Welcome to the forum.
What editor? Are you using RH HTML or RH for Word as both can
produce webhelp? Sounds like RH HTML but just confirm that.
In RH HTML, there is no concept of tabs in the way Word uses
them so how are you creating them, if that is the editor you are
using?
If you are going to generate printed output as well I would
caution against playing with bullets. You will need to do that from
the css style sheet and it can be tricky.
There's a number of topics on my site that will help you with
this. Do scan through the topic on printing even if you don't
intend to generate a printed output. Some of the points in it are
relevant to your question.
