1. Re: Multi-camera editing - FREEZING & LAGGING
(Howard_Cromwell) May 31, 2008 12:57 AM (in response to fredou_79)There are newer Aspect HD builds that fixes many problems:
http://www.miscdata.com/cineform/AspectHD-5.3.1.116-Setup.zip
What media are you using? perhaps dedicate your RAID to media... -
2. Re: Multi-camera editing - FREEZING & LAGGING
fredou_79 Jun 4, 2008 4:10 PM (in response to fredou_79)my raid is dedicated to medias
will check build 116
Jake from CF is on it also. -
3. Re: Multi-camera editing - FREEZING & LAGGING
fredou_79 Jun 12, 2008 2:11 PM (in response to fredou_79)build 118 still give me problem, any other sharing this problem? -
4. Re: Multi-camera editing - FREEZING & LAGGING
hpmoon May 20, 2012 9:41 PM (in response to fredou_79)Reviving this old thread because of the stunning lack of bug reports on this (if the problem is related, and still hasn't been fixed as recently as CS6).
When you've got your Multi-Camera Monitor visible, and you're fine-tuning your Multi-Camera sequence by moving the time indicator in that timeline, when you press play, the Multi-Camera Monitor freezes up and just plays the audio. This is happening to me on a Core i7-3770K (Ivy Bridge) overclocked to 4 GHz, etc. The simple solution, but a POOR one, is to active the Multi-Camera Monitor window first, and then press play.
This is incredibly dumb. It is a bona fide bug. It is simply not the way that the Project Monitor behaves vis-a-vis the timeline. Adobe hasn't fixed this for several versions by now. On the other hand, I can't find any complaints about it. Does no one care? Or are those stealth moderators around here ("Community Professionals") quashing reports as usual with unrelated advice about upgrading systems?
5. Re: Multi-camera editing - FREEZING & LAGGING
ACT.onn May 20, 2012 11:04 PM (in response to fredou_79)Hello all
I am having this same trouble. additionally my multicamera edit has a Hold Frame on the In point of each clip!
6. Re: Multi-camera editing - FREEZING & LAGGING
Jeff Bellune May 21, 2012 4:45 AM (in response to hpmoon)@hpmoon,
If you haven't done it yet, please file a bug report here:
Adobe - Feature Request/Bug Report Form
Todd Kopriva (an Adobe employee) has assured us that every one of those is reviewed and analyzed. Then they are prioritized. The most serious bugs that affect the most users are the ones that will get fixed first.
Jeff
7. Re: Multi-camera editing - FREEZING & LAGGING
hpmoon May 21, 2012 8:24 AM (in response to Jeff Bellune)Yes, of course. My experience is that they ignore many such reports, but I've already filed one and might be pleasantly surprised. Anyway, for the purposes of this thread, it will help if we all confirm this is a problem, documenting here whether Premiere behaves this way on all systems.
