20 Replies Latest reply on Oct 14, 2015 9:01 AM by marthak38007292
    Dreamweaver cs6 doesn't start
    Misi Level 1
      hi,
      after installing dreamweaver cs6 form creative cloud test version i tried to start the programm.
      After a few seconds and a bumping icon in the dock (no splash screen), the icon disappered. and that was all. no dreamweaver.
      I already re-installed it. No change.
      Here some more information:
      MacBook Pro,  Mac OS X 10.7.4
      Dreamweaver CS6 is not installed on the system disk, but on a second harddrive.
      Flash CS6 is installed on this second harddrive too and it works. Dreamweaver does not.
      Adobe Web Premium CS5.5  is installed on system disk and it works.
      What is wrong with dreamweaver cs6 here?
      Mike
        • 1. Re: Dreamweaver cs6 doesn't start
          saurabhGupta1403 Level 2
          Well, dreamweaver should also work. However, try uninstalling it first and then try to reinstall it via Adobe Application Manager.
          you can remove the dreamweaver from here: "/Applications/Utilities/Adobe Installers/..."
          • 2. Re: Dreamweaver cs6 doesn't start
            Misi Level 1
            That was the first thing i tried :-)
            Uninstall and reinstall.
            but it didn't work.
            • 3. Re: Dreamweaver cs6 doesn't start
              Okay. It may be due to multiple drive problems and files sync problem. If possible, can you try out installing on the system drive. If not, then i will let someone from this team to help you out.
              -thanks.
              • 4. Re: Dreamweaver cs6 doesn't start
                PiyushGupta Adobe Employee
                You can try downloading from www.adobe.com/go/trydreamweaver/ and install that.
                • 5. Re: Dreamweaver cs6 doesn't start
                  Misi Level 1
                  Same problem on system drive. Icon bumping, no splashscreen, then icon disappears. dreamweaver does not start.
                  • 6. Re: Dreamweaver cs6 doesn't start
                    cueballjh
                    Same problem. Uninstalled, re-downloaded and re-installed. Tried this again by uninstalling, downloading Dreamweaver CS6 alone and re-installing.  Dreamweaver CS6 still does not launch.
                    Also installed Adobe Support Advisor, which says:
                    "Inspection could not identify any issues. Please contact Adobe Support for further assistance."
                    • iMac 2.93GHz Intel Core i7 - OS X 10.6.8
                    • CS6 Design & Web Premium installed in Applications folder on system drive
                    • No other applications running
                    • Drive permissions verified & repaired
                    Click on Dreamweaver icon to launch and it begins the normal bouncing, but simply disappears after a few seconds.
                    • 7. Re: Dreamweaver cs6 doesn't start
                      You can try launching after temporarily enabling root user on your machine. You can find steps to enable root user here:
                      http://support.apple.com/kb/ht1528
                      OR
                      You can simply launch Dreamweaver CS6 via root user instead of double clicking it:
                      Just open Terminal and type
                      sudo <PathToDreamweaver>/Contents/MacOS/<Dreamweaver>
                      This will resolve your problem if it is due to any incorrect permissions.
                      • 8. Re: Dreamweaver cs6 doesn't start
                        cueballjh Level 1
                        Launched it out of Terminal and got the following text:
                        2012-05-16 12:13:51.172 Dreamweaver[5496:e07] A system font, "LucidaGrande 13.00 pt. P [] (0xa8197d0) fobj=0xa819030, spc=4.11", is requested to be deallocated. Ignoring...
                        2012-05-16 12:13:51.173 Dreamweaver[5496:e07] A system font, "LucidaGrande 13.00 pt. P [] (0xa8197d0) fobj=0xa819030, spc=4.11", is requested to be deallocated. Ignoring...
                        ...at which point the Dreamweaver icon disappeared again.  Repeated the launch through Terminal and it stayed open.
                        After this I quit out of Dreamweaver and tried to launch with the standard method of clicking the app icon in Applications, but it would not launch.
                        EDIT: checked FontBook for font conflicts, of which there were none.  Lucida Grande also validated fine.
                        • 9. Re: Dreamweaver cs6 doesn't start
                          Misi Level 1
                          root user enabled. but dreamweaver did not open.
                          • 10. Re: Dreamweaver cs6 doesn't start
                            cueballjh Level 1
                            Root user also enabled here, but Dreamweaver would not open by clicking.  The method through Terminal did work, however.
                            • 11. Re: Dreamweaver cs6 doesn't start
                              Misi Level 1
                              next test: logged out my normal administrator account. logged in as root (new user). tried to start dreamweaver. dreamweaver started as it should. great!
                              BUT: logged out as root user. logged in my normal account. same behavior as before. dreamweaver would not start.
                              please help, adobe!
                              • 12. Re: Dreamweaver cs6 doesn't start
                                rimcrazyph
                                I am having the same issue.  I was able to start DW in a terminal shell using the sudo command stated above.  I got the following lines after it started:
                                2012-05-17 06:29:21.649 Dreamweaver[10927:9403] AdobeCrashReporterInitialize: Couldn't find the AdobeCrashDaemon.app folder
                                2012-05-17 06:29:24.268 Dreamweaver[10927:9403] CFURLCreateWithString was passed this invalid URL string: '/System/Library/Frameworks/' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
                                When I quit I got the same message as cueballjh with respect to LucidaGrande:
                                2012-05-17 06:31:12.242 Dreamweaver[10927:9403] A system font, "LucidaGrande 13.00 pt. P [] (0x12972ea0) fobj=0x129731b0, spc=4.11", is requested to be deallocated. Ignoring...
                                2012-05-17 06:31:12.243 Dreamweaver[10927:9403] A system font, "LucidaGrande 13.00 pt. P [] (0x12972ea0) fobj=0x129731b0, spc=4.11", is requested to be deallocated. Ignoring...
                                My installation was I started with CS5 Master Suite.  I used the Adobe Uninstaller and uninstalled all of CS5 Master Suite.  I then installed Master Suite CS6.  Everything appeared to install correctly.
                                • 13. Re: Dreamweaver cs6 doesn't start
                                  rimcrazyph Level 1
                                  I got my installation to work.  I used the Adobe Uninstaller and uninstalled DW.  I then went to disk utility and ran Fix Permissions on the system drive.  I rebooted and then did an install of DW and it worked.  Hope this helps.
                                  • 14. Re: Dreamweaver cs6 doesn't start
                                    Misi Level 1
                                    yes. my DW is working now, too.
                                    like rimcrazyph i ran fix permission after uninstallation DW.
                                    without reboot i installed DW as root-user, instead of normal administrator account.
                                    now it works.
                                    thanks.
                                    • 15. Re: Dreamweaver cs6 doesn't start
                                      cueballjh Level 1
                                      Fixed here as well.
                                      Uninstalled, repaired permissions as root user from Terminal, then also ran the installation as root user from Terminal.
                                      DW is now launching fine.  Thanks for all of the help!
                                      • 16. Re: Dreamweaver cs6 doesn't start
                                        c313ste
                                        I was having the same problem as you.
                                        It would run after installing as the root user, but not on my normal login.
                                        So AS ROOT USER: uninstalled it again, fixed permissions, reinstalled.
                                        Then as NORMAL USER it would start as normal.
                                        I'm about to pull my hair out!!!
                                        • 17. Re: Dreamweaver cs6 doesn't start
                                          Steven T Level 1
                                          I had the exact problem. And i
