7 Replies Latest reply on May 20, 2012 9:24 PM by bhargavi reddy
    AS3 Color Tweening
    MishaAbesadze
      Have Adobe simple Color Tweening code, like this caurina code : Tweener.addTween(myClip, {_color: 0x000000, time:1, transition:"easeOut"}); ?
        • 1. Re: AS3 Color Tweening
          bhargavi reddy Level 1
          As per my knowledge using colorTransform is the way to color tweening in as3.
          • 2. Re: AS3 Color Tweening
            MishaAbesadze Level 1
            That's nice. can you write here an example of this code ?
            • 3. Re: AS3 Color Tweening
              var myColor:ColorTransform = new ColorTransform();
              myColor.color = 0x000000;        //Here you can give the color whatever you want...
              myClip.transform.colorTransform = myColor;         //Here myClip is your object...
              • 4. Re: AS3 Color Tweening
                It's working perfect, but it has no tween effect. I mean color changing fastly, not ease. Is there some solution ? Thank you
                • 5. Re: AS3 Color Tweening
                  Sumit Agrawal FLash
                  Hi ,
                  U can use Tween Class To Ease,
                    please use this one
                  import fl.transitions.Tween;
                  import fl.transitions.easing.*;
                  var myTween = new Tween(myClip,'alpha',Strong.EaseIn,0,1,5,true);
                  • 6. Re: AS3 Color Tweening
                    Sumit Agrawal FLash
                    Hi
                    There is different between this two method. caurina tweener makess one color to other colo, for example 0X000000 to 0X333333.
                    Adobe tween removes one color and starts new color from null.
                    Here is en examples of this two clases :
                    Caurina Tweener:
                    Tweener.addTween(myClip, {_color: 0x333333, time:1, transition:"easeOut"});
                    Adobe Tween:
                              myColor.color = 0x333333;
                              myClip2.transform.colorTransform = myColor;
                              var myTween = new Tween(myClip2,'alpha',Strong.easeOut,0,1,3,true);
                    • 7. Re: AS3 Color Tweening
                      import flash.utils.Timer;
                      import flash.events.TimerEvent;
                      import flash.geom.ColorTransform;
                      var timer:Timer = new Timer(1000,0);
                      var arr:Array = [0x000000,0xff0000,0x00ff00,0x0000ff,0xffff00,0xff00ff,0x00ffff];
                      var carr:Array = [];
                      timer.addEventListener(TimerEvent.TIMER,changeColor);
                      timer.start();
                      function changeColor(e:TimerEvent):void
                      trace("timer");
                      var color:ColorTransform = new ColorTransform();
                      var num:Number = Math.floor(Math.random() * arr.length);
                      color.color = arr[num];
                      arr.splice(num,1);
                      mc.transform.colorTransform = color;
                      Try this code....
