1. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
Gustavo Del Vechio May 7, 2012 9:32 AM (in response to medgno_43)Hi medgno_43
Just for confirmation. The build is installed on your machine is the official Illustrator CS6 trial that Adobe made avaliable for download today at this page: http://www.adobe.com/cfusion/tdrc/index.cfm?product=illustrator&loc=en_us ?
Did you try to trash preferences or reinstall Illustrator CS6? Does the problem persist?
Best Regards
Gustavo.
2. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
medgno_43 May 7, 2012 9:47 AM (in response to Gustavo Del Vechio)I didn't install the version from that link, but I did install the official release of CS6 Web and Design Premium, and the application version is 16.0.0. I both trashed the CS6 preferences and reinstalled Illustrator CS6, and I get the same error message.
3. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
Larry G. Schneider May 7, 2012 10:25 AM (in response to medgno_43)Do you have any whiteboard software installed? I think I remember this as being the culprit.
4. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
RAILhead May 8, 2012 5:32 AM (in response to medgno_43)I am having the same issue. I bought the CS6 Standard Suite Upgrade, and Illustrator gives me the exact same dialog, then quits.
5. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
Nick320 May 9, 2012 2:48 PM (in response to RAILhead)I'm having exactly the same issue. Cannot do anything to solve it. All the other CS6 programs work but not Illustartor. I installed it from the Design Premium CD I was sent by Adobe. Any ideas anyone?
6. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
Gustavo Del Vechio May 9, 2012 3:27 PM (in response to Nick320)Hi
I´ll forward this post to an engineer from Adobe Illustrator Team. Will ask about this problem.
Thank you for bringing this issue. Expect to receive answers soon.
Best Regards
Gustavo.
7. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
Gustavo Del Vechio May 10, 2012 4:44 AM (in response to Gustavo Del Vechio)Hi Friends
I´m in contact with an engineer from Adobe Illustrator Team.
Could you please tell us if the SMART Product Drivers 10.6 are installed on your systems? http://smarttech.com/us/Support/Browse+Support/Support+Documents/KB3/146595.aspx
Also...could you please tell us if it happens to old Illustrator version?
This info will help the engineer to find the problem.
Thank you a lot
Gustavo.
9. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
Gustavo Del Vechio May 10, 2012 7:38 AM (in response to Nick320)Hi Nick
This is a note from the engineer:
"Launch terminal window on your Mac and type in ulimit. If you get anything other than unlimited you should change it back to unlimited. There are plenty of web resources that you can use to find out more about this command and how to change it or you can ask on one of the MAC forums.
If you see the value unlimited and still see the error you should report back the bug to Adobe: https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Gustavo.
11. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
Gustavo Del Vechio May 10, 2012 9:26 AM (in response to Nick320)Hi Nick
Thank you
Your form is already with the engineers.
Thank you a lot
Best Regards
Gustavo.
12. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
Ian Kelleigh May 11, 2012 3:09 PM (in response to medgno_43)Having the same issue from a fresh install today from the Creative Cloud. I don't have any SMART driver software installed and ulimit shows unlimited for me as well.
13. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
Ian Kelleigh May 15, 2012 1:36 PM (in response to Ian Kelleigh)Is there an ETA on this? Thanks.
14. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
amcoWork May 16, 2012 8:29 AM (in response to medgno_43)I'm having this exact problem with my newly downloaded Illustrator CS6. It worked all day yesterday, and today I have this message. Tried all the terminal commands as instructed above and no change.
CS 5.1 is working fine.
Any update on this issue is much needed.
15. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
AshutoshChaturvediMay 17, 2012 2:05 AM (in response to amcoWork)
Create a new user accunt on your mac login using the newly created user and see if it changes things for you. Make sure you also have the latest OS updates installed on your mahine
16. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
Ian Kelleigh May 17, 2012 7:38 AM (in response to AshutoshChaturvedi)Yes, when launching Illustrator CS6 under a new user account, it runs fine. But how do I get it to run with my real account?
17. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
AshutoshChaturvediMay 17, 2012 9:02 PM (in response to Ian Kelleigh)
Hi Ian,
Glad to see it works for you.
I reccomended a new user account to remove few variables. I have tried this on numerious occasions when I see something weird happening only for me. If it runs fine under new account that means you need to review one of the softwares in your startup or some MAC OS settings. Troubleshooting this may take lot of time, If you are short on time maybe you should just copy files from the old account and start using the new one.
-- All the best
18. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
Nick320 May 18, 2012 4:26 AM (in response to AshutoshChaturvedi)Hi guys
Just to let you know. I just updated the OS (to 10.7.4) and now it works! I've done nothing else. I'll let you know if it keeps working.
Hope that works for you.
19. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
creative_nick May 18, 2012 5:48 AM (in response to medgno_43)I also encountered this issue on MAC OSX 10.7. I tried many hit and trials and finally found a way to launch Ai, though it is just a workaround. I followed these steps:
1. I created shell script which can launch Ai. You can download this shell script from the location: http://dl.dropbox.com/u/47167182/launchAI.command.zip.
2. Unzip the folder and drag the launchAI.command file into your dock area. (Please verify the application path, since I have installed AICS6 on default location)
3. Click launchAI.command icon in the dock.
4. A terminal will appear asking your user password, enter your password to see if AI launches successfully.
5. If you don't like typing password for each run, you can edit /etc/sudoers file to add a line "%staff ALL=(ALL) NOPASSWD: ALL" . (Replace staff with your user's group name).
Please see if this workaround also works for you.
All the best!
20. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
Ian Kelleigh May 18, 2012 6:56 AM (in response to AshutoshChaturvedi)ADBEDesigner, do you have any suggestions on where to start looking for software that would modify this max open files option? My OS is the latest version (10.7.4).
Thanks.
21. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
AshutoshChaturvediMay 18, 2012 6:57 AM (in response to Nick320)
@Nick320: Even reinstalling 10.6 would have worked or just creating a new account. Most of these issues impacting few users are related to OS settings.During the course of our working we install many softwares and few of these even change the default settings at times we also change settings that we do not recall changing.
22. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
Ian Kelleigh May 18, 2012 7:00 AM (in response to creative_nick)Creative_nick, that script works perfectly. That's really strange, what is different about how this is being launched versus just launching the app normally? BTW, during launch I get this error in the terminal window:
2012-05-18 06:57:59.647 Adobe Illustrator[69428:3e03] CFURLCreateWithString was passed this invalid URL string: '/System/Library/Frameworks/' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
2012-05-18 06:58:22.879 CS6ServiceManager[69443:a03] *** CFMessagePort: bootstrap_register(): failed 1100 (0x44c) 'Permission denied', port = 0x1d03, name = 'com.adobe.csi.CSServiceManager.3'
See /usr/include/servers/bootstrap_defs.h for the error codes.
23. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
AshutoshChaturvediMay 18, 2012 7:16 AM (in response to Ian Kelleigh)
Ian: is is very difficult to pin point the software that would have modified it. I suggest you should have a look at all applications or hardware installed and most likely culprit could be products that deal with databases, network operations or file management systems. Cant really tell as we do not have this issue at computers at our office.
24. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
creative_nick May 18, 2012 8:27 AM (in response to Ian Kelleigh)Ian,
This all is related to permissions that are avaialable to the process. When you launch the app with terminal (with the script that I provided), AI is invoked through shell and inherits the shell quota. It also gets sudo permissions so that AI is now able to change the limit of number of open files.
25. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
creative_nick May 18, 2012 8:31 AM (in response to Ian Kelleigh)CS6ServiceManager[69443:a03] *** CFMessagePort: bootstrap_register(): failed 1100 (0x44c) 'Permission denied', port = 0x1d03, name = 'com.adobe.csi.CSServiceManager.3'
Ian, Did you deny participating in Adobe PIP (Product Improvement Plan)? I have seen such an error in that case.
26. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
creative_nick May 18, 2012 8:35 AM (in response to Ian Kelleigh)do you have any suggestions on where to start looking for software that would modify this max open files option? My OS is the latest version (10.7.4).
@Ian: Please look for files /etc/launchd.conf, $HOME/.launchd.conf or /etc/sysctl.conf. These are the common files where the limit may exist.
27. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
Ian Kelleigh May 18, 2012 9:02 AM (in response to creative_nick)Thanks Nick. I couldn't find any of these files (and yes I knew to make sure the system files were visible to search in them). In the mean time I will keep using your script solution right now. It works and that's all I wanted. Cheers!
28. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
SVGFOTO May 18, 2012 10:31 AM (in response to Gustavo Del Vechio)Hi,
I had the same problem after upgrading from CS5 to CS6. I found this solution: http://www.smarttech.com/us/Support/Browse+Support/Support+Documents/KB3/146595.aspx
This solved my problem
29. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
ergon_g May 21, 2012 4:24 AM (in response to creative_nick)The solution with the shell script works perfectly.
30. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
rubenantonio1 May 22, 2012 10:51 PM (in response to ergon_g)Script works, however it appears it's required to run everytime to open Illustrator. Is that correct?
31. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
amcoWork May 23, 2012 3:28 PM (in response to medgno_43)I really really really REALLY hope that Adobe is paying attention to this issue.
I've now had this issue happen intermintantly on two different computer, neither of which have ever had the SMART software installed on them and neither that appear to to have the launchd.conf or sysctl.conf (unless I'm missing some kind of setting to reveal this files, but I doubt it as I'm going through terminal on an admin account).
One of the computers is essentially a totally clean instal with nothing on it other than MS Office and Adobe CS 6.
Thankfully the script Nick made is working, but its crazy to have to resort to this.
32. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
AshutoshChaturvediMay 23, 2012 9:06 PM (in response to amcoWork)
@amco: create a new user account and run Ai after logging into it. does it work. At times we think our machines are clean but softwares do get installed on our machines e.g unknown ones like device drivers or known ones like MS office. One thing is however certain Adobe enginers did not enocounter this before they shipped it.
33. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
RAILhead May 24, 2012 6:27 AM (in response to creative_nick)The script launches Illustrator just fine.
I had this issue when I first installed CS6, but after a restart, Ai started working normally. I go to launch it today, and I get the error at startup again. BUT, this screipt works -- now Adobe just needs to figure out what's going on instead of putting the brunt of the work on us. CS5 Ai works just fine. I don't -- and never have -- had Smart installed, nor any app like it.
34. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
RAILhead May 24, 2012 6:36 AM (in response to RAILhead)I receive the following Terminal error when I use the script:
2012-05-24 08:34:34.189 Adobe Illustrator[56601:3e03] CFURLCreateWithString was passed this invalid URL string: '/System/Library/Frameworks/' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
2012-05-24 08:34:38.874 CS6ServiceManager[56607:a03] *** CFMessagePort: bootstrap_register(): failed 1100 (0x44c) 'Permission denied', port = 0x1d03, name = 'com.adobe.csi.CSServiceManager.3'
35. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
RAILhead May 31, 2012 10:40 AM (in response to RAILhead)No word from Adobe on this?
36. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
Ian Kelleigh Jun 4, 2012 6:23 PM (in response to Ian Kelleigh)Strangly enough, the problem seems to have fixed itself at some point. Maybe after a restart, not really sure. But my preferences were all reset which is fine, but now I don't have to use that terminal command.
37. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
IvanDavidJun 14, 2012 3:38 AM (in response to Ian Kelleigh)
Thought I'd consolidate the useful replies to the OP, and add the inputs I've received form the Illustrator Engineering team.
On Mac OS, Illustrator usually launches with normal user account permissions (non-privileged). To maximize performance, Illustrator tries to increase the maximum number of files to be opened. Mac OS does not restrict or limit Illustrator from increasing the maximum number of files that can be opened. However, a system administrator or third party software may place such restrictions on the maximum number of files that can be opened by a process, by adding a system preference to configuration files.
When such a file limit setting is enforced, a process like Illustrator that is starting with normal user account permissions fails to launch.
The possibility of such a system preference being added to your configuration files is higher if you have installed SMART Product Drivers 10.6 (See KB article http://www.smarttech.com/us/Support/Browse+Support/Support+Documents/KB3/146595.aspx). But, here's a procedure to isolate and fix the problem even if it is not SMART product drivers that tweaked this system preference.
You need to first check for the file limit system preference, and then try solution 1 or 2.
Check if your computer has this system preference:
- Check if these files exist in your system:
• /etc/launchd.conf,
• $HOME/.launchd.conf
• /etc/sysctl.conf. - If you find any of the files listed above, check for a setting like:
limit maxfiles
Solution 1: If the system preference exists on your computer:
- Create a backup of the file that contains the file limit setting
- Open the file with editing permissions. For example, sudo vim <filepath>
- Find the line that contains the setting, and delete it by pressing dd.
- Save the file and press !wq to quit vim.
- Reboot and launch Illustrator CS6.
- If the error persists, there is a chance that this setting is being enforced from a different location. Perform the actions outlined in Solution 2.
Solution 2: If the system preference does not exist on your computer:
- Download the shell script attached with this reply.
- Unzip the file, and drag the launchAI.command file into your dock area. Do verify the application path; the command file assumes that Illustrator CS6 is installed at the default location.
- Click launchAI.command.
- In the terminal that appears, enter your user password, and check if Illustrator CS6 launches successfully.
If you don't like typing your password every time you launch Illustrator:
- Open the /etc/sudoers file in editing mode.
- Add the following line to the file:
- Replace staff with your user's group name.
launchAI.command.zip 242 bytes
38. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
brtdv Jun 15, 2012 12:41 AM (in response to IvanDavid)Ivan David,
We know how to work around the issue, and launch illustrator with a shell script as root user. But that is merely a workaround and does not fix the issue...
Fact is that under my normal user account, I have NO file limit setting of any kind:
bert@bertbookpro ~> ulimit unlimited
But still I get the error message displaying the "Unable to set maximum number of files to be opened" error, while I have no files that exists where the ulimit setting could be present:
bert@bertbookpro ~> cat /etc/launchd.conf cat: /etc/launchd.conf: No such file or directory bert@bertbookpro ~> cat ~/.launchd.conf cat: /Users/bert/.launchd.conf: No such file or directory bert@bertbookpro ~> cat /etc/sysctl.conf cat: /etc/sysctl.conf: No such file or directory
(which means that this solution also does not work)
THAT is the core problem, so there has to be a real solution to this instead of a workaround, so I can run Illustrator under my normal user account...
39. Re: "Unable to set maximum number of files to be opened" in CS6 trial, CS5 runs fine
Ian Kelleigh Jun 15, 2012 6:50 AM (in response to brtdv)I know. I almost feel like installing then uninstalling those drivers to see if that fixes it because right now I don't have any of those files sitting around.
