1. Re: Cannot Load CS5.5 Projects Into Premier PRo Cs6 when they contain MTS files
TheMtyThor May 14, 2012 3:52 PM (in response to TheMtyThor)incase any one finds this, Cs 5.5 With MTS files in the project did not initially Load IN CS6. i had to add another Sequence Set to AVCHD in the Sequence presets, then Re-link the MTS files per folder and all files showed up, i hope that helps any one looking for this answer
2. Re: Cannot Load CS5.5 Projects Into Premier PRo Cs6 when they contain MTS files
JSS1138 May 14, 2012 3:54 PM (in response to TheMtyThor)i have a TON of CS5.5 Projects
General wisdom is to finish those in 5.5, and only start new projects in CS6.
3. Re: Cannot Load CS5.5 Projects Into Premier PRo Cs6 when they contain MTS files
TheMtyThor May 14, 2012 4:30 PM (in response to JSS1138)Not A Viable Option since this is a BUG not a feature ion CS6 Premier Pro
4. Re: Cannot Load CS5.5 Projects Into Premier PRo Cs6 when they contain MTS files
Reg Santo Tomas May 14, 2012 4:37 PM (in response to TheMtyThor)Please make sure that CS6 is properly activated (requires online activation) so that the protected content will allow these codecs to import.
That is the only reason I can think of right now why you aren't able to relink these files.
Reg Santo Tomas
Premiere Pro QE
5. Re: Cannot Load CS5.5 Projects Into Premier PRo Cs6 when they contain MTS files
JSS1138 May 14, 2012 4:37 PM (in response to TheMtyThor)Did you try them in a new project? They still don't work even then?
6. Re: Cannot Load CS5.5 Projects Into Premier PRo Cs6 when they contain MTS files
TheMtyThor May 14, 2012 7:08 PM (in response to JSS1138)yes works in a new project whe selecting the proper Preset
7. Re: Cannot Load CS5.5 Projects Into Premier PRo Cs6 when they contain MTS files
TheMtyThor May 14, 2012 7:09 PM (in response to Reg Santo Tomas)i did properly activate, i see the registration on adobe site
8. Re: Cannot Load CS5.5 Projects Into Premier PRo Cs6 when they contain MTS files
TheMtyThor May 14, 2012 7:13 PM (in response to TheMtyThor)I have everything Activated properly, i can see the MTS files only if i Open a NEW Sequence. All the unlocked Presets are there, It just WONT open a CS5.5 project with Canon MTS files in it, i dont have this problem in After Effects CS6, MTS works fine in there. As far as i am concerned, i can use this work around just fine until Adobe Addresses the problem with CS5.5 Opening in CS6 Premier Pro
9. Re: Cannot Load CS5.5 Projects Into Premier PRo Cs6 when they contain MTS files
Reg Santo Tomas May 14, 2012 9:30 PM (in response to TheMtyThor)Just for clarification, are you unable to open the project at all or is it opening but not allowing you to import/relink the mts files?
Reg Santo Tomas
Premiere Pro QE
10. Re: Cannot Load CS5.5 Projects Into Premier PRo Cs6 when they contain MTS files
JSS1138 May 14, 2012 9:40 PM (in response to TheMtyThor)yes works in a new project
O-kaaay...then why is it not an option to finish current projects in the current version and only start new projects in the new version?
11. Re: Cannot Load CS5.5 Projects Into Premier PRo Cs6 when they contain MTS files
shooternz May 14, 2012 9:40 PM (in response to Reg Santo Tomas)For my clarification of the issue.
One has never been able to open a previous version project in a later version ...directly.
It usually / always asks if you want to save as a "NEW VERSION PROJECT" first.... and give one a save as option.
What was your workflow as regards opening a CS5.5 project in CS6?
Something I have never done cross versions is Import a previous version into a later version...so I have no idea if that ever worked or otherwise.
Importing and Opening are two very different things and would be handled differently by Premiere - I expect..
12. Re: Cannot Load CS5.5 Projects Into Premier PRo Cs6 when they contain MTS files
Wil Renczes May 14, 2012 11:53 PM (in response to shooternz)I'm thinking this isn't a project compatibility issue. This is the 2nd instance I've heard from users that Canon MTS files aren't working correctly in CS6. I believe QE's looking into the issue to see if they can repro.
Cheers
13. Re: Cannot Load CS5.5 Projects Into Premier PRo Cs6 when they contain MTS files
Todd_Kopriva May 15, 2012 1:35 AM (in response to Wil Renczes)Wil, I think that this may be the same issue that you heard about earlier, since Thor here is the person whose issue I alerted the team about earlier.
14. Re: Cannot Load CS5.5 Projects Into Premier PRo Cs6 when they contain MTS files
TheMtyThor May 15, 2012 2:19 AM (in response to Reg Santo Tomas)The CS5.5 Project Opens, but MTS Files are Shown as Off Line. Also For Clarification, I have ALWAYS been able to open a project containing MTS files from a previous version of Premiere to the New Version, there is a warning that says it will be saved in the New version format. thats Fine. here are my steps because apparently i am not being as clear as i think i am:
System Windows 7 x64
1.) installed CS6 from Disks provided from Adobe
2.) reboot
3.) Open a CS5.5 Premier Project, the systm asks to Convert it to CS6, i say YEs
4.) Unlike PREVIOUS versions, the MTS files in this former CS5.5 Now Saved as CS6 are shown as offline
5.) If i Add a NEW Sequence to the Former CS6 Project that uses the AVCHD Preset, i can then Relink MTS files
Without the New Sequence, the MTS files canot be imported nor can they be relinked, premiere pro CS6 complains that the file format is Unsupported
i hope that explanatino is clearer
15. Re: Cannot Load CS5.5 Projects Into Premier PRo Cs6 when they contain MTS files
shooternz May 15, 2012 3:19 AM (in response to TheMtyThor)I will test this with Panasonic mts files in the morning.
16. Re: Cannot Load CS5.5 Projects Into Premier PRo Cs6 when they contain MTS files
Jeff Bellune May 15, 2012 3:56 AM (in response to shooternz)Sony AVCHD files link automatically in the new CS6 project.
Jeff
17. Re: Cannot Load CS5.5 Projects Into Premier PRo Cs6 when they contain MTS files
billbuch May 15, 2012 6:06 AM (in response to TheMtyThor)CS6 has a comparable issue with mxf files, which adobe is aware of, and is working on.
18. Re: Cannot Load CS5.5 Projects Into Premier PRo Cs6 when they contain MTS files
TheMtyThor May 15, 2012 8:20 AM (in response to Jeff Bellune)If i Start a New project in CS6 premiere pro, i can also import MTS files normally, if i didnt already make that Abundantly clear
19. Re: Cannot Load CS5.5 Projects Into Premier PRo Cs6 when they contain MTS files
Reg Santo Tomas May 15, 2012 8:29 AM (in response to TheMtyThor)TheMtyThor,
Thank you for the clarification. I just wanted to make sure that I was following the proper trail.
I will check this out today and see if I can reproduce this issue as described.
Reg Santo Tomas
Premiere Pro QE
20. Re: Cannot Load CS5.5 Projects Into Premier PRo Cs6 when they contain MTS files
El_Plates Jul 24, 2012 9:16 PM (in response to shooternz)I'm in a similar jam.
So does the solution go as follows? : Open the Premiere Pro CS5.5 project in CS5.5 > save as > new version project > close Pp CS5.5 > then open the saved project in Pp CS6.
Is there a similar process for opening an After effects CS5.5 project in Ae CS6 ?
