3 Replies Latest reply on May 20, 2012 3:03 PM by Anton Azarov
    What is the best AIR render mode?
    hhhhhhhhhhhhhh5 Level 1
      In Flash Professional Help / Publishing AIR for Android applications (http://helpx.adobe.com/flash/using/publishing-air-android-applications.html) I found the following:
      Render mode
      Allows you to specify which method the AIR runtime uses to render graphic content. The options include:
          Auto - automatically detect and use the fastest rendering method available on the host device.
          CPU - Use the CPU.
          GPU - Use the GPU. If no GPU is available, the CPU is used.
          Direct - Render using Stage3D. This is the fastest available rendering method.
      If the Auto mode automatically selects the fastest rendering method, what is the point of the 3 other options?
      My application has some minor 2D animations, but very smooth drag-and-drop performance is important. What rendering mode would you recommend?
      Thank you.
