1. Re: 3d Frame works in Flash ActionScript3.0
_spoboyle May 15, 2012 1:53 AM (in response to kiran1989)Stage3D is an API not a frame
Stage3D is very low-level and other 3D engines build on this to create an easier to use framework. This includes making it easier to do reasonably complicated features, including lighting, shadows, importing models etc etc
Strictly speaking you can use just Stage3D without any framework at all, however if you are doing anything slightly complicated you will end up writing your own framework.
I would recommend using a framework.
there are loads of frameworks out there you can take a look at. some are free other aren't, some have license agreements requiring you to include framework logos etc.
I'd recommend taking a look at Flare3D, and Alternativa
2. Re: 3d Frame works in Flash ActionScript3.0
kiran1989 May 15, 2012 2:22 AM (in response to _spoboyle)Dear Spoboyle,
Thanks for the reply. It Means with stage3d we can make and animate the 3d content in the flash right?.
I Think I was almost cleared. I was thinking about away3d frame work. so what is the difference in away3d, flare3d and alternativa3d.
Regards
kiran
3. Re: 3d Frame works in Flash ActionScript3.0
_spoboyle May 15, 2012 2:30 AM (in response to kiran1989)yes you can make and animate 3d content with stage3d although if you are going use stage3d without a framework it's going to be very hard and complicated.
tbh i have only ever used papervison3d (before stage3d came out) and i would not recommend it now.
recently I have been playing around with pure stage3d so i can understand what's happening low-level under the bonnet of these frameworks and believe me it's been fairly complicated getting even the basics working. in doing my research flare3d and alternativa have been the engines of choice by those that have been working with the frameworks.
perhaps you could read this which is probably better than anything i could give you
http://www.emanueleferonato.com/2011/02/14/flare3d-vs-away3d-in-the-creation-of-a-simple-g ame/
4. Re: 3d Frame works in Flash ActionScript3.0
_spoboyle May 15, 2012 2:31 AM (in response to _spoboyle)and here are some benchmarks tests if performance is important to you
5. Re: 3d Frame works in Flash ActionScript3.0
kiran1989 May 15, 2012 6:00 AM (in response to _spoboyle)Thanks spoboyle
