2 Replies Latest reply: May 20, 2012 6:18 PM by Phinehas1234 RSS
    Remove url parameter
    Phinehas1234 Community Member
      Hi All,
      I have a page it contains some url parameters. When I submit this page, url parameters will also be submitted.
      After submission, action page encounters some error because of isDefined("url.XXX").
      Therefore, is it possible to remove "url.XXX" in action page so that isDefined("url.XXX") will remain return false?
        • 1. Re: Remove url parameter
          Adam Cameron. Community Member
          If you don't want things in the URL scope... don't pass parameters in the query string.
          Or alter your logic from simply:
          isDefined("URL.XXX")
          to include the additional criteria that you wish to consider, eg:
          if (!someCriteriaThatMakesTheURlParamIrrelevant){
               if (isDefined("URL.XXX")){
                    // some stuff
          }else{
               // some other stuff
          NB: isDefined() is a bit of a legacy and someonwhat imprecise function.  You're better off using structKeyExists().
          Adam
          • 2. Re: Remove url parameter
            Spend much time on solving it. Finally, I can remove the parameter in query string successfully.
