1 Reply Latest reply on May 8, 2012 11:10 PM by Manish K.A
    Republishing the Streams
    Saran_soft84
      Hi Everyone,
      I like to republish all the streams from one FMS to another FMS. I also placed the publishing code in core FMS server (main.asc) and the accept connection code at the other end secondary FMS(main.asc). All the streams are republished as well. After a some hours later publish is not active in receiving end FMS but it is active in core FMS. Kindly guide me to proceed further.
      Thanks in advance
      Saravanan
        • 1. Re: Republishing the Streams
          Manish K.A Helper
          How long does it take before feed become inactive on second server? Do you see anything in the logs of both server which can hint what is the issue -
          Please check core / applications logs on both servers.
          Is it possible for you to share the code just in case if that helps us in resolving issue
