Problem with Multiple Series - CFCHART
Guest
May 08, 2012 May 08, 2012
Using CF9, trying to create a simple chart with two series.  Problem is that when there are no values, CFCHART draws a line but with values of "0".
The first series is a set of monthly values (12 values) one for each month in 2011. The second series are also monthly values, but for 2012 YTD (Jan thru May 2012).  Range for all values is between 90 and 100, so I have it set to "scale" so you can see if year-over-year is better or worse.
Am trying to plot Series 1 (2011) on one line, and Series 2 on a second line.  This allows comparison of year-over-year results.  Have two QofQ, one that contains the twelve 2011 values, and one that contains the five 2012 monthly values.  X-Axis values are numbers (1-12 for 2011, and 1-5 for 2012).  However, I re-format the results using "CreateDate", so CFCHART can recognize a date, and format/display only the "months" on the chart (i.e., JAN, FEB, MAR....... DEC).   This is working, since bottom of chart shows JAN thru DEC.
The chart displays 2011 correctly with 12 points and a line.  But for 2012, it displays the 5 points (Jan-May) with their values, then displays Jun-Dec 2012 with values of ZERO.  So on the May 2012 plot, you have this big line that runs from 90% in May, down to 0% in Jun, then 0% for the rest of 2012.  I only want it to plot the 2012 line thru May.
If you remove the 2011 series from the CFCHART, it displays correctly, and only displays the 5 months in 2012 (Jan-May).   And if you remove the 2012 series, it displays correctly, with all 12 months in 2011.
I just need it to display exactly like that, when two CFCHARTSERIES are used.   Even if you <CFOUTPUT> the 2012 query, you get 5 items, Jan-May.  So not sure why it want to chart 12 items for 2012, with all ZEROs for June - Dec 2012.
Appreciate any help/advise on how to get year-over-year lines, with 12 data points for 2011 and 5 for 2012.
Gary
Advanced techniques
2.1K
Valorous Hero , May 15, 2012 May 15, 2012
You need to disable interpolation. However there is also a bug in some verisons.
     https://bugbase.adobe.com/index.cfm?event=bug&id=3042868
See here for a work-around:
     http://forums.adobe.com/message/3304324#3304324
Valorous Hero ,
Guest
May 16, 2012 May 16, 2012
Thanks, I found the solution doing a Google search, which led me to this Adobe forum link:
which is same one you mentioned.  I was so relieved it wasn't a problem with my code, I kept testing for errors, couldn't find any.
We are in the process of upgrading from CF7 to CF9.  We are developing on CF9, but still using CF7 in production, hopefully for only a few more weeks until we get our new CF/SQL Servers, running CF9.
Until then, have to write two versions of the .CFM file, one that runs on CF7 servers, and one for the CF9 test servers.
Thanks again for getting back, much appreciated.
Gary
Documentation
