When I try to supress hyphenation in an arithmetic expression (-64dBVp-p), I select that word then hit shortcut
ESC n s (as the documentation says). A "no hyphenation" marker appears but the word itself disappears. Am I doing something wrong?
Cheers,
JP
I found either a solution or a workaround. David solved the problem of the
disappearing word (<applies dope slap to self>) but the word still broke
at the hyphen.
I then tried changing the hyphen to a true minus sign, (CTRL-Q SHIFT-P)
but that didn't work either-- the word broke after the minus sign.
The problem went away after I did Format>Document>Text Options and removed
both the hyphen and the minus sign from the "Allow Line Breaks After" field.
Cheers,
JP
What happens if you do a CTL-L to refresh the screen? Does that bring it back?
Alas, no.
You shouldn’t be selecting the word. Place your cursor in front of it and then enter the no-hyphen code.
You will also have to use non-breaking hyphens inside your expression.
at the hyphen.
Cheers,
JP
While you can remove them from the Allow Line Breaks, you could also have just inserted non-breaking hyphens (Esc - [hyphen] h). Maybe for the future (i.e., it's easier to type, and you don't prevent appropriate breaks).
P.S.,
Surely this is a bug. ESC n s is an override and to have it fail to override
this fairly obscure setting is crazy-making.
Also, I'll want to go back and add +, =, etc. to make sure other expressions don't get broken.
Cheers,
JP
I thought "ESC n s" was just for suppressing the hyphenation symbol - at least that's what the FM9 shortcuts list that Jetsetcom.net had published a few years ago and the help says.
