I currently (still) use InDesign CS4 and I am thinking about getting CS6 (using the Cloud). However, I use a LOT of scripts and I wonder if I can keep on using that scripts or not...
Basically, yes. Simply try it; if it works, it works. If it doesn't, either modify it (usually trivial) or make CS6 believe it's really CS4 by adding this line to your script:
app.scriptPreferences.version = 6;
(InDesign 6 is part of CS4).
Peter
Um...
Peter, that's really bad advice. That'll make any subsequent script which relies on CS5 or later features not work.
Either you should wrap that in a try/catch/finally, or use version folders.
Approach 1:
try{
// your script
}catch(err){
throw err;
} finally{
app.scriptPreferences.version = parseFloat(app.version);
Approach 2:
Create a folder in your scripts panel called "Version 6.0 Scripts", and place the script in that subfolder.
Ah, Harbs, you're absolutely right. I had forgotten that app.scriptPreferences.version is sticky (never use it myself.) Thanks.
Peter
