9 Replies Latest reply on May 13, 2012 3:36 AM by Ronald_Simpson
    How create a single path to type on, not compound path from many paths?
      I am a bit new to illustrator, but I am having trouble figuring this one out.
      I have some negative space I created(black area, see image) that I want to fill with type, not just a simple fill.
      Basically I want to create the negative space from a bunch of small minus signs(-) that need to line up as they go across. If I type on each path one at a time as the text doesn't line up that way. This needs to be one continuous path.
      Unfortunately if I add them together, it creates a compound path, which you cannot type on, unless I am mistaken? So I need them to be a path, not a compound object.
      Hopefully that made sense, any help would be greatly appreciated.
      Thank you!
