Hello,
We are in the process of upgrading some of our PC's currently running Flash player versions 9 and 10 to version 11. We are going to push this out via SCUP to all workstations with in our environment. The issue we have is that when we install version 11 it is not removing the old version from the workstations.
Is there a way to get the flash player 11 MSI to remove the older versions of flash player when it installs version 11 or will we need to pull the old versions out manually after version 11 is installed?
Cheers
Joe
Hi Joe,
From what I understand, the MSI should do an uninstall first automatically. Unfortunately, I don't have any experience with SCUP/SCCM so I don't have much more to add. I suspect you'll find more info with a few Google searches or maybe another admin will reply back.
Chris
I assume that you know about the Admin Guide http://www.adobe.com/devnet/flashplayer/articles/flash_player_admin_guide.html
I also do not know much about SCUP; is there a way that you could incorporate the executable uninstaller (http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows.html) as a first step of the upgrade process?
Hey Guys,
Thanks for replying.
I’m thinking I should be able to push a vb script to uninstall the older versions out via SCCM or I could use the uninstaller (if it can be targeted to get rid of one version and leave another).
Either way it shouldn’t be to hard.
Cheers
The uninstaller will uninstall all installed Flash Player versions.
