Robohelp 9 with webhelp output.
Anyone know how I can use the skin editor (or other options) to achieve the following:
I would like to completely remove the hide "X" in the TOC pane. I don't need this functioanlity.
I would like the highlight of the selected TOC item to extend horizontally to fill the entire TOC pane.
I would also like to remove the vertical line between the TOC pane and the topic pane.
Thanks...
Hi there
You might want to download a copy of my Skinny on Skins file. It documents much of what you want to accomplish.
Click here to view the download page
Cheers... Rick
thanks... i downloaded both files and all I am getting is this...
lots of TOC, but no content.
nevermind.... i did the unblock in properties.
I did accomplish a few things, but a few still outstanding....
Can I extend the TOC highlight to the full with of the navigation pane?
Can I get rid of the border for Glossary, Search, and Print(see below)? I did remove it, following your instructions for Contents(see above).
Thanks again...
Can anybody help re: the above?
See if this helps.
http://forums.adobe.com/message/3665680#3665680
But this part...
To change the color of the bar that is above your TOC and below your Contents, Index and Search buttons:
Two lines below that, change the <color> tag to the color you want (probably the background color of your TOC). For example, <color>background:#FFFFFF</color> makes this bar white.
...does not work...
Maybe try asking in that thread in the hope the person who posted the solution can assist you.
