I would like to add a Close button to my master slide that executes javascript: window.close().
Is there a way to do that with the button widget?
That option is not listed in the dropdown for this widget.
Interactive objects cannot currently be added to Captivate master slides. So you cannot do this with a normal button or click box either.
There is a Close button that can be added to the playback bar, but whether or not it will close your window depends on a number of factors.
As Rod told, the button widget is a static widget with limited functionalities, but I like it nevertheless because you can use it on master slides/question slides. Just an idea, didn't try it out:
Lilybiri
