10 Replies Latest reply on Feb 16, 2017 4:31 PM by Richard_B.Riddick
    Uh, how do you deselect in Photoshop?
    John Stanowski Level 2
      I feel really dumb right now but for some reason I'm having trouble deselecting. First off, I'm talking layers and vector objects here. I know Cmd D deselects selections. But how you do deselect any layer which might currently be active? I'm working in PS CS6 for the first real time and it's like I suddenly got dumb or something. I know you can select a blank area of the Layers Panel to do it, but my Layers Panel is full right now, so I don't even see any dead space. This is especially troubling because I'm making a lot of shape layers and if I do that while a layer is selected then I wind up making masks.
      Help.
      Update: I just figured it out. You Cmd select the selected layer. whew. Just mentioning it in case anyone sees this who needs it. (PS CS6 removed the "blank area" at the bottom of the Layers Panel!)
        • 1. Re: Uh, how do you deselect in Photoshop?
          Trevor.Dennis Adobe Community Professional
          Click on an empty part of the Paths panel, or hit the Escape key.
          • 2. Re: Uh, how do you deselect in Photoshop?
            emil emil Level 4
            While you have a path with anchor points selected, Escape will deselect the anchor points but the vector mask remains active indicated by the paths outlines remaining highlighted and the white frame on the layer mask in the layer's panel and also the highlighted path layer in the Paths panel. Alternatively the same can be achieved by clicking anywhere outside or inside but not on the actual path with one of the path selection tools (black or white pointer) which are also accessible temporarily while holding Ctrl/Cmd when using a pen tool.
            While no anchor points are selected, Escape will remove the focus (deselect) the vector mask but the current layer remains active (selected). Alternatively the same can be achieved by clicking the vector mask icon in the layers panel which toggles the vector mask selection or clicking an empty space on the  Paths panels
            Ctrl/Cmd clicking the selected layer in the Layers panel or just clicking an empty space in the Layers panel will deselect the currently selected layer leaving you without a selected layer and any pixel editing tools and menus will be dimmed.
            edit: we haven't installed CS6 yet and I don't know the details there which may be different.
            • 3. Re: Uh, how do you deselect in Photoshop?
              I didn't need to deselect paths. I needed to know how to deselect Layers. In order to make a new Shape Layer there must be no layers currently selected, else you would wind up making a vector mask on that selected layer.
              I wanted to be able to make sure there were no selected layers so that I could create fresh Shape Layers. Problem is if your layers run all the way down past the bottom of the Layers Panel, you have no "blank space" to click to deselect any selected layers.
              I just found out that Command-clicking the selected layer will deselect it. That's what I was looking for. It's a clunky way to work, but I guess it's all I've got.
              I wish you could do the same with just a key as often the currently selected layer could be out of view.
              • 4. Re: Uh, how do you deselect in Photoshop?
                emil emil Level 4
                John Stanowski wrote:
                ... In order to make a new Shape Layer there must be no layers currently selected, else you would wind up making a vector mask on that selected layer...
                In order to make a new Shape Layer you have to have the New Shape layer button selected in the tool's option bar under the main menu - this is the button before Add to shape, Subtract from shape, etc. You don't need to deselect the layer for this - you can just click the New Shape Layer button in the options. But this button will be automatically selected if the tool is in Shape Layers drawing mode (fist button on the options bar) and a vector mask is not active which can be done with the Escape key. Deselecting a layer also automatically sets that option but you don't need to do that. Just press the Escape key and that's it - you will create a new shape layer. If you have anchor points selected press the Escape key twice.
                • 5. Re: Uh, how do you deselect in Photoshop?
                  Ahh, you're right. Cool. Then deselecting all layers isn't an issue anymore.
                  • 6. Re: Uh, how do you deselect in Photoshop?
                    Noel Carboni Level 8
                    However, to answer your question a little more directly, in Photoshop on a PC one only has to hold down the Control key when clicking a layer to deselect it.  I'm not sure what key that maps to on a Mac...  Try your modifier keys.
                    -Noel
                    • 7. Re: Uh, how do you deselect in Photoshop?
                      PECourtejoie Adobe Community Professional
                      Noel, it's Command (CMD) on a Mac, as stated in the first post. (And remember: http://forums.adobe.com/thread/946377 )
                      • 8. Re: Uh, how do you deselect in Photoshop?
                        TimmyCrackCorn Level 1
                        Is there any other way (like a shortcut) to do this?  Sometimes you have a LOOOONG list of layers, and to have to scroll through every time, located the highlighted layer, the cntrl-click is a R-PITA.  There has to be a shortcut ... should just be ESCAPE or something.
                        Tim
                        • 9. Re: Uh, how do you deselect in Photoshop?
                          Travis NIO Level 1
                          Yes, it is an issue, in CC 2014 you would just select escape to unselect the layer and it would work, another workflow issue.  If you try to go to the custom keyboard section in the edit dropdown, it won't let you program esc as the Select->Deselect Layers Dropdown, either.  Another downgrade of this newest update is that if you want to change a custom keyboard instead of letting you do it like it did before and taking you to the old one, it just gives you a Red X button not letting you change it without having to manually find the offending command in the super long list.  Another downgrade, can't Adobe figure this stuff out in testing?  Esc worked for years, then it doesn't, not good.
                          Anyways, the key and easier way is to just click outside of it.  Missing escape key will probably rewire CMD+D to Deselect Layer, since I never use it (except for in InDesign, but that's another story).
                          • 10. Re: Uh, how do you deselect in Photoshop?
                            Richard_B.Riddick Level 1
                            if all else fails, click outside the canvas !!
                            If you don't have auto-select enabled, CTRL+click outside the canvas.
