
There is no mention of this CFC anywhere (taht I can see) in the code
extracts you've provided. Am I missing something?
Adam
> 10 000.
You are kidding, right? You have a 10000-line CFC?
Adam
Of course, it's right, with multiple <cfinclude>...
We have a very big application.
The CFC is just on message up.
thanks
the bullengine is not the name of this exemple, it's the same of test.asr, in real production.
The probleme is when invoke test.asr in CALL.CFC
The test.asr is not view as a regular component or web service.
I can't call test.asr from CALL.CFC. This is my problem.
effectively, the size of my code is certainely a problem.
"This method of calling a function in another component works fine if the component is called via "<CFINVOKE Component=" but, for some strange reason, doesn't work when called as a web service. Yes, it's the exact same function that is being called, but CF is evidently a bit more cranky when called as a web service. So we found that the only way to access a function in another component when called via a web service is to store that component in the Application scope."
the more at : http://mx.sys-con.com/read/86108.htm
The solution is here
Thanks.
Seb
Oct 24, 2006 Oct 24, 2006
Hang on. I only just twigged to something here.
This:
Refers to this:
test.asr File
function Dequote(s)
var ta=s.split("'");var ret="";if(ta.length>1){ret=ta[0];for(var
i=0;i<ta.length-1;i++){ret=ret+"''"+ta[i+1];}}else{ret=s;}return ret;
So flashservice.test => test.asr. Which is not a component (ie: a CFC).
It it's a webservice (which it doesn't look like), then you're using the
wrong syntax. Read this:
http://livedocs.macromedia.com/coldfusion/7/htmldocs/00000307.htm
So yes - <cfobject COMPONENT="foo" name="bar"> will indeed only work for
instantiating CFCs. That's what it's for.
Adam
Ok but i have trusted with webservice option but i think it's necessary declared web service "test.asr" in Cf Admin.
I experiment this and put the result here.
The way is good.
Seb
Re Hi,
It's impossible to declare a .asr as webservice.
So, I don't know how call a serverside AsctionScript service from CFC.
It's so very simple when call from Client. no différence between CFC and ASR
Seb
Documentation
