4 Replies Latest reply: May 15, 2012 6:46 PM by MonkeyEatsMonkey RSS
    "Motion" effect missing on Multicam clips in CS6
    MonkeyEatsMonkey Community Member
      CS6 does not appear to have "motion" as an inherent effect on multicam clips.  Almost everything I shoot is multicam, and there are several instances where I like to clean up the framing of a shot in Premiere.  The "Motion" effect was always there for multicam clips in previous versions.  What gives, Adobe?
        • 1. Re: "Motion" effect missing on Multicam clips in CS6
          Jeff Bellune CommunityMVP
          I've gotten earlier versions of Pr into this state, but I can't reproduce it.  Try creating a new project, then importing the existing project into the new one.  Open up the problem sequence and see if the Motion effect shows up.
          Jeff
          • 2. Re: "Motion" effect missing on Multicam clips in CS6
            Just tried this, and no dice.  However, I did open an entirely separate project with a multicam sequence and the "motion" effect is there.  Any other ideas on how to get the effect back on the project I'm working on?
            • 3. Re: "Motion" effect missing on Multicam clips in CS6
              You need to realize that your project is corrupt at this point.  The following steps are what I would do to try and rescue it:
              1. In the corrupt project, create a new sequence that matches the old one.  Add a random clip to the new sequence and see if the Motion effect is there on the random clip.
              2. If so, then copy/paste the contents of the old sequence into the new one and hope for the best.
              3. EDIT: See if an auto-save version still has the Motion effect for that sequence.
              4. If that still doesn't work, then close and launch Pr, only hold down the Shift+Alt keys during launch until you see the welcome screen.  That'll reset your preferences and your plug-in cache.  Load the old project and see if the Motion effect is back.
              5. If that still doesn't work, then re-create the sequence and/or project.
              Jeff
              • 4. Re: "Motion" effect missing on Multicam clips in CS6
                Tried all of those, and still no luck.  But what I've now discovered is that further into the sequence the multicam clips all have Motion.  I was able to delete the clips in question and drag/trim the good clips into the empty space, then re-cut to the camera I was originally wanting.  Problem solved.  Thanks.
