I'm using Flash Media Development Server 4.5.
And I'm doing some testing for a multicast stream (IP multicast). After 10 minutes it stream stops until I restart the application.
I know that before release 4.5 the limit of multicast was 10 minutes but after 4.5 release , 'the limit' is 30 minutes. So I guess that is another problem. I followed the standard procedure described here:
We never changed RTMFP limit. It was and it still is 10 minutes. When you say after 4.5 release - it was 30 minutes - which 4.5 release are you talking (because 4.5 is our last major release and we have just made 2 dot releases of 4.5 i.e. 4.5.1 & 4.5.2 - both of which dont have any licensing changes when it comes to Multicast timeout). Can you point to me any document where it says its changed to 30 minutes?
In this document
http://www.adobe.com/products/flash-media-server-family/buying-guide-comparison.html
seems that flash media server 4.5 Flash Media Development Server 4.5 has ip
multicast limit to 30 minutes.
Regards
Dario
That's a wrong info - i'll get that corrected. Sorry for miscommunication from our end.
ok no problem.
an other question -> Flash media interactive 4.5 can run on Windows XP OS?
I dont see any reason why it should not run - but its not supported platform.
OMG! I have same problem when using multicast, it limit 10 minutes, not 30 minutes on http://www.adobe.com/products/flash-media-server-family/buying-guide-c omparison.html. Thanks for your topic
I saw this problem too. So can I get serial number?
