Hi guys,
I have inDesign CS 5 for Mac and i want to print my document (130 pages) on double sides of the letter paper. However, my printer doesn't do double sided printing so I have to print all odd pages at once, then flip the paper over and print the even pages.
Can anyone please tell me how I can go about doing that without selecting every individual page, and clicking print 130 times?
Appreciate it!!
Duplex printing is the printer specfic feature , so if your printer supports it check the duplex print option in the printer preferences and then check
If your printer doesn't support it then forget it.
In the print dialog box, you should be able to select a "sequence" setting of either all odd page or all even pages.
There's also a checkbox for printing in reverse order. I haven't had to do this in quite a while, but I seem to remember that if you print the even pages first, and in reverse, you can place the stack back in the printer for the second pass to print the odd pages, and it will be stacked correctly when you're done.
"Reverse order" is sort of confusing. At initial thought, i thought it's printing from last page to first page instead of first page to last page, thus the term "reverse order"
That's what it does. You can do a test if you like. Make a document of 4 pages with just a page number on each. Print the evens first in reverse, flip the stack over and print the odds in regular order.
Will this work if i have my pages sectioned off and starting from page 1 for each section? Basically i just want to print every other page, regardless of my page number.
