Could this be a bug within adt.jar?
When running the adt.jar java app as an ant task within Flash Builder 4 I get the following error:
Filename contains restricted character '\': C:\libraries\the\path\to\the\file\directory\FMODAirN
Every single property expanded within the <java> ant task with the exception of ane.target.platform includes ${basedir} which evaluates to C:\libraries\the\path\to\the\file\, yet only the last parameter in the argument list for adt.jar complains regarding a restricted character:
ane.extension.descriptor=${basedir}/directory/extension.xml
ane.keystore=${basedir}/directory/test.p12
ane.src.library=${basedir}/directory/library.swf
ane.target.platform=Windows-x86
ane.project.name=${basedir}/directory/air.fmod.ane.ane
ane.swc.name=${basedir}/directory/air.fmod.ane.swc
native.library=${basedir}/directory/FMODAirNativeExtension.dll
<target name="default" depends="clean, init">
<java jar="${FLEX_HOME}/lib/adt.jar" fork="true">
<arg value="-package"/>
<arg value="-tsa"/>
<arg value="none"/>
<arg value="-storetype"/>
<arg value="pkcs12"/>
<arg value="-keystore"/>
<arg value="${ane.keystore}"/>
<arg value="-storepass"/>
<arg value="test"/>
<arg value="-target"/>
<arg value="ane"/>
<arg value="${ane.project.name}"/>
<arg value="${ane.extension.descriptor}"/>
<arg value="-swc"/>
<arg value="${ane.swc.name}"/>
<arg value="-platform"/>
<arg value="${ane.target.platform} ${ane.src.library}"/><!--missing library error if ${ane.src.library} is on its own line-->
<arg value="${native.library}"/><!--Filename contains restricted character '\': C:\libraries\the\path\to\the\file\directory\FMODAirN-->
</java>
</target>
<arg value="-tsa"/>
<arg value="none"/>
<arg value="test"/>
<arg value="ane"/>
<arg value="-swc"/>
<arg value="-C"/>
<arg value="C:/libraries/the/path/to/the/file/directory/FMODAirNativeExtension.dll"/><!--Filename contains restricted character '\': C:\libraries\the\path\to\the\file\directory\FMODAirN-->
</java>
</target>
Any help would be appreciated!
Asking one of our ADT experts to see if they've seen this before. You might also want to cross post this over on the Flash Builder forums.
Thanks, Chris.
I'll do that as well
Heard back from our ADT guy and he doesn't believe it's an ADT specific problem. We run ADT tests daily on Windows and he's never seen this error before. He suggests you try to find the full path and run the command from the command line directly to see if the error still occurs.
