I just bought the creative cloud and i tried downloading and installing a couple cs6 apps and i get this error.
"The application Install.app can't be opened. -1712"
What do i do?
Running Mac OSX 10.7.3
First Generation i7
A system restart should help. 1712 is a mac OSX error when something times out usually thrown when process is running already or the process didn't close properly last time.
Please move the .dmg file to a different location and then try to install the software.
The issue is with the incorrect permissions to the location where you have saved the downloaded file of Adobe CS6
Open Disk Utility and run "Verify Disk Permissions" and then "Repair Disk Permissions".
After that try installing and check if it works.
Premjit
I just encountered a similar problem but no dialog.
The solution is simple, just remove the extended attributes on the file, like this:
Chin$ xattr -c FlashBuilder_4_7_LS10.dmg
May it will help
Nice of you to chime in, but you are replying to a post that is well over two years old.
I did a system restart and it worked! Thanks for the reminder that when all else fails, try "restart"
