Selecting Certain Parts of a Value
Oct 23, 2006 Oct 23, 2006
I have attached the code I am using to test this out and make sure it works before implementing it. What I have is a database field which stores the date and time that they select. It keeps it in the form of yyyy-mm-dd hh:mm:ss. I want to pull all of those out to cfset variables so it would go something like...
<cfset year = "the yyyy value">
<cfset month = "the mm value">
and so on...
However, with the attached code, I am getting everything past the '-'. So if in the database it was 2006-10-8 10:40:23, it is showing 8 10:40:23. I want it to be just the 8.
My other problem is how to get the reast of the values out, and set all those different parts of the time to the different variables with the fucntions I do not know how to use:(. Any help would be great!
Thanks!!
Advanced techniques
263
Participant , Oct 23, 2006 Oct 23, 2006
Hi
try this code.
Participant ,
Hi
try this code.
Engaged ,
Oct 24, 2006 Oct 24, 2006
You also may want to lookup the function DATAPART() as well. You can extract just parts of the date that you want, taking the value is a valid date/time object.
You have a datetime field. If your db has date functions they will work. If not, cold fusion date functions will work and they are a lot simpler than string functions.
To start, put google "coldfusion date functions".
Documentation
