21 Replies Latest reply on Jul 17, 2012 2:22 AM by briano.de.rhino
    cannot install cs6 pb!!!!
    leslie wand Level 2
      hi,
      this is turning into a nightmare. cannot install cs6.
      sys: i7 / 920 / 12gb ram / gtx 550ti (always current drivers) / bm intensity pro - win7 / sp1 / 64bit
      ran setup
      all seemed ok till asked to insert 2nd disk. at which point error message said to restart and try again.
      on second try there was no longer any cs6 folder on the first disk just the following folders:
      cs6 speech anal models
      encore cs6 functional content
      premiere cs6 functional content.
      tried installing direct from the premiere folder set up and received the following error message:
      Exit Code: 7
      Please see specific errors and warnings below for troubleshooting. For example,  ERROR: DW050, DW062 ...
      -------------------------------------- Summary --------------------------------------
      - 0 fatal error(s), 2 error(s), 0 warning(s)
      ----------- Payload: {614020C8-2E16-4E16-A5F0-04DE2AB96097} Adobe Premiere Pro CS6 Functional Content 6.0.0.0 -----------
      ERROR: DW062: Unable to locate folder for token SharedDocuments
      ERROR: DW050: The following payload errors were found during install:
      ERROR: DW050:  - Adobe Premiere Pro CS6 Functional Content: Install failed
      tried a couple more times - same result. what's going on!?
      thanks
      5th try:
      Exit Code: 7
      - 0 fatal error(s), 72 error(s), 0 warning(s)
      ----------- Payload: {DE88AA40-6766-43D3-A755-8FC374B3D2C3} DynamiclinkSupport 6.0.0.0 -----------
      ----------- Payload: {539AEF15-3A2B-4A31-A587-7E90F7D9C700} Camera Profiles Installer 7.0.0.0 -----------
      ----------- Payload: {8706963D-5F48-47CC-998B-DAB70B089DB8} Suite Shared Configuration CS6 3.0.0.0 -----------
      ERROR: DW050:  - Adobe Bridge CS6 (64 Bit): Install failed
      ERROR: DW050:  - AdobeColorVideoProfilesAE CS6: Install failed
      ERROR: DW050:  - Dynamic Link Media Server: Install failed
      ERROR: DW050:  - CS6 Production Premium: Install failed
      ERROR: DW050:  - Adobe XMP Panels: Install failed
      ERROR: DW050:  - AdobeColorCommonSetCMYK CS6: Install failed
      ERROR: DW050:  - AdobeColorEU CS6: Install failed
      ERROR: DW050:  - Adobe Encore CS6_AdobeEncore6en_USLanguagePack: Install failed
      ERROR: DW050:  - SonicWrappers_ph: Install failed
      ERROR: DW050:  - Adobe Flash CS6_AdobeFlash12.0-en_USLanguagePack: Install failed
      ERROR: DW050:  - Adobe Prelude CS6 Support: Install failed
      ERROR: DW050:  - Adobe Photoshop CS6 Support: Install failed
      ERROR: DW050:  - AdobePDFL x64 CS6: Install failed
      ERROR: DW050:  - AdobeColorJA CS6: Install failed
      ERROR: DW050:  - Adobe Hunspell Linguistics Plugin CS6 x64: Install failed
      ERROR: DW050:  - SonicWrappers_bl: Install failed
      ERROR: DW050:  - Adobe Audition: Failed due to Language Pack installation failure
      ERROR: DW050:  - Adobe Photoshop CS6 Core_x64: Failed due to Language Pack installation failure
      ERROR: DW050:  - Adobe Player for Embedding 3.3: Install failed
      ERROR: DW050:  - Adobe CSXS Infrastructure CS6: Install failed
      ERROR: DW050:  - Adobe SpeedGrade CS6: Failed due to Language Pack installation failure
      ERROR: DW050:  - AdobeColorNA CS6: Install failed
      ERROR: DW050:  - Adobe Premiere Pro CS6: Failed due to Language Pack installation failure
      ERROR: DW050:  - Adobe Prelude CS6_AdobePrelude1en_USLanguagePack: Install failed
      ERROR: DW050:  - Adobe Encore CS6: Failed due to Language Pack installation failure
      ERROR: DW050:  - AdobeMotionPicture CS6: Install failed
      ERROR: DW050:  - Adobe After Effects CS6: Failed due to Language Pack installation failure
      ERROR: DW050:  - AdobeColorPhotoshop CS6: Install failed
      ERROR: DW050:  - Adobe Flash CS6: Failed due to Language Pack installation failure
      ERROR: DW050:  - Camera Profiles Installer: Install failed
      ERROR: DW050:  - AdobePDFL CS6: Install failed
      ERROR: DW050:  - Photoshop Camera Raw 7 (64 bit): Install failed
      ERROR: DW050:  - Adobe SpeedGrade CS6_AdobeSpeedGrade6.0en_USLanguagePack: Install failed
      ERROR: DW050:  - Required Common Fonts Installation x64: Install failed
      ERROR: DW050:  - AdobeColorVideoProfilesCS CS6: Install failed
      ERROR: DW050:  - Adobe WinSoft Linguistics Plugin CS6 x64: Install failed
      ERROR: DW050:  - PDF Settings CS6: Install failed
      ERROR: DW050:  - Recommended Common Fonts Installation x64: Install failed
      ERROR: DW050:  - Adobe Extension Manager CS6: Install failed
      ERROR: DW050:  - Suite Shared Configuration CS6: Install failed
      ERROR: DW050:  - Adobe Player for Embedding x64 3.3: Install failed
      ERROR: DW050:  - Adobe WinSoft Linguistics Plugin CS6: Install failed
      ERROR: DW050:  - Adobe Bridge CS6: Install failed
      ERROR: DW050:  - Adobe After Effects CS6 Support: Install failed
      ERROR: DW050:  - AdobeCMaps x64 CS6: Install failed
      ERROR: DW050:  - Microsoft Visual C++ 2005 Redistributable Package (x64): Install failed
      ERROR: DW050:  - AdobeTypeSupport CS6: Install failed
      ERROR: DW050:  - Adobe Audition_AdobeAudition5en_USLanguagePack: Install failed
      ERROR: DW050:  - AdobeTypeSupport x64 CS6: Install failed
      ERROR: DW050:  - Adobe Mini Bridge CS6: Install failed
      ERROR: DW050:  - Adobe Linguistics CS6 x64: Install failed
      ERROR: DW050:  - AmericanEnglishSpeechAnalysisModels: Install failed
      ERROR: DW050:  - AdobeColorCommonSetRGB CS6: Install failed
      ERROR: DW050:  - Adobe Premiere Pro CS6 Support: Install failed
      ERROR: DW050:  - Adobe SwitchBoard 2.0: Install failed
      ERROR: DW050:  - Photoshop Camera Raw 7: Install failed
      ERROR: DW050:  - Adobe Premiere Pro CS6_AdobePremierePro6.0en_USLanguagePack: Install failed
      ERROR: DW050:  - AdobeHelp: Install failed
      ERROR: DW050:  - Adobe After Effects CS6_AdobeAfterEffects11en_USLanguagePack: Install failed
      ERROR: DW050:  - Adobe Encore CS6 Support: Install failed
      ERROR: DW050:  - Adobe Linguistics CS6: Install failed
      ERROR: DW050:  - DynamiclinkSupport: Install failed
      ERROR: DW050:  - Adobe Prelude CS6: Failed due to Language Pack installation failure
      ERROR: DW050:  - Adobe Photoshop CS6 International English Language Pack_x64_AdobePhotoshop13-en_GB_x64: Install failed
      ERROR: DW050:  - Adobe After Effects CS6 Presets: Install failed
      ERROR: DW050:  - AdobeCMaps CS6: Install failed
      ERROR: DW050:  - Adobe CSXS Extensions CS6: Install failed
      ERROR: DW050:  - Adobe ExtendScript Toolkit CS6: Install failed
      ERROR: DW050:  - Adobe Media Encoder CS6 X64: Install failed
      System Requirements
      getting to be beyond a joke ;-( at least vegas loads!
