14 Replies Latest reply on May 11, 2012 11:54 AM by Kurt Gold
    PDF showing overprint preview
    Mathias17 Level 2
      Is there a way to output a PDF that looks like Aunt Illie's Overprint Preview?
        • 1. Re: PDF showing overprint preview
          Kurt Gold Level 5
          Which version of Illustrator are you using?
          Also, what exactly is the purpose of your request?
          • 2. Re: PDF showing overprint preview
            Mathias17 Level 2
            Using Illustrator CS5.
            I want to output PROOFs for customers that are more accurate.
            • 3. Re: PDF showing overprint preview
              Kurt Gold Level 5
              That means it is rather inappropriate to tell them to turn on Overprint Preview in Acrobat or Acrobat Reader, right?
              If so, take a copy of the file, do a Flatten transparency and save as .pdf
              Sometimes you would first have to apply a midget transparency value to all objects (e. g. 99 % opacity).
              • 4. Re: PDF showing overprint preview
                TommyGun96 Level 1
                Overprint preview is just an on-screen simulation of the artwork it is not changing any color values at all.
                If you're making color proofing prints you should have a calibrated RIP that handles the color rendering accurately, otherwise if you just want to sent a on-screen preview for customers you could make a screen capture of your overprint-preview.
                • 5. Re: PDF showing overprint preview
                  Larry G. Schneider Adobe Community Professional & MVP
                  Here's a file from AI saved as a PDF and opened in Acrobat. The orange rectangle is set to overprint in AI. For Acro9 and above I think that Overprint Preview is automatic. If it detects it, it will show it.
                  • 6. Re: PDF showing overprint preview
                    Mathias17 Level 2
                    Yeah, the Overprint Preview setting thing is great to know. I'm only just now getting heavily into prepress file set up so I'm figuring all this out for the first time.
                    @Kurt & Larry - I think it works really well, but actually instructing all customers to change that setting I'm almost positive will only cause more confusion than anything . . . but I still may try it. Perhaps an instructional screenshot, just like you attached, Larry. Might just do the trick! Hmm, what aboput those without Acrobat, who only have Adobe Reader? Does Reader include this functionality?
                    @Tommy - I actually did exactly that for the proof I output today. But . . . I don't want to be stuck with that everytime there are overprint elements or fluorescent inks used in a design.
                    • 7. Re: PDF showing overprint preview
                      Kurt Gold Level 5
                      Yes, it's there in recent versions of Acrobat Reader.
                      On the other hand, have you already tried the other suggestions in post 3?
                      • 8. Re: PDF showing overprint preview
                        It's set to Automatic by default in 9 and 10 so someone would have had to go in and change it to see something different.
                        • 9. Re: PDF showing overprint preview
                          Mathias17 Level 2
                          Oh ok, thanks.
                          Ah yes, I meant to comment on that - I tried it and it seemed to do nothing. Though, I don't understand Flatten Transparency at all. I've read about it, but have never worked with it.
                          Here's my attempt:
                          Afterward, it all looked and seemed to be unchanged.
                          Another screenshot for ya (with no Flatten Trans done) - The pink swooshy shapes are screens of a PMS, set to overprint. Here you can see my setup with one selected, along with my workspace panels mess (yes, that's a little extra Hieronymous B. wallpaper action for the fine art lovers in tha hizzouse):
                          • 10. Re: PDF showing overprint preview
                            Mathias17 Level 2
                            Holy Snikes I just unchecked "Preserve Overprints and Spot Colors" in the Flatten Transparency dialogue and something magical happened!
                            • 11. Re: PDF showing overprint preview
                              isladive Level 1
                              There is a way to create a pdf proof directly from Illustrator that looks like your screen does with the Overprint Preview on (and without having to take a screenshot instead).  If you go to your color swatches and then down to "Spot Colors" and change the color definition to LAB instead, when you get out of that, your color will look like overprint on even if you do not have that option selected AND your PDF created from Illustrator will also look like that.  However, you do not want to save it with LAB colors, so undo or don't save the file that way. This is new to me as well, I was just researching some of this same stuff today and read a great article about the OP and LAB colors, etc., that led me to make this PDF proof discovery.  If you are intretested in the article to understand more... http://rwillustrator.blogspot.com/2007/02/busting-myth-achieving-consistent-color.html
                              Like I said, I discovered this today and it seems to have worked fine.
                              • 12. Re: PDF showing overprint preview
                                Kurt Gold Level 5
                                I've not tried isladive's method yet.
                                Can anyone confirm that new insight?
                                • 13. Re: PDF showing overprint preview
                                  Mathias17 Level 2
                                  Gahh, haven't got around to it yet, Kurt. Soon, soon . . . though I'd rather someone more experienced with this madness test it out.
                                  But, I would like to announce that Flatten Transparency has solved yet another one of my Illy conundrums - When you Release an object's Envelope Distort > Make With Warp and you get that grey shape warped to the shape of the distortion envelope. I've always wanted to use to use it for certain things but could nevber figure out how to convertin it into a normal path. No longer.
                                  • 14. Re: PDF showing overprint preview
                                    Kurt Gold Level 5
                                    Isladive,
                                    can you provide a sample .ai file including some more instructions?
                                    Your idea sounds promising. I'm not sure if it really works, though.
