1. Re: Color matching to HP color laserjet
lilia@ Apr 19, 2012 10:52 AM (in response to Evil Lair)You will most likely find that when printing to a desktop printer it is best to print in RGB... change your workspace to RGB or make sure it uses the RGB profile.
Test it by creating a document with 4 squares coloured in CMYK... then compare the print to the actually colours rather than comparing them to your screen.
2. Re: Color matching to HP color laserjet
Manish-Sharma Apr 19, 2012 12:38 PM (in response to Evil Lair)How does the PDF comes out for the same document....is there color difference in it as well?
If in PDF the color are proper then how is the output when you print the PDF?
3. Re: Color matching to HP color laserjet
Evil Lair Apr 19, 2012 1:17 PM (in response to Manish-Sharma)Creating a pdf and printing from Acrobat results in the same colors and darkness.
For this test I am printing something that has already been commerically printed, which also closely matches what I have on my calibrated monitor.
4. Re: Color matching to HP color laserjet
Manish-Sharma Apr 19, 2012 1:23 PM (in response to Evil Lair)So when you make PDF form Indesign , does the color difference show up on-screen as well.(when you open PDF in any PDF reader)
Can you show the screen shot of the Indesign doc and Print out?
5. Re: Color matching to HP color laserjet
Evil Lair Apr 19, 2012 3:10 PM (in response to Manish-Sharma)The pdf matches what shows in Indesign if I include the color profile, which is what I tried printing out from Acrobat. Unfortunately the content I am working with isn't my own so I can't show a screenshot or picture.
6. Re: Color matching to HP color laserjet
Is this profile supposed to match the laserjet or the press?
7. Re: Color matching to HP color laserjet
I admit to still being a bit mystified to the whole color profile process even after years of using it and reading articles about it. I created our profile years ago to match 3m matchprint proofs, mainly just for Photoshop to display cmyk images as closely to those 3m proofs as possible. Photoshop is setup not to embed and ignore any profiles in images. Any print projects back then just went for the standard film/matchprint, and later the digital files sent directly to the printer without any regard for color profiles and it worked pretty well.
Since then I've been using it in Indesign and Illustrator as the main cmyk profile so everything displays the same, and the final print-ready pdf for our main internal projects goes to our commercial printer with the profile as well. I've tried the standard printer profiles that come built-in but they always look really off and way too yellow. Anything we have gotten commercially printed, or ended up in other outside projects matches up well regardless of included-or-not profiles, the only normal difference is the profile displays a little lighter than what gets printed but I prefer that anyway.
8. Re: Color matching to HP color laserjet
P Spier Apr 20, 2012 9:21 AM (in response to Evil Lair)CMYK profiles are device-dependent, so the numbers you are feeding the laserjet are probably inappropriate for the device. Does HP provide any profiles? They won't be as good as custom profiles, but probably better than what you are using. And how are you calibrating the monitors? If you've calibrated to a device-dependent space that won't help, either.
9. Re: Color matching to HP color laserjet
Evil Lair Apr 20, 2012 10:54 AM (in response to P Spier)My custom profile is only used for the working space. For the printer profile in the Print/ColorManagement/Options I set it to the HP supplied profile (hp color LaserJet CMYK v402). I've also tried other printer profiles but it doesn't change the output in any way.
My monitor isn't calibrated to any specific device, just using a Spyder3 with standard gamma/whitepoint/brightness targets.
10. Re: Color matching to HP color laserjet
P Spier Apr 21, 2012 5:38 PM (in response to Evil Lair)What happens if you go to View > Proof Setup and select your HP Profile, then View > Proof Colors?
11. Re: Color matching to HP color laserjet
Evil Lair Apr 23, 2012 8:04 AM (in response to P Spier)Doing that displays the colors much closer to what is printing out, however it displays even brighter than my own profile. So the ink levels or brightness are displaying much brighter especially in darker areas on screen vs printed output where it all just turns completely black.
For example an area of C:65 M:58 Y:52 K:33 just comes out black on the printer.
12. Re: Color matching to HP color laserjet
P Spier Apr 23, 2012 9:32 AM (in response to Evil Lair)It's not unusual for a monitor to show dark areas brighter than the print (I had a terrible time with this last summer on a project). You are, after all, looking at transmitted light vs. reflected light.
13. Re: Color matching to HP color laserjet
Evil Lair Apr 23, 2012 11:01 AM (in response to P Spier)True, but this is so far off I can't really use this printer for any type of use besides what a dirt-cheap inkjet would see as it is now. The old Minolta printer wasn't the greatest print quality but the colors and levels were at least very similar to what my workflow looks like. I really feel like the printer is more than capable to output something that exceeds the old printer but there is a software issue somewhere that is holding it back.
I made a quick mockup to show the difference between what I want and what comes out of the printer:
14. Re: Color matching to HP color laserjet
P Spier Apr 23, 2012 11:54 AM (in response to Evil Lair)That certainly looks like a profile mismatch.
Are you using a Postscript or PCL driver? And you might want to try the drivers from HERE: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&pro dTypeId=18972&prodSeriesId=3974355&prodNameId=3974362&swEnvOID=219&swLang=8&mode=2&taskId= 135&swItem=lj-78442-1
15. Re: Color matching to HP color laserjet
Evil Lair Apr 23, 2012 3:06 PM (in response to P Spier)I am using the Postscript driver. Those drivers from the HP site are what I first tried, and after reading around some people had issues solved by using the several years newer drivers from Apple which is what I am on now.
Based on the common theme I'm seeing online that HP color printer support for Macs just sucks I think we will be returning this one and going with another brand. If anyone has any suggestions for a tabloid/networked color laser they are happy with I would be glad to hear about it.
16. Re: Color matching to HP color laserjet
P Spier Apr 23, 2012 3:16 PM (in response to Evil Lair)I've been using a Xerox Phaser 7800 for a few months now and I love it.
17. Re: Color matching to HP color laserjet
Evil Lair Apr 24, 2012 7:31 AM (in response to P Spier)That model is a bit out our range but the 7500 or the Dell variant of the same looks very promising. If we switch to something that works well I'll report back.
18. Re: Color matching to HP color laserjet
P Spier Apr 24, 2012 8:35 AM (in response to Evil Lair)One of the nice things about Xerox is the sales rep can send in your test file and they'll print it without attempting any kind of color management and send you the results. I started my shopping a week or so before the 7800 was availble, so I got prints first from the 7500 and they were very good (and the price was reduced to clear them out). When I got the 7800 prints of the same files a week later I was completely blown away. What had looked great the week before was only barely acceptable when compared side-by-side with the new prints.
This does not mean the 7500 is not a good printer -- just that the 7800 is amazing. I think it cost me about $800 more (and I bought the PhaserMatch calibration package which you can get with either model) than I would have spent on the 7500, and it will definitely cost more for supplies (It has separate drum units for each color), but it was my gift to myself and I have no regrets.
19. Re: Color matching to HP color laserjet
mr. pep May 7, 2012 5:56 PM (in response to P Spier)Peter this hits on an issue I have. My publishing company produces high quality color books. We scan in old comic strips and color correct them. I need a good printer to proof our pages before we send the files to the printer. We had an old HP 3800 and liked it. So, I recently got the 5225 and it sucks. So I thought I'd go up to the 5525, which has calibration software, but I'm gun shy about HP now. You say the Xerox 7800 is good. I've narrowed down my options to the HP 5525 or the Xerox 7800. Both have calibration, duplexing and tabloid size. Is the 7800 the way to go? I also think I'll get killed on toner. Can you tell me which is better?
20. Re: Color matching to HP color laserjet
P Spier May 8, 2012 3:51 AM (in response to mr. pep)I cannot tell you which is better. I've had no experience with the HP. I will say this though, the Xerox uses genuine Adobe Postscript and the HP uses emulation, and I'll personally never buy a ps printer that uses emeulation ever again after having had some issues in the past. Your mileage may vary.
I love my 7800, but the best advice I can offer is to prepare a file and make sample prints on both machines.
21. Re: Color matching to HP color laserjet
Evil Lair May 11, 2012 3:35 PM (in response to P Spier)We ended up replacing the HP with a Xerox 7500n. Right out of the box the prints are about 95% color accurate along with much sharper and accurate text (the HP was maybe 65% accurate?). It is so much better quality compared to the HP and so much closer to finished print projects it is not even a contest. It looks to have double the print resolution and white text on a rich black background looks superb, compared to the high-compression jpg looking uneven blotchiness of the HP. Its like the Xerox is using a completely different printing technology or something its so much better.
I am having a bit of difficulty dialing in the last 5%. The prints are a bit light and the colors a little saturated using the default print setup in Indesign. Using the Proof print setting fixes the brightness and knocks the colors down perfectly, but neutral colors turn reddish. Changing among the different printer profiles doesn't seem to have any effect, nor changing the setting under Print/Color Matching/ choosing Colorsync or In Printer. Surprisingly there doesn't appear to be a printer profile to choose from specific to the Xerox.
There is the manual color correction under the Xerox print options but I don't want to have to go through that every time printing something.
22. Re: Color matching to HP color laserjet
P Spier May 11, 2012 3:44 PM (in response to Evil Lair)You need to have the printer profiled (and recalibrated or re-profiled at regular intervals), or figure out the settings you use to get the color right, then save them as a preset.
23. Re: Color matching to HP color laserjet
mr. pep May 11, 2012 6:25 PM (in response to P Spier)Thank you Peter and Evil Lair for your advice. I asked both HP and Xerox to run test prints for me. I'm still waiting to hear back from HP. They acted like they'd never heard of such a request, but would try. Xerox had a local office near Seattle and a rep not only agreed to run 3 pdf's for me, but he dropped them off at my office. They were spot on, whereas the HP I initially had, the 5225, was terrible. I hoped the HP 5525 would be better, if only because it had calibration capabilities, and the 5225 did not. Well, we went and got the Xerox 7800 DN. We may spend more on toner over time, but we get the results we wanted. Not only will it be great right out of the box, but I can adjust the individual ink densities if I need to.
I find it hard to believe my needs were so unusual. And buying a printer without first seeing a print is like buying a car without driving it. I even tried to get some manufacturers to give me names of happy customers, but they all balked, which seems counter-productive to me.
I hope my experience will help others out there.
24. Re: Color matching to HP color laserjet
BLUDVLZ13 Sep 5, 2014 11:18 AM (in response to Evil Lair)Evil,
This may be two years in the answering, but like you, I have run into the same problem with the HP CP5225 printer. By default it just seems to want to drop out all (or mostly all) the yellow from images. I just invested in a Colormunki Photo (~$500) and used that spectrophotometer to generate a custom color profile for the printer--and it actually WORKS! I get near-perfect color now from the printer that matches my screen.
I've made it available to download at the link below:
https://www.dropbox.com/sh/5qvilx8r1ue0n4x/AADxrN8fCm1i2gijMOf8hLC8a?dl=0
Install it to your computer and specify it as your CMYK profile when printing from your app.
Hope this helps!
