CS6 installation error, inconsistency in the installer database, exit error 15
May 22, 2012 May 22, 2012
I just received my serial number but I can't install due to the above problem. Any advice? I ran the cleaner, restarted several times, nothing works! Please help!
21.3K
I'm seeing exactly the same error. I'm on OS X Lion 10.7.3. I have tried rebooting and running the Disk Utility and repairing disk permissions. Neither have fixed the problem.
I have to say this is fairly ridiculous. I'm only evaluating CS6 on a trial at this point. If Adobe can't make something as basic as software installation work (it's just copying some files into a directory FFS!) it doesn't exactly create a great impression of their product.
Think I'm going to start Googling "alternatives to Adobe Illustrator" rather than waste any more time on this...
I'm on the Lion 10.7.4
Now it won't even accept my serial number anymore. This is really ridiculous, I have wasted 2 days on this already, I am seriously fed up!!!
I should also add that I've run the Adobe Cleaner Tool as well. Still no luck. Sort it out Adobe! This is woeful.
Adobe Employee ,
Which Adobe product are you both trying to install?  How did you obtain the software?  Did you download it?  Did it come on a disc?
I am trying to install the trial of Adobe Illustrator CS6 downloaded from Adobe using the Adobe Download Manager.
Adobe Employee ,
Interesting because we have been seeing this error for users installing from the Creative Cloud and not from the trials.  Was the download able to complete successfully or are you trying to open the DMG file while the Adobe Download Assistant is saying that it is still extracting?
Alternately can you try downloading the install files using the directions listed at http://forums.adobe.com/thread/981369 to initiate a direct download.
The Download Assistant completed and then launched the installer itself. The installation process hung the first time around. I then retried it manually and it failed with the error code listed above.
Adobe Employee ,
So no error messages when downloading through the Adobe Download Assistant.  What happened when you initiated the direct download?
I'll see if I have time to re-download the 1.5GB installer and try again tomorrow, but I'm not really sure why I should bother given I managed to create my illustration with Inkscape this afternoon while waiting for this to be resolved.
Honestly, do you really expect to be able to attract new customers if your installation experience is this poor? You're asking people to...
1) Download and install the Adobe Download Assistant.
2) Download a ridiculously huge file (most OSes are smaller than a 1.5GB download)
3) Attempt to install the file.
4) Clean their Adobe installation folder when that fails to work.
5) Re-download the file a slightly different way (so we're up to over 3GB now)
6) Attempt to install that file.
...and then assuming that works, you charge them over $1000 for the privilege. Not exactly a persuasive buying experience.
Contrast that with Inkscape:
1) Download a 80MB archive.
2) Extract to a folder.
3) Run the app - done.
Pain involved:none. Cost the user: $0.
I have the disc for CS6 extended, I just received my serial # today. Should I try to download directly from Adobe? Is the installer the problem?
Adobe Employee ,
@anke55mom I have branched your discussion out to http://forums.adobe.com/thread/1009706.  Since you were initially inquiring about obtaining a serial number.  If you have the DVD media though then please install from the DVD.
@tomtheguvnor1 I am sorry that you had difficulties downloading I am guessing a suite of products by the file size you were posting?  Unfortunately I am unsure what exactly caused your difficulties since we have not completed the troubleshooting process.  If I had to make an assumption I would assume that the download was not completed and that the download files were being saved to a location which the Adobe Download Assistant did not have permission to write too.
Not sure why you would conclude that. Given @anke55mom is getting an identical error and attempting to install from a DVD, it suggests to me that it has nothing to do with an incomplete download.
I have been trying to download from the disc, it's not installing!!! I get the installer finished but the download itself stops at 2 % and gives me the exit error 15, see my initial title
Adobe Employee ,
Anke55mom can you please run the Adobe Support Advisor - http://www.adobe.com/support/loganalyzer/ and choose the package for support option.  It will provide you a token number can you please respond to this thread with that number.
OK, I re-downloaded using the direct download linked you suggested and I got exactly the same error.
Adobe Employee ,
Very strange previously this issue was reported for download errors.  Tomtheguvnor1 can you please complete the same steps I requested of Anke55mom.  This will allow me to review your installation log files.  Also can you try installing by rebooting safe boot mode, starting with the shift key held down, to see if you receive the same error message.
Guest
I have the same problem. I spent the whole night for this issue but could not solve. I try the cleaner applicaiton, it didn't help. I also downloaded it again, but still same problem. By the way, I was installing Dreamveaver on Mac OS 10.7.4, not design premium or something else.
No luck, never worked.
I can't even open that now... I downloaded the Mac version of the Support Advisor, here is the message I am getting! What the heck is going on here???
This application cannot be installed because this installer has been mis-configured. Please contact the application author for assistance.
Its strange that you all are facing the same issue in different situation , it doesn't sound like the problem with the installer becuase we have tried with DVD , Direct Download and also from the Download Manger . The problem looks like with the Mac OS something common.
Can you start your machine in "Safe mode" and then install the software , if it doesn't work then we would require the log files for analysis.
You can manually retrieve the install logs , check this link for detail :- kb2.adobe.com/cps/844/cpsid_84451.html
May 23, 2012 May 23, 2012
I started in safe mode, found the log files, The summary lists 0 errors 0 fatal, 0 warnings at the bottoms, the only thing it says is "Media DB sync failed". I am not able to copy with the command you told me to use, it takes me out of the file.... The support Advisor still does not install in safe mode either...
Can I just return the program and get a credit, I am tired of this. I have had no problem with any other program, I have been using CS5 with no issues, this is absurd!!
Error "Media DB sync failed"  , It looks like you have some previous version of Adobe software present on you machine , You can uninstall all the adobe software , run the cleaner tool and re-install the software.
You could download the cleaner tool  from www.adobe.com/support/contact/cscleanertool.html
If you want to returm the program , you have to contact support , no one would be able to help you here reagrding that.
I am currently running CS5 and I am scared to uninstall it, because I need to have one that works. If that doesn't solve my problem, I am stuck!!!
Hmmm...You have a point but you have to take your chances.
The solution I have suggested should work for you however if in case it doesn't work, you can anytime install CS5 back.
So if you want to try the solution once again ,
1) Uninstall CS5
2) Run the cleaner tool
3) Install CS6
Find the link for cleaner tool in my previous post
I don't understand why I have to uninstall CS5, none of the people I know had to do that! I would like to keep the program on my computer! There has to be a different way to fix this!
