1. Re: EDL created by Premiere Pro causing import failures.
Tim Kossow May 21, 2012 10:35 AM (in response to StevRo)Hey Steve,
I'm having similar issues. Mine says: "unsupported edit info: 'W000' in edit 4". Also it crashes, if I try to use the "Send to SpeedGrade" function. Really anoying!
Any suggestions?
-- Tim
2. Re: EDL created by Premiere Pro causing import failures.
StevRo May 21, 2012 12:51 PM (in response to Tim Kossow)Hi TIm,
not really other than disabling/removing the transition's that don't import. For now, I don't export audio tracks into SG, I'll work on it seperately after I get the edits/grading done.
3. Re: EDL created by Premiere Pro causing import failures.
Tim Kossow May 22, 2012 2:23 AM (in response to StevRo)Thanks!
Maybe it's even a nice way to get used to a more steamlined workflow, i don't know. Sending to SpeedGrade also takes forever and crashes regularily, really annoying! Kind of puts the term "SpeedGrade" into a new context, if you have to wait half an hour to start grading.
cheers,
-- Tim
4. Re: EDL created by Premiere Pro causing import failures.
Vincent Lindsay Sep 11, 2012 4:46 PM (in response to StevRo)I just got an error like this.
I do have some transitions and clips in the footage, and because of hte mix of video with timelapse, some go beyond 100% some go below. How do you fix this? Edit:
I opened the .edl file and this is what is on line 35, I redid the export of the edl file, error changed.
035 AX V W000 006 00:00:00:00 00:00:02:07 00:02:50:14 00:02:53:11 EFFECTS NAME IS W000
* FROM CLIP NAME: MVI_8747.MOV
* TO CLIP NAME: IMG_8692.JPG
M2 AX 179.8 00:01:34:16 M2 AX 019.2 00:00:00:00 its seems its from a movie to a timelapse.
Edit 2: I tried taking away the transition, but its still the same, The constant I see is W000. Whatever that is, its breaking it.
5. Re: EDL created by Premiere Pro causing import failures.
Vincent Lindsay Sep 11, 2012 4:26 PM (in response to Tim Kossow)seems like you have some other problems if it takes you that long to load up speedgrade. probably one of the fastest adobe programs i have ever used.
