flash player freezes windows 7 64 bit in chrome and firefox. Any resolution to this problem? Have a brand new HP Computer and locks up my computer and hitting control alt delete does nothing. After holding the start button down and restarting the computer it will not start again until I take the battery out and do a fix. Any help on this?
Moving this discussion to the Installing Flash Player forum.
What is your Firefox version? Does the same thing happen if you use Waterfox instead?
What is your Flash Player version?
What is your display adapter, device driver version & date?
What is your Firefox version? 12.0
Does the same thing happen if you use Waterfox instead? Yes
What is your Flash Player version? 3.1
Adobe Shockwave Player File Version: 11.6.1.629 Date Modified 8-23-2011
What is your display adapter, device driver verions & date?
Radeon(TM) HD 7690M XT
Intel(R) HD Graphics Family
Advanced Micro Devices, Inc Driver Version 8.882.2.3000 Driver Date"9/30/2011
Hope this helps and thank you. This is a brand new computer and no help from HP
Please check here what your Flash Player version is:
Please install the latest version if you have anything less than 11.2.202.235
Regarding your display adapters, go to these locations to check for newer device drivers:
P.S. the driver checking utility works best on Internet Explorer.
1. Go to the address field in chrome and type in "chrome://plugins"
2. You will see the section for the flash plugin, go to right of the page and click the "+" sign to expand the info.
3. Examine the entries you have for the flash plugin (usually two). Look at the "Location" address for each entry. Disable the one that belongs to the chrome application, you don't need it, it will conflict with adobe's plugin.
