1. Re: Stereo audio in left channel only.
the_wine_snob May 16, 2012 8:37 AM (in response to ForumCruiser)That is an odd problem, as the Master Audio in PrE is 2-channel (Stereo). Regardless of the input Audio Clips, they are mixed-down to 2-channel.
Can you give us details of your Audio on the Timeline, the files' specs., and which Audio Tracks they appear on?
A screen-cap of the Timeline, might be useful here.
Good luck,
Hunt
2. Re: Stereo audio in left channel only.
Steve Grisetti May 16, 2012 8:42 AM (in response to the_wine_snob)Also, are these videos recorded with an external microphone?
If your microphone is monaural (as most are), you'll only get audio on one channel. Then you just use the Fill Left or Fill Right Audio Effect to span it across both.
3. Re: Stereo audio in left channel only.
_techkid123_ May 17, 2012 5:45 PM (in response to ForumCruiser)Hi ,
Are you sure that when you import the clips they playback with the both the channel ,
first stretch the audio channel as shown in the image and use the effects in the audio as shown in the image.
try using the fill left or the fill right effect in premiere elements and then try to export the video.
Hope it Helps
Regards
4. Re: Stereo audio in left channel only.
ForumCruiser May 18, 2012 1:15 AM (in response to _techkid123_)Hi and thanks for all input.
Yes I use a mono mic, but the camera puts the sound on both channels.
When I play the timeline I hear the voice in both channels.
The timeline audio track shows waveforms on both channels.
Here is a pic of the timeline:
The project is corrupt somehow. I just tried creating a new project with the same video files and made a short flv out of it and it comes out OK.
I will try to redo this one which leads me to another question which I will post in another thread if not already answered.
Thanks for your input.
