1. Re: CF10 Solr Search RHEL
raZorTTZ May 22, 2012 6:45 PM (in response to raZorTTZ)Also,
I took a look in the neo-solr.xml file and based on the port number and webapp entry tried navigating to it using the browser
and got a could not connect error using chrome. My understanding (limited as it is) is that I should get site back.
Cheers,Simon
2. Re: CF10 Solr Search RHEL
raZorTTZ May 22, 2012 7:12 PM (in response to raZorTTZ)Some more thinking out loud..
Should the Solr Home be /opt/coldfusion10/cfusion/jetty/multicore or /opt/coldfusion10/cfusion/jetty/solr?
Here is the neo-solr.xml file (minus the languages node for brevity sake)
<wddxPacket version='1.0'>
<header/>
<data>
<struct type='coldfusion.server.ConfigMap'>
<var name='httpsenabled'>
<string>FALSE</string>
</var>
<var name='solrport'>
<number>8985.0</number>
</var>
<var name='solrhttpsport'>
<number>0.0</number>
</var>
<var name='solrwebapp'>
<string>solr</string>
</var>
<var name='solrhost'>
<string>localhost</string>
</var>
<var name='languages' />
<var name='username'>
<string/>
</var>
<var name='solrbuffersize'>
<number>40.0</number>
</var>
<var name='solrhome'>
<string>/opt/coldfusion10/cfusion/jetty/multicore</string>
</var>
<var name='password'>
<string/>
</var>
</struct>
</data>
</wddxPacket>
3. Re: CF10 Solr Search RHEL
raZorTTZ May 22, 2012 10:29 PM (in response to raZorTTZ)The plot thickens...
I have been trying to manually start the service using the /opt/coldfusion10/cfusion/jetty/cfjetty script and came up with an error.
I had a look at the /opt/coldfusion10/cfusion/jetty/logs/start.log file and found the following
/sbin/runuser: invalid option -- 'X'
Try `/sbin/runuser --help' for more information.
It turns out that when cfjetty is executed the JVM arguments that are included in the command
-XX:+AggressiveOpts -XX:+ScavengeBeforeFullGC -XX:-UseParallelGC -Xmx512m -Dsolr.solr.home=multicore -DSTOP.PORT=8077 -DSTOP.KEY=cfsolrstop
are causing an exception and the service never starts.
If I edit the /opt/coldfusion10/cfusion/jetty/cfjetty script and wrap the command that is being sent through /sbin/runuser with double quotes, the script executes and the service starts.
Around line 77 for my particular change (I went through and updated other references so I could stop and restart later)
Before:
SOLRSTART='cd $SOLR;$SUCMD $SOLR_JVM/bin/java $JVMARGS -jar start.jar >> $SOLR/logs/start.log 2>&1'
After
SOLRSTART='cd $SOLR;$SUCMD "$SOLR_JVM/bin/java $JVMARGS -jar start.jar >> $SOLR/logs/start.log 2>&1"'
Now I can get into the ColdFusion Collections section of the ColdFusion Administrator.
Should the service be started automatically when ColdFusion starts? It doesn't look like it starts automatically.
Cheers,
Simon
4. Re: CF10 Solr Search RHEL
Jan Ruusuvuori Oct 1, 2012 9:03 PM (in response to raZorTTZ)Thanks Simon,
I ran into the same issue ("cfjetty start" fails due to botched runuser command line). The info you posted helped be solve it.
By the way, have you filed this as a bug at https://bugbase.adobe.com ?
Br,
Jan
5. Re: CF10 Solr Search RHEL
raZorTTZ Oct 1, 2012 10:11 PM (in response to Jan Ruusuvuori)Hi Jan,
Glad it helped
Thanks for the link to the bugbase. I have submitted the bug to Adobe. I also saw a bug that had been closed in the public beta that is a duplicate
https://bugbase.adobe.com/index.cfm?event=bug&id=3123145
Cheers,
Simon
6. Re: CF10 Solr Search RHEL
mlerley Aug 4, 2014 12:02 PM (in response to raZorTTZ)Thanks! Still not fixed, and this is still helping.
