why am I getting the error message No permission to copy document here?
Because you don't have "permission to copy document here"? Pardon the sarcasm, but you're not telling us anything here - not the program, not the operating system, no nothing. Nobody can help you based on some sentence that merely reflects your frustrated mumbling at the screen...
Mylenium
I thought i was still on the help site cor adobe digital reader not the entire Adobe site. I downloaded books from my local library and cant transfer them to my nook, it says they are documents and i cant copy them. Ive been doing it the same way for 6 months and now i have problems
Moving this discussion to the Adobe Digital Editions forum.
The answer to the question is that either the publisher or the library have
set the digital rights to those ebooks to prevent you from copying them to
another device. You can check this by looking at the ebooks' digital
rights. Here's how:
In ADE Library mode, click on the small arrow next to the ebook's name. A
drop-down box will give you some choices - pick Item Info. About halfway
down the list is the section that contains the digital rights settings.
I'm betting the 'copying' setting says no.
There's no way to fix this - it's the perogative of publishers, writers,
distributors and libraries. So if you don't like it, try contacting your
library and see if they can change the setting. I'm not hopeful that they
can or if they can, they will.
While some publishers do restrict copying titles, the error is actually referring to the transfer of the book, not actually copying. Copy restrictions means just that: you cannot make a copy of the book. This error is typically caused when the NOOK has not been authorized properly. To solve the issue, you need to reset the Adobe credentials on your NOOK.
Note: These instructions are for ADE 2.0. Please make sure you're using the most up-to-date version before continuing.
Connect your NOOK to your computer (if it's not already connected).
Hope this helps!
I have a Kobo touch. Using either a WIN XP SP3 or WIN7 machine does your procedure apply?
I want to double-check with you since the E-reader can be cranky.
My basic problem is similar to the original:
- Could transfer books some months ago.
- After yet another reset some non-Kobo sourced books will now not transfer.
- The error message is "No permission to copy here".
- The digital rights show "No copying".
Two computers are involved, same ADE ID.
Howard
