1. Re: Transcode to Cineform AVI
Colin Brougham May 8, 2012 4:12 AM (in response to MonkeyEatsMonkey)Prelude will transcode to just about anything, but it only allows you to use encoding presets to do this, and you can't create encoding presets in Prelude. However, you can build them in Pr or AME, and they will be automatically available in Prelude.
Simply open a test clip in Pr or AME, and build an AVI preset using Cineform. Save the preset, and then launch Prelude; the preset should be available in the list of presets after you select AVI as the Format.
2. Re: Transcode to Cineform AVI
MonkeyEatsMonkey May 8, 2012 7:57 AM (in response to Colin Brougham)I'm pretty sure I read this in the help file, because I already tried it. I used the CineForm Avi codec to create a custom preset that I named "CineForm 24p". And while it shows up in both Media Encoder and Premiere, it is not listed as an option in Prelude.
3. Re: Transcode to Cineform AVI
Colin Brougham May 8, 2012 8:17 AM (in response to MonkeyEatsMonkey)Hmm... I don't have Cineform to test, but I just tried Lagarith, and the preset I created in AME showed up in the AVI presets in Prelude. Did you close and relaunch Prelude? They won't automatically show up, since I believe they are initialized at launch.
4. Re: Transcode to Cineform AVI
MonkeyEatsMonkey May 8, 2012 9:13 AM (in response to Colin Brougham)Okay, I think I found a workaround. I created a new preset using Adobe Media Encoder, and instead of choosing "Cineform AVI" as my base codec, I chose "AVI" instead. Under the video tab, I changed the video codec to "GoPro-Cineform Codec (x64) v7.4.0", and changed the rest of the settings to what I would normally encode to (1920x1080, 23.976, progressive, square pixels), then named the preset "AVI Cineform 24p".
When I went back to Prelude, it appeared under the AVI presets. I didn't have to restart the program.
While this does work, it's far from intuitive. I'd much rather just be able to choose my codec from Prelude's transcode menu.
5. Re: Transcode to Cineform AVI
Colin Brougham May 8, 2012 9:24 AM (in response to MonkeyEatsMonkey)I'd much rather just be able to choose my codec from Prelude's transcode menu.
Let them know that here: https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
6. Re: Transcode to Cineform AVI
MonkeyEatsMonkey May 8, 2012 10:20 AM (in response to Colin Brougham)Done. Thanks for the suggestion.
