I am using SCUP to update a v10 deployment to v11.2. The installation appears to work, with the updates agent showing installed status for all four updates which get applied to an x64 system:
Adobe Flash Player 32-bit ActiveX 11.2.202.235
Adobe Flash Player 64-bit ActiveX 11.2.202.235
Adobe Flash Player 64-bit Plugin 11.2.202.235
Adobe Flash Player 32-bit Plugin 11.2.202.235
That said the WindowsUpdate.log file shows a failure as follows:
Windows failed to install the following update with error 0x80070643: Adobe Flash Player 32-bit ActiveX 11.2.202.235
Now Flash Player is working in all browsers but the ActiveX Flash Player does not show in Add/Remove Programs. IE shows that it is using the ActiveX player.
The FlashInstall.log in SysWow64\Macromedia\Flash shows:
2012-5-18+10-39-54.631 [error] 1226 1062
=O====== M/11.2.202.235 2012-05-18+10-39-52.900 ========
0000 00000010 "C:\Windows\TEMP\{8F50881C-1A05-45FE-AF56-D34F4C74F081}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 2 -au 4294967295
0001
0002
0003
0004 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0005
0006
0007 00000018
0008
0009 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_2_202_235.ocx
0010 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.exe
0011 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.dll
0012 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0013
0014
0015 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0016
0017
0018
=X====== M/11.2.202.235 2012-05-18+10-39-56.709 ========
and
2012-5-18+10-40-6.910 [error] 1226 1062
=O====== M/11.2.202.235 2012-05-18+10-40-05.769 ========
0000 00000010 "C:\Windows\TEMP\{181D6F14-892A-40BB-A39F-10E973E139E7}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 2 -au 4294967295
0001
0002
0003 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_2_202_235.dll
0011 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_235_Plugin.exe
0012 00000017 C:\Windows\SysWOW64\Macromed\Flash
0013 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0014
0015
0016 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0017
0018
0019
=X====== M/11.2.202.235 2012-05-18+10-40-08.594 ========
So it clearly thinks there is some kind of failure.
I need to be confident of this update before rolling to 000's of machines so any input appreciated...
EDIT - OK I now know this only happens if intenet explorer it loaded at the time the updates are applied. There is no way to control this when deploying via SCUP so should the installers be able to handle IE being loaded at installation time?
You should only have to run the 64 bit updates as they contain both the 32 and 64 bit components.
There is no install switch that will ignore an opened browser. However, with the release of 11.2 this issue should only occur for re-installs of the same version. You should not see this occurring when updating to new versions.
That is interesting, SCUP decides that all 4 installers are requiredusing the prerequisites from the adobe catalog. Question is, does it matter? Still functions just doesn't show as an installed program in the control panel.
OK back this morning and had a look at the installable rules for the installer. Basically the x64 installer has a rule which contains the following...
Processor architecture is x64
However the 32 bit version does not have a rule related to architecture.
Therefore on a 64-bit machine it will attempt to install both the 64bit versions and the 32bit version, which is where the problem exists.
The machines currently have 32-bit flash 10, if we install only version 11.2 64-bit am I right in thinking it will remove the 32-bit 10 and leave only the correct 64-bit version installed?
Yes, I believe that is a correct assumption. Sorry if I wasn't clear in my previous post, your observation of the 64 bit installer's prerequisite and functionality are both correct.
I have copied and edited the updates with SCUP so that the 32-bit versions will only install on an x86 system. This has fixed the issue for 64-bit systems, they now only get the two 64-bit updates pushed at them. All working fine on the 64-bit front. Getting a number of 32-bit systems where they fail but actually it isn't a SCUP issue, on those machines if I log in and try to install manually it fails removing version 10 with the Error 2753. The file 'FP_AX_MSI_INSTALLER.exe' is not marked for installation.
I am not sure why this happens, could possibly be down to the methods used to install v10 in the first place. The Adobe flash uninstaller does not fix this, I had to manually remove registry keys to get v11.2 to install. We don't have too many 32 bit systems left but if it becomes a major problem I will look to deploy a script to remove the keys so the 11.2 install can function.
Could we get the following info from you?
1. What are the exact registry paths which still exist in the registry after running the uninstaller?
2. The FlashInstall.log from the following locations on a system that exhibits this issue?
C:\Windows\System32\Macromed\Flash\
Chris
Hi Chris,
Is there any plans to change the Installable rules for the x86 Flash updates in future versions published through the official catalogue to limit applicability to only 32bit machines. Just so we don’t need add this additional rule manaully before publishing to SCCM. Ideally we want to be able to have all Flash updates in a single SCCM SU deployment and let the update Installable rules determine correct applicability.
Ben
Hi Ben,
Starting with 11.3 (which is in beta right now), we have a universal installer for both 32 and 64 bit systems. AFAIK, this will carry over to msi's too.
Chris
Hi, I'm using SCCM/SCUP to deploy flash to 32-bit Windows 7 and Vista. Now using the universal installer 32/64. Installing fine for the vast majority of computers, but some are still giving the "Error 2753. The file 'FP_AX_MSI_INSTALLER.exe' is not marked for installation. " error message in Event Viewer Application Log. The same problem is persisting and I just cant see why some machines have it. Currently now pushing out 11.4.402.287, and have same issues.
The Sytem Log says: Installation Failure: Windows failed to install the following update with error 0x80070643: Adobe Flash Player 32-bit/64-bit ActiveX 11.4.402.287.
The SCCM log file c:\windows\system32\ccm\logs\WUAHandler.log says: Installation job encountered some failures. Error = 0x80240022
This link may help you...
If you edit this script to make it completely silent you can push it out to all your machines where you are getting the error. Then push out your Flash updates again and you should be okay. I don't know exactly why the error comes up but I think it must be related to the method used to install flash in the original instance.
