2 Replies Latest reply on May 11, 2012 3:23 PM by FlashKatt
    Graphic moves tho it's position is numerically the same
    FlashKatt Newcomer
      I have a graphic..a bit of type imported as an AI graphic, which moves when I play the animation in Flash (by hitting the Return key).
      I check its position before and after I see it move; no change in the position. When I publish, this same element does not move, which is good..but...
      ..the fact that it moves in Flash throws the accuracy of the feedback...is it moving or isn't it? sort of thing..
      anyone know what the cause and fix for this would be?
      Thank you!
      kat
