Trying to go live on the web
Oct 25, 2006 Oct 25, 2006
Ok, I have CF7 installed with IIS as the web server on an XP box. I am also using a domain forward from Yahoo to my box. I can see the website on the my box only and when I try from another computer it says page can not be found. How can the forward just work on the box the site is on? Or is there another problem with the IIS CF setup. I am trying to do some final testing prior to hooking up with a web host so any help would be great.
I have search an read everything I can find on the forums and Web and nothing seems ot work.
Thanks in advance
Shane
Advanced techniques
348
Can you see a plain html file on your host computer over the Internet?
That would tell you if the problem is a global problem of your unusual
configuration or a CF problem.
If you can see the HTML, you should be able to see a CFML file if all
the web connectors are properly configured. The webconfig tool would
usually handle this.
Thanks for the reply Ian, I just tried this and the same error shows up so does that point to IIS or CF problems? Neither the .cfm or .htm shows up over the web on another computer.
Shane
Very unlikely its a CF problem, ColdFusion has nothing to do with .htm
pages.
Possibly an IIS problem.
But I would suspect most likely is that your computer isn't being
reached by the request. Can you confirm that when you ask for resources
on your computer the request is getting there?
How are you requesting information from your computer?
I was worried about that also. I am using a domain forward from Yahoo and that seems to work locally fine. I also pinged the DNS and Yahoo responds fine. But when I ping my IP on my local box it does not go through. Could it be something with the DSL line or my ISP being MSN? I am about to just move it all over to CrystalTech and forget the local problems.
Thanks again for helping.
Shane
The site is www.springsautoads.com if you want to try to access it.
Shane
I finally got a HTML page about South African Airways, but there where a
heck of a lot of redirects before I did. That could be the problem. I
suspect this is an issue with the way Yahoo is doing the redirection.
If you where to use the direct IP address of your box, not a DNS, does
that work better?
Hi Iam, I have tried this also and it does not work, I am getting an HTTP 500 error now which is an internal server error.
Not sure where ot go from here
Shane
Documentation
