Hi
I am publishing an output in the Webhelp layout.
The dialog box that appears on clicking the standard Search button is not getting resized when I decrease the search pane.
I have attached the screenshot for your reference. Please help.
Sreekanth
Use the camera icon to put screenshots in your post using the web interface – attachments get stripped off
Ummm, Jeff?
There was an image in the post? I see it.
Cheers... Rick
Yes, I saw that one too, but it looked like there was two more in there that didn’t come through. Also, the first shot only sort of set up the question – it didn’t show the issue as far as I could tell…
Unless I'm mistaken, the OP dislikes the fact that some of the content is disappearing?
Cheers... Rick
Much keener eyes on you Rick! ;>)
Thanks Rick. Will take care of it next time.
Like a lot of stuff on the web, there is a minimum size below which an object cannot display properly.
Sorry Peter, I did not understand what exactly you mean by "minimum size" here. Can you please explain?
Simply a size below which something cannot be displayed nicely. A bit like trying to wear a shirt that is two sizes too small, it ain't going to look pretty.
But is it impossible to increase the size of that window? May be a file that can be edited to resize it after publishing?
This thread started with a problem about when the pane is downsized. If you want it increased by default, that's a different matter. Visit http://www.robowizard.com and download the Skinny on Skins. How is covered there.
