11 Replies Latest reply on May 16, 2012 6:34 PM by Kevin Parrott
    Applescript: delete object from page
    ax1e2l_b3r4a5s6s Level 1
      I'm trying to remove an objects from a page with a known name.
      I've name the object theLine.  It's a drawn line.  Under certain conditions, I want to delete it.
      Other object is a placed graphic name theImage.  Under certain conditions, I want to delete it as well.
      Keep trying various iterations, but not even coming close.
        • 1. Re: Applescript: delete object from page
          Disregarding the object and focusing on the lines, i keep trying iterations of this, but to no avail:
          tell application "Adobe InDesign CS5.5"
                    set theTopRule to the graphic line "SolidSigLineTop"
                    set theBottomRule to the graphic line "SolidSigLineBottom"
                    if theSigLineCount = 2 and theSigMicroPrint = "Y" then
            delete theTopRule
            delete theBottomRule
                    end if
          end tell
          results in:
          error "Adobe InDesign CS5.5 got an error: Can’t get graphic line \"SolidSigLineTop\"." number -1728 from graphic line "SolidSigLineTop"
          • 2. Re: Applescript: delete object from page
            Kevin Parrott Level 2
            Hi
            does this work?
                delete (every graphic line of document 1 whose label is "SolidSigLineTop")
            end tell
            • 3. Re: Applescript: delete object from page
              No.  No error, but no deletion.
              Also tried
              delete (every graphic line whose label is "SolidSigLineTop")
              and
              delete (graphic line "SolidSigLineTop")
              Still not working.
              • 4. Re: Applescript: delete object from page
                try this
                    set myDoc to active document
                    tell myDoc
                        try
                            set AllGraphicLines to {"SolidSigLineTop", "SolidSigLineBottom"} as string
                            set myGraphicline to (every graphic line whose label is in AllGraphicLines)
                            delete myGraphicline
                        on error
                            display dialog "no graphic line/s with this name exists"
                        end try
                    end tell
                end tell
                • 5. Re: Applescript: delete object from page
                  got the display dialog error in the on error portion of the try statement!
                  Is the line I drew on the page not a graphic line?!?!?!??!??!
                  I guess the other option is that the name is not right.  I named the element under the layers, the same way I did with some Text Rectangles, etc.  Assumed that was right.
                  • 6. Re: Applescript: delete object from page
                    the script assumes that you have a line/stroke on your page and that the stroke is labled in "Script Label", (window/utilities/Script Label), as we
                    are looking for it's label   "every graphic line whose label is"  .
                    you say you've named the layer, very differnt.
                    to label your stroke, select it, open "window/utilities/Script Label"  enter your strokes name, deslect the stroke, run the script, works fine here
                    if you need to delete layers, let me no and ill alter the code for you.
                    kp
                    • 7. Re: Applescript: delete object from page
                      heres some code to delete specific layers
                          activate
                          tell myDoc
                              try
                                  set AllLayers to {"SolidSigLineTop", "SolidSigLineBottom"} as string
                                  set myLayer to every layer whose name is in AllLayers
                                  delete myLayer
                              on error
                                  display dialog "no layer/s with this name exists"
                              end try
                          end tell
                      end tell
                      • 8. Re: Applescript: delete object from page
                        I wasn't very clear - sorry.
                        I named the item under the layer.
                        Layer 1 in the layers window, expanded it, shows all the elements.
                        Named the items there.  In this case, renamed the reference to the line.
                        Then I can manipulate each element by it's name.
                        I've used this with text rectangles tons, and it works fine.  Never heard of the script label.  Must be different for lines?
                        • 9. Re: Applescript: delete object from page
                          ahh, i see, sorry, try this,  you need ot tell your doc to do what you need it ot do
                              activate
                              tell myDoc
                                  delete theTopRule
                              end tell
                          end tell
                          • 10. Re: Applescript: delete object from page
                            Wonderful.  Sorry about the lack of clarity.  Applescripting applications has me more than a little confused.  Works, of course, now that I explained it completely!
                            What is the reference for an object placed on the page??  (tiff file added using the place command)
                            I need to perform the same function to that object as well - possible deletion.
                            Thanks again.  This forum is EXCELLENT!
                            • 11. Re: Applescript: delete object from page
                              give this a spin
                                  activate
                                  tell myDoc
                                      delete theTopRule
                                      --delete graphic
                                      set PlacedImage to rectangle "TEST" -- the image is automatically place in a rectangle
                                      delete PlacedImage
                                  end tell
                              end tell
