Have Adobe simple Color Tweening code, like this caurina code : Tweener.addTween(myClip, {_color: 0x000000, time:1, transition:"easeOut"}); ?
As per my knowledge using colorTransform is the way to color tweening in as3.
That's nice. can you write here an example of this code ?
var myColor:ColorTransform = new ColorTransform();
myColor.color = 0x000000; //Here you can give the color whatever you want...
myClip.transform.colorTransform = myColor; //Here myClip is your object...
It's working perfect, but it has no tween effect. I mean color changing fastly, not ease. Is there some solution ? Thank you
Hi ,
U can use Tween Class To Ease,
please use this one
import fl.transitions.Tween;
import fl.transitions.easing.*;
var myTween = new Tween(myClip,'alpha',Strong.EaseIn,0,1,5,true);
Hi
There is different between this two method. caurina tweener makess one color to other colo, for example 0X000000 to 0X333333.
Adobe tween removes one color and starts new color from null.
Here is en examples of this two clases :
Caurina Tweener:
Tweener.addTween(myClip, {_color: 0x333333, time:1, transition:"easeOut"});
Adobe Tween:
myColor.color = 0x333333;
myClip2.transform.colorTransform = myColor;
var myTween = new Tween(myClip2,'alpha',Strong.easeOut,0,1,3,true);
import flash.utils.Timer;
import flash.events.TimerEvent;
import flash.geom.ColorTransform;
var timer:Timer = new Timer(1000,0);
var arr:Array = [0x000000,0xff0000,0x00ff00,0x0000ff,0xffff00,0xff00ff,0x00ffff];
var carr:Array = [];
timer.addEventListener(TimerEvent.TIMER,changeColor);
timer.start();
function changeColor(e:TimerEvent):void
trace("timer");
var color:ColorTransform = new ColorTransform();
var num:Number = Math.floor(Math.random() * arr.length);
color.color = arr[num];
arr.splice(num,1);
mc.transform.colorTransform = color;
Try this code....
