1. Re: PDF File Upgrade Problem.
radzmar Apr 25, 2012 11:03 AM (in response to Thirusanguraja Venkatesan)Sorry, but I don't understand what you're trying to do.
Please explain exactly what you're doing.
2. Re: PDF File Upgrade Problem.
Thirusanguraja Venkatesan Apr 25, 2012 9:30 PM (in response to radzmar)I have uploaded PDF document properties window screen shot in that I have highlighted pdf version that is 1.4 , but I want to upgrade that pdf version into 1.6 or above, for that am using Adobe Reader 9 to upgrade while upgrading the Adobe reader will get automatically closed the upgrading process will terminated.
3. Re: PDF File Upgrade Problem.
radzmar Apr 25, 2012 10:15 PM (in response to Thirusanguraja Venkatesan)I'm still not sure what you're doing and why.
I mean, how are you trying to change the PDF Version of your PDF? Reader isn't able to do such things.
4. Re: PDF File Upgrade Problem.
Thirusanguraja Venkatesan Apr 26, 2012 12:30 AM (in response to radzmar)Thanks for reply,
Sorry for miss understanding, Now i will explain you setp by step process
Am going to add Accessbility tag to my PDF document
Step: 1
Adding accessbility Tag to the pdf document
Error Msg:
While the process get started the following error message will appear and adobe reader will get closed
Are you got what is problem?
5. Re: PDF File Upgrade Problem.
radzmar Apr 26, 2012 12:54 AM (in response to Thirusanguraja Venkatesan)Well, first of all, you should install the latest updates for your Acrobat (current Acrobat 9.5.1).
If the error then still occurs, it may be that the internal structure of your file is damaged or of a very poor quality.
Then I suggest to run the preflight plugin to try to fix the PDF.
There are tons of fixups in the preflight plugin so you may have to test which does fix your problem.
6. Re: PDF File Upgrade Problem.
Thirusanguraja Venkatesan Apr 26, 2012 2:49 AM (in response to radzmar)Thanks for your valuble reply…
7. Re: PDF File Upgrade Problem.
Thirusanguraja Venkatesan Apr 26, 2012 2:54 AM (in response to Thirusanguraja Venkatesan) -
8. Re: PDF File Upgrade Problem.
Thirusanguraja Venkatesan Apr 26, 2012 3:11 AM (in response to Thirusanguraja Venkatesan)Hi radzmar,
One more interesting news am used "Acrobat 6" for adding accessibility tag it was completed successfully without any error message and result is fine.
But I want to known what is the problem in "Acrobat 9" and "Acrobat 10" can you help me?
9. Re: PDF File Upgrade Problem.
radzmar Apr 26, 2012 4:16 AM (in response to Thirusanguraja Venkatesan)Interesting.
Can you upload you PDF file somewhere, so I can check it with my system?
10. Re: PDF File Upgrade Problem.
Thirusanguraja Venkatesan Apr 26, 2012 5:33 AM (in response to radzmar)There is no option in this reply forum to send file to you so please send me your e-mail id for sending that sample pdf file else give me any other alternative way to send file to you.
Thanking you..
11. Re: PDF File Upgrade Problem.
radzmar Apr 26, 2012 5:37 AM (in response to Thirusanguraja Venkatesan)Please use a file sharing service such as Acrobat.com and post the link here.
12. Re: PDF File Upgrade Problem.
Thirusanguraja Venkatesan Apr 28, 2012 2:07 AM (in response to radzmar)Download File From Below Link
https://www.drivehq.com/file/df.aspx/shareID9797912/fileID998763156/Test.pdf
13. Re: PDF File Upgrade Problem.
radzmar Apr 30, 2012 12:57 AM (in response to Thirusanguraja Venkatesan)Hi,
sorry but the link has expired.
14. Re: PDF File Upgrade Problem.
Iakov Qvaz Apr 30, 2012 1:35 AM (in response to radzmar)Good to see you here, Radzmar. I noticed you when I visited the Acrobat forms forum and felt you were bored because you were not challenged. This forum is much, much more engaging and you are naturally thriving (three red boxes). Thank you for helping here.
15. Re: PDF File Upgrade Problem.
Thirusanguraja Venkatesan May 3, 2012 9:56 PM (in response to radzmar)Sorry for inconvenient please download file from following link.
16. Re: PDF File Upgrade Problem.
radzmar May 3, 2012 11:38 PM (in response to Thirusanguraja Venkatesan) -
17. Re: PDF File Upgrade Problem.
Thirusanguraja Venkatesan May 4, 2012 1:55 AM (in response to radzmar) -
18. Re: PDF File Upgrade Problem.
radzmar May 4, 2012 2:07 AM (in response to Thirusanguraja Venkatesan) -
19. Re: PDF File Upgrade Problem.
Thirusanguraja Venkatesan May 8, 2012 10:22 PM (in response to radzmar)Thanks for you help,,
I am having one more problem in adding tag to pdf please hlep me see below forums link
