1 2 Previous Next 40 Replies Latest reply on Apr 3, 2013 10:48 AM by jaredg18
    Video investigation with Flash Player 11.2.202.228
    chris.campbell Adobe Employee
      Are you seeing a green screen or bars when watching video with the latest Flash Player update, version 11.2.202.228?
      Do you see other display bugs, such as incorrect colors or severe artifacting?
      We're actively investigating these problem and would like to consolidate information into this thread.  Here's what we need from you:
      First, please update your drivers to the latest released version.  Do not use beta drivers.  There are known issues with Nvidia beta drivers (285.27 and 285.38) that can cause bugs with Flash Player.  Please verify that you have the released versions from your GPU manufacturer.  If you have to choose between an older driver provided by your computer manufacturer (Dell, Acer, etc.) or a new driver by the GPU manufacturer (Nvidia, ATI, Intel, etc), choose the newer driver.  You can find these drivers here:
      If updating your driver does not solve the problem, here's what we'd like to know.  Please answer all four questions:
      1. What problem are you encountering?
      2. Try disabling Flash's hardware acceleration.  Does this fix the bug?
      3. What URL did you use to view video?  Please be specific (ie. we need something more than just "any youtube video")
      4. Please post your DxDiag report.  See these steps for details for creating the DxDiag.txt file.  Open this file and copy/paste the contents to your reply.
      Chris
        • 1. Re: Video investigation with Flash Player 11.2.202.228
          ginganinga1 Level 1
          1. Messed up colour with green line at the top just like your example screenshot when playing some embedded videos
          2. Disabling Flash Hardware acceleration fixes the issue
          3. http://www.qvcuk.com/video/todaysproducts.html?cm_re=LN-_-OnQVCTV-_-VOTP
          4. See below:
          System Information
          Time of this report: 4/12/2012, 00:46:32
                 Machine name: xxxxx
             Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.111118-2330)
                     Language: English (Regional Setting: English)
          System Manufacturer: Medion
                 System Model: X6815
                         BIOS: BIOS Date: 07/18/11 14:06:58 Ver: 04.06.03
                    Processor: Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz (8 CPUs), ~2.2GHz
                       Memory: 8192MB RAM
          Available OS Memory: 8104MB RAM
                    Page File: 3009MB used, 13194MB available
                  Windows Dir: C:\Windows
              DirectX Version: DirectX 11
          DX Setup Parameters: Not found
             User DPI Setting: 120 DPI (125 percent)
          System DPI Setting: 120 DPI (125 percent)
              DWM DPI Scaling: Disabled
               DxDiag Version: 6.01.7601.17514 64bit Unicode
          DxDiag Notes
                Display Tab 1: No problems found.
                  Sound Tab 1: No problems found.
                  Sound Tab 2: No problems found.
                    Input Tab: No problems found.
          DirectX Debug Levels
          Direct3D:    0/4 (retail)
          DirectDraw:  0/4 (retail)
          DirectInput: 0/5 (retail)
          DirectMusic: 0/5 (retail)
          DirectPlay:  0/9 (retail)
          DirectSound: 0/5 (retail)
          DirectShow:  0/6 (retail)
          Display Devices
                    Card name: Intel(R) HD Graphics 3000
                 Manufacturer: Intel Corporation
                    Chip type: Intel(R) HD Graphics Family
                     DAC type: Internal
                   Device Key: Enum\PCI\VEN_8086&DEV_0116&SUBSYS_20801B0A&REV_09
               Display Memory: 1696 MB
             Dedicated Memory: 64 MB
                Shared Memory: 1632 MB
                 Current Mode: 1920 x 1080 (32 bit) (60Hz)
                 Monitor Name: Generic PnP Monitor
                Monitor Model: unknown
                   Monitor Id: SEC314C
                  Native Mode: 1920 x 1080(p) (59.999Hz)
                  Output Type: Internal
                  Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
          Driver File Version: 8.15.0010.2656 (English)
               Driver Version: 8.15.10.2656
                  DDI Version: 10.1
                 Driver Model: WDDM 1.1
            Driver Attributes: Final Retail
             Driver Date/Size: 2/17/2012 10:28:48, 8087040 bytes
                  WHQL Logo'd: Yes
              WHQL Date Stamp:
            Device Identifier: {D7B78E66-4256-11CF-DA72-8A00A9C2C535}
                    Vendor ID: 0x8086
                    Device ID: 0x0116
                    SubSys ID: 0x20801B0A
                  Revision ID: 0x0009
          Driver Strong Name: oem29.inf:IntelGfx.NTamd64.6.0:iSNBM0:8.15.10.2656:pci\ven_8086&dev_0116
               Rank Of Driver: 00E62001
                  Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
             Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                               {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                               {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                               {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                 D3D9 Overlay: Supported
                      DXVA-HD: Supported
                 DDraw Status: Enabled
                   D3D Status: Enabled
                   AGP Status: Enabled
          Sound Devices
                      Description: Speakers (Realtek High Definition Audio)
          Default Sound Playback: Yes
          Default Voice Playback: Yes
                      Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0269&SUBSYS_1B0A20B8&REV_1001
                  Manufacturer ID: 1
                       Product ID: 100
                             Type: WDM
                      Driver Name: RTKVHD64.sys
                   Driver Version: 6.00.0001.6353 (English)
                      WHQL Logo'd: Yes
                    Date and Size: 4/19/2011 17:19:42, 2839912 bytes
                      Other Files:
                  Driver Provider: Realtek Semiconductor Corp.
                   HW Accel Level: Basic
                        Cap Flags: 0xF1F
              Min/Max Sample Rate: 100, 200000
          Static/Strm HW Mix Bufs: 1, 0
          Static/Strm HW 3D Bufs: 0, 0
                        HW Memory: 0
                 Voice Management: No
          EAX(tm) 2.0 Listen/Src: No, No
             I3DL2(tm) Listen/Src: No, No
          Sensaura(tm) ZoomFX(tm): No
                      Description: Realtek Digital Output (Realtek High Definition Audio)
          Default Sound Playback: No
          Default Voice Playback: No
                  Manufacturer ID: 1
                       Product ID: 100
                             Type: WDM
                      WHQL Logo'd: Yes
                      Other Files:
                        Cap Flags: 0xF1F
                        HW Memory: 0
          Sound Capture Devices
                      Description: Microphone (Realtek High Definition Audio)
            Default Sound Capture: Yes
            Default Voice Capture: Yes
                        Cap Flags: 0x1
                     Format Flags: 0xFFFFF
          DirectInput Devices
                Device Name: Mouse
                   Attached: 1
              Controller ID: n/a
          Vendor/Product ID: n/a
                  FF Driver: n/a
                Device Name: Keyboard
                   Attached: 1
              Controller ID: n/a
                  FF Driver: n/a
          Poll w/ Interrupt: No
          USB Devices
          + USB Root Hub
          | Vendor/Product ID: 0x8086, 0x1C26
          | Matching Device ID: usb\root_hub20
          | Service: usbhub
          | Driver: usbhub.sys, 3/25/2011 04:29:26, 343040 bytes
          | Driver: usbd.sys, 3/25/2011 04:28:59, 7936 bytes
          +-+ Generic USB Hub
          | | Vendor/Product ID: 0x8087, 0x0024
          | | Matching Device ID: usb\class_09
          | | Service: usbhub
          Gameport Devices
          PS/2 Devices
          + Standard PS/2 Keyboard
          | Matching Device ID: *pnp0303
          | Service: i8042prt
          | Driver: i8042prt.sys, 7/14/2009 00:19:57, 105472 bytes
          | Driver: kbdclass.sys, 7/14/2009 02:48:04, 50768 bytes
          + Terminal Server Keyboard Driver
          | Matching Device ID: root\rdp_kbd
          | Upper Filters: kbdclass
          | Service: TermDD
          + Synaptics PS/2 Port TouchPad
          | Matching Device ID: *syn1d0f
          | Upper Filters: SynTP
          | Service: i8042prt
          + Terminal Server Mouse Driver
          | Matching Device ID: root\rdp_mou
          | Upper Filters: mouclass
          | Service: TermDD
          | Driver: termdd.sys, 11/21/2010 04:23:47, 63360 bytes
          | Driver: sermouse.sys, 7/14/2009 01:00:20, 26624 bytes
          | Driver: mouclass.sys, 7/14/2009 02:48:27, 49216 bytes
          Disk & DVD/CD-ROM Drives
                Drive: C:
          Free Space: 485.5 GB
          Total Space: 901.5 GB
          File System: NTFS
                Model: SAMSUNG HN-M101MBB
                Drive: D:
          Free Space: 29.5 GB
          Total Space: 51.2 GB
          File System: NTFS
                Drive: E:
                Model: HL-DT-ST BDDVDRW CT40N
               Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), 11/21/2010 04:23:47, 147456 bytes
          System Devices
               Name: Intel(R) 6 Series/C200 Series Chipset Family SMBus Controller - 1C22
          Device ID: PCI\VEN_8086&DEV_1C22&SUBSYS_20A91B0A&REV_05\3&11583659&2&FB
             Driver: n/a
               Name: 2nd generation Intel(R) Core(TM) processor family DRAM Controller - 0104
          Device ID: PCI\VEN_8086&DEV_0104&SUBSYS_20A91B0A&REV_09\3&11583659&2&00
             Driver: n/a
               Name: High Definition Audio Controller
          Device ID: PCI\VEN_8086&DEV_1C20&SUBSYS_20B81B0A&REV_05\3&11583659&2&D8
             Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/21/2010 04:23:47, 122368 bytes
               Name: 2nd generation Intel(R) Core(TM) processor family PCI Express Controller - 0101
          Device ID: PCI\VEN_8086&DEV_0101&SUBSYS_20A91B0A&REV_09\3&11583659&2&08
             Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/21/2010 04:23:47, 184704 bytes
               Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 6 - 1C1A
          Device ID: PCI\VEN_8086&DEV_1C1A&SUBSYS_20A91B0A&REV_B5\3&11583659&2&E5
               Name: Intel(R) Centrino(R) Wireless-N 1030
          Device ID: PCI\VEN_8086&DEV_008A&SUBSYS_53058086&REV_34\4&23A43D1D&0&00E1
             Driver: n/a
               Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 4 - 1C16
          Device ID: PCI\VEN_8086&DEV_1C16&SUBSYS_20A91B0A&REV_B5\3&11583659&2&E3
               Name: Realtek PCIe GBE Family Controller
          Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_20A81B0A&REV_06\4&132F4C9F&0&00E5
             Driver: n/a
               Name: Intel(R) HM65 Express Chipset Family LPC Interface Controller - 1C49
          Device ID: PCI\VEN_8086&DEV_1C49&SUBSYS_20A91B0A&REV_05\3&11583659&2&F8
             Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 02:48:27, 15424 bytes
               Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 2 - 1C12
          Device ID: PCI\VEN_8086&DEV_1C12&SUBSYS_20A91B0A&REV_B5\3&11583659&2&E1
               Name: NVIDIA GeForce GT 555M
          Device ID: PCI\VEN_10DE&DEV_0DCE&SUBSYS_20A61B0A&REV_A1\4&2974873A&0&0008
             Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 213096 bytes
             Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 6/12/2011 11:43:00, 307604 bytes
             Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\Nvd3d9wrap.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 233064 bytes
             Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\detoured.dll, 6/12/2011 11:43:00, 4096 bytes
             Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvdxgiwrap.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 224360 bytes
             Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\Nvd3d9wrapx.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 259072 bytes
             Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\detoured.dll, 6/12/2011 11:43:00, 4096 bytes
             Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvdxgiwrapx.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 248320 bytes
             Driver: C:\Program Files\NVIDIA Corporation\license.txt, 6/12/2011 11:43:00, 15511 bytes
             Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 13241448 bytes
             Driver: C:\Windows\system32\DRIVERS\nvpciflt.sys, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 27240 bytes
             Driver: C:\Windows\system32\OpenCL.dll, 1.00.0000.0000 (English), 6/12/2011 11:43:00, 67176 bytes
             Driver: C:\Windows\system32\nvapi64.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 2646632 bytes
             Driver: C:\Windows\system32\nvcompiler.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 18583144 bytes
             Driver: C:\Windows\system32\nvcuda.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 7130216 bytes
             Driver: C:\Windows\system32\nvcuvenc.dll, 6.14.0012.7548 (English), 6/12/2011 11:43:00, 2213480 bytes
             Driver: C:\Windows\system32\nvcuvid.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 2944104 bytes
             Driver: C:\Windows\system32\nvd3dumx.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 15238248 bytes
             Driver: C:\Windows\system32\nvdecodemft.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 362600 bytes
             Driver: C:\Windows\system32\nvinfo.pb, 6/12/2011 11:43:00, 7240 bytes
             Driver: C:\Windows\system32\nvinitx.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 239720 bytes
             Driver: C:\Windows\system32\nvoglv64.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 22296168 bytes
             Driver: C:\Windows\system32\nvoptimusmft.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 366696 bytes
             Driver: C:\Windows\system32\nvumdshimx.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 834152 bytes
             Driver: C:\Windows\system32\nvwgf2umx.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 8863336 bytes
             Driver: C:\Windows\SysWow64\OpenCL.dll, 1.00.0000.0000 (English), 6/12/2011 11:43:00, 57960 bytes
             Driver: C:\Windows\SysWow64\nvapi.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 2337896 bytes
             Driver: C:\Windows\SysWow64\nvcompiler.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 13011560 bytes
             Driver: C:\Windows\SysWow64\nvcuda.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 5303912 bytes
             Driver: C:\Windows\SysWow64\nvcuvenc.dll, 6.14.0012.7548 (English), 6/12/2011 11:43:00, 2082408 bytes
             Driver: C:\Windows\SysWow64\nvcuvid.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 2804840 bytes
             Driver: C:\Windows\SysWow64\nvd3dum.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 12003432 bytes
             Driver: C:\Windows\SysWow64\nvdecodemft.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 300136 bytes
             Driver: C:\Windows\SysWow64\nvinit.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 200808 bytes
             Driver: C:\Windows\SysWow64\nvoglv32.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 16464488 bytes
             Driver: C:\Windows\SysWow64\nvoptimusmft.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 326248 bytes
             Driver: C:\Windows\SysWow64\nvumdshim.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 695400 bytes
             Driver: C:\Windows\SysWow64\nvwgf2um.dll, 8.17.0012.7548 (English), 6/12/2011 11:43:00, 6554216 bytes
             Driver: C:\Windows\system32\nvdispco6420150.dll, 2.00.0015.0000 (English), 6/12/2011 11:43:00, 1496168 bytes
             Driver: C:\Windows\system32\nvgenco6420100.dll, 2.00.0010.0000 (English), 6/12/2011 11:43:00, 1427560 bytes
               Name: Intel(R) 6 Series/C200 Series Management Engine Interface - 1C3A
          Device ID: PCI\VEN_8086&DEV_1C3A&SUBSYS_20A91B0A&REV_04\3&11583659&2&B0
             Driver: n/a
               Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 1 - 1C10
          Device ID: PCI\VEN_8086&DEV_1C10&SUBSYS_20A91B0A&REV_B5\3&11583659&2&E0
               Name: Renesas Electronics USB 3.0 Host Controller
          Device ID: PCI\VEN_1033&DEV_0194&SUBSYS_20931B0A&REV_04\4&37254DAA&0&00E3
             Driver: C:\Windows\system32\DRIVERS\nusb3xhc.sys, 2.01.0016.0000 (English), 4/13/2011 17:30:54, 207872 bytes
             Driver: C:\Windows\system32\nusb3co1.dll, 2.01.0014.0000 (English), 4/1/2011 17:50:40, 81920 bytes
               Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
          Device ID: PCI\VEN_8086&DEV_1C2D&SUBSYS_20A91B0A&REV_05\3&11583659&2&D0
             Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7601.17586 (English), 3/25/2011 04:29:04, 52736 bytes
             Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17586 (English), 3/25/2011 04:29:14, 325120 bytes
             Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17586 (English), 3/25/2011 04:29:26, 343040 bytes
               Name: Intel(R) Mobile Express Chipset SATA AHCI Controller
          Device ID: PCI\VEN_8086&DEV_1C03&SUBSYS_20A91B0A&REV_05\3&11583659&2&FA
             Driver: C:\Windows\system32\DRIVERS\iaStor.sys, 10.01.0000.1008 (English), 11/6/2010 07:45:48, 438808 bytes
               Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26
          Device ID: PCI\VEN_8086&DEV_1C26&SUBSYS_20A91B0A&REV_05\3&11583659&2&E8
               Name: Intel(R) HD Graphics 3000
          Device ID: PCI\VEN_8086&DEV_0116&SUBSYS_20801B0A&REV_09\3&11583659&2&10
             Driver: C:\Windows\system32\DRIVERS\igdkmd64.sys, 8.15.0010.2656 (English), 2/17/2012 10:28:56, 14692896 bytes
             Driver: C:\Windows\system32\igdumd64.dll, 8.15.0010.2656 (English), 2/17/2012 10:28:48, 8087040 bytes
             Driver: C:\Windows\system32\igd10umd64.dll, 8.15.0010.2656 (English), 2/17/2012 10:21:54, 9605632 bytes
             Driver: C:\Windows\system32\igfxcmrt64.dll, 2.02.0000.1006 (English), 2/17/2012 09:21:50, 193024 bytes
             Driver: C:\Windows\system32\igfxcmjit64.dll, 2.02.0000.1006 (English), 2/17/2012 09:21:50, 2967040 bytes
             Driver: C:\Windows\system32\IccLibDll_x64.dll, 3/26/2011 14:29:42, 94208 bytes
             Driver: C:\Windows\system32\igkrng600.bin, 2/17/2012 10:27:56, 963912 bytes
             Driver: C:\Windows\system32\igcompkrng600.bin, 3/26/2011 15:18:08, 145804 bytes
             Driver: C:\Windows\system32\igfcg600m.bin, 2/17/2012 10:27:56, 261208 bytes
             Driver: C:\Windows\SysWow64\igkrng600.bin, 2/17/2012 10:27:56, 963912 bytes
             Driver: C:\Windows\SysWow64\igcompkrng600.bin, 3/26/2011 15:18:08, 145804 bytes
             Driver: C:\Windows\SysWow64\igfcg600m.bin, 2/17/2012 10:27:56, 261208 bytes
             Driver: C:\Windows\system32\igdde64.dll, 2/17/2012 10:27:54, 79360 bytes
             Driver: C:\Windows\SysWow64\igdde32.dll, 2/17/2012 10:24:50, 58880 bytes
             Driver: C:\Windows\system32\iglhxs64.vp, 2/17/2012 10:42:22, 18508 bytes
             Driver: C:\Windows\system32\iglhxo64.vp, 2/17/2012 09:21:50, 59425 bytes
             Driver: C:\Windows\system32\iglhxc64.vp, 2/17/2012 09:21:50, 59230 bytes
             Driver: C:\Windows\system32\iglhxg64.vp, 2/17/2012 09:21:50, 59398 bytes
             Driver: C:\Windows\system32\iglhxo64_dev.vp, 2/17/2012 09:21:50, 58109 bytes
             Driver: C:\Windows\system32\iglhxc64_dev.vp, 2/17/2012 09:21:50, 59104 bytes
             Driver: C:\Windows\system32\iglhxg64_dev.vp, 2/17/2012 09:21:50, 58796 bytes
             Driver: C:\Windows\system32\iglhxa64.vp, 3/26/2011 14:29:42, 1074 bytes
             Driver: C:\Windows\system32\iglhxa64.cpa, 3/26/2011 14:29:42, 1981696 bytes
             Driver: C:\Windows\system32\iglhcp64.dll, 3.00.0001.0014 (English), 2/17/2012 09:21:50, 213504 bytes
             Driver: C:\Windows\system32\iglhsip64.dll, 3.00.0000.0012 (English), 2/17/2012 09:21:50, 524800 bytes
             Driver: C:\Windows\SysWow64\igdumd32.dll, 8.15.0010.2656 (English), 2/17/2012 10:24:54, 6121472 bytes
             Driver: C:\Windows\SysWow64\igfxdv32.dll, 8.15.0010.2656 (English), 2/17/2012 09:23:18, 321024 bytes
             Driver: C:\Windows\SysWow64\igd10umd32.dll, 8.15.0010.2656 (English), 2/17/2012 10:13:04, 7794688 bytes
             Driver: C:\Windows\SysWow64\iglhcp32.dll, 3.00.0001.0014 (English), 2/17/2012 09:21:50, 177152 bytes
             Driver: C:\Windows\SysWow64\iglhsip32.dll, 3.00.0000.0012 (English), 2/17/2012 09:21:50, 519680 bytes
             Driver: C:\Windows\SysWow64\IntelCpHeciSvc.exe, 1.00.0001.0014 (English), 2/17/2012 10:37:02, 276248 bytes
             Driver: C:\Windows\SysWow64\igfxcmrt32.dll, 2.02.0000.1006 (English), 2/17/2012 09:21:50, 237056 bytes
             Driver: C:\Windows\SysWow64\igfxcmjit32.dll, 2.02.0000.1006 (English), 2/17/2012 09:21:50, 2321408 bytes
             Driver: C:\Windows\system32\difx64.exe, 1.04.0001.0000 (English), 2/17/2012 10:37:02, 184600 bytes
             Driver: C:\Windows\system32\hccutils.dll, 8.15.0010.2656 (English), 2/17/2012 09:25:18, 110592 bytes
             Driver: C:\Windows\system32\igfxsrvc.dll, 8.15.0010.2656 (English), 2/17/2012 09:25:38, 63488 bytes
             Driver: C:\Windows\system32\igfxsrvc.exe, 8.15.0010.2656 (English), 2/17/2012 10:37:02, 511768 bytes
             Driver: C:\Windows\system32\igfxpph.dll, 8.15.0010.2656 (English), 2/17/2012 09:25:54, 386560 bytes
             Driver: C:\Windows\system32\igfxcpl.cpl, 8.15.0010.2656 (English), 2/17/2012 09:26:14, 126976 bytes
             Driver: C:\Windows\system32\igfxdev.dll, 8.15.0010.2656 (English), 2/17/2012 09:25:10, 430080 bytes
             Driver: C:\Windows\system32\igfxdo.dll, 8.15.0010.2656 (English), 2/17/2012 09:24:40, 142336 bytes
             Driver: C:\Windows\system32\igfxtray.exe, 8.15.0010.2656 (English), 2/17/2012 10:37:02, 170264 bytes
             Driver: C:\Windows\system32\hkcmd.exe, 8.15.0010.2656 (English), 2/17/2012 10:37:02, 398616 bytes
             Driver: C:\Windows\system32\igfxress.dll, 8.15.0010.2656 (English), 2/17/2012 09:24:40, 9007616 bytes
             Driver: C:\Windows\system32\igfxpers.exe, 8.15.0010.2656 (English), 2/17/2012 10:37:02, 440600 bytes
             Driver: C:\Windows\system32\igfxTMM.dll, 8.15.0010.2656 (English), 2/17/2012 09:25:50, 410624 bytes
             Driver: C:\Windows\system32\gfxSrvc.dll, 8.15.0010.2656 (English), 2/17/2012 09:25:10, 172032 bytes
             Driver: C:\Windows\system32\GfxUI.exe, 8.15.0010.2656 (English), 2/17/2012 10:37:02, 5886232 bytes
             Driver: C:\Windows\system32\GfxUI.exe.config, 2/17/2012 09:22:08, 264 bytes
             Driver: C:\Windows\system32\IGFXDEVLib.dll, 1.00.0000.0000 (Invariant Language), 2/17/2012 09:25:10, 9216 bytes
             Driver: C:\Windows\system32\igfxext.exe, 8.15.0010.2656 (English), 2/17/2012 10:37:02, 250136 bytes
             Driver: C:\Windows\system32\igfxexps.dll, 8.15.0010.2656 (English), 2/17/2012 09:25:46, 28672 bytes
             Driver: C:\Windows\SysWow64\igfxexps32.dll, 8.15.0010.2656 (English), 2/17/2012 09:23:48, 25088 bytes
             Driver: C:\Windows\system32\igfxrara.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:14, 435712 bytes
             Driver: C:\Windows\system32\igfxrchs.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:16, 428544 bytes
             Driver: C:\Windows\system32\igfxrcht.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:16, 429056 bytes
             Driver: C:\Windows\system32\igfxrdan.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:16, 437248 bytes
             Driver: C:\Windows\system32\igfxrdeu.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:16, 438784 bytes
             Driver: C:\Windows\system32\igfxrenu.lrc, 8.15.0010.2656 (English), 2/17/2012 09:24:42, 286208 bytes
             Driver: C:\Windows\system32\igfxresn.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:20, 439808 bytes
             Driver: C:\Windows\system32\igfxrfin.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:16, 438272 bytes
             Driver: C:\Windows\system32\igfxrfra.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:16, 439808 bytes
             Driver: C:\Windows\system32\igfxrheb.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:18, 435712 bytes
             Driver: C:\Windows\system32\igfxrhrv.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:22, 438784 bytes
             Driver: C:\Windows\system32\igfxrita.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:18, 438784 bytes
             Driver: C:\Windows\system32\igfxrjpn.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:18, 432128 bytes
             Driver: C:\Windows\system32\igfxrkor.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:18, 430592 bytes
             Driver: C:\Windows\system32\igfxrnld.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:16, 438784 bytes
             Driver: C:\Windows\system32\igfxrnor.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:18, 437760 bytes
             Driver: C:\Windows\system32\igfxrplk.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:18, 438784 bytes
             Driver: C:\Windows\system32\igfxrptb.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:20, 437760 bytes
             Driver: C:\Windows\system32\igfxrptg.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:20, 438784 bytes
             Driver: C:\Windows\system32\igfxrrom.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:22, 439296 bytes
             Driver: C:\Windows\system32\igfxrrus.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:20, 439296 bytes
             Driver: C:\Windows\system32\igfxrsky.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:20, 438272 bytes
             Driver: C:\Windows\system32\igfxrslv.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:20, 437760 bytes
             Driver: C:\Windows\system32\igfxrsve.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:20, 437760 bytes
             Driver: C:\Windows\system32\igfxrtha.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:20, 437248 bytes
             Driver: C:\Windows\system32\igfxrcsy.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:16, 438272 bytes
             Driver: C:\Windows\system32\igfxrell.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:18, 440320 bytes
             Driver: C:\Windows\system32\igfxrhun.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:18, 438272 bytes
             Driver: C:\Windows\system32\igfxrtrk.lrc, 8.15.0010.2656 (English), 2/17/2012 09:26:20, 437760 bytes
             Driver: C:\Windows\system32\Gfxres.ar-SA.resources, 2/17/2012 09:26:22, 164334 bytes
             Driver: C:\Windows\system32\Gfxres.cs-CZ.resources, 2/17/2012 09:26:22, 140885 bytes
             Driver: C:\Windows\system32\Gfxres.da-DK.resources, 2/17/2012 09:26:24, 135868 bytes
             Driver: C:\Windows\system32\Gfxres.de-DE.resources, 2/17/2012 09:26:24, 145579 bytes
             Driver: C:\Windows\system32\Gfxres.el-GR.resources, 2/17/2012 09:26:24, 207830 bytes
             Driver: C:\Windows\system32\Gfxres.es-ES.resources, 2/17/2012 09:26:24, 145687 bytes
             Driver: C:\Windows\system32\Gfxres.en-US.resources, 2/17/2012 09:26:14, 131317 bytes
             Driver: C:\Windows\system32\Gfxres.fi-FI.resources, 2/17/2012 09:26:26, 140549 bytes
             Driver: C:\Windows\system32\Gfxres.fr-FR.resources, 2/17/2012 09:26:26, 143805 bytes
             Driver: C:\Windows\system32\Gfxres.he-IL.resources, 2/17/2012 09:26:26, 157226 bytes
             Driver: C:\Windows\system32\Gfxres.hr-HR.resources, 2/17/2012 09:26:36, 139487 bytes
             Driver: C:\Windows\system32\Gfxres.hu-HU.resources, 2/17/2012 09:26:26, 142189 bytes
             Driver: C:\Windows\system32\Gfxres.it-IT.resources, 2/17/2012 09:26:28, 148033 bytes
             Driver: C:\Windows\system32\Gfxres.ja-JP.resources, 2/17/2012 09:26:28, 161613 bytes
             Driver: C:\Windows\system32\Gfxres.ko-KR.resources, 2/17/2012 09:26:28, 146675 bytes
             Driver: C:\Windows\system32\Gfxres.nb-NO.resources, 2/17/2012 09:26:28, 136369 bytes
             Driver: C:\Windows\system32\Gfxres.nl-NL.resources, 2/17/2012 09:26:30, 142335 bytes
             Driver: C:\Windows\system32\Gfxres.pl-PL.resources, 2/17/2012 09:26:30, 140923 bytes
             Driver: C:\Windows\system32\Gfxres.pt-BR.resources, 2/17/2012 09:26:30, 142664 bytes
             Driver: C:\Windows\system32\Gfxres.pt-PT.resources, 2/17/2012 09:26:30, 141644 bytes
             Driver: C:\Windows\system32\Gfxres.ro-RO.resources, 2/17/2012 09:26:36, 144338 bytes
             Driver: C:\Windows\system32\Gfxres.ru-RU.resources, 2/17/2012 09:26:32, 191775 bytes
             Driver: C:\Windows\system32\Gfxres.sk-SK.resources, 2/17/2012 09:26:32, 140122 bytes
             Driver: C:\Windows\system32\Gfxres.sl-SI.resources, 2/17/2012 09:26:32, 136451 bytes
             Driver: C:\Windows\system32\Gfxres.sv-SE.resources, 2/17/2012 09:26:34, 141435 bytes
             Driver: C:\Windows\system32\Gfxres.th-TH.resources, 2/17/2012 09:26:34, 221099 bytes
             Driver: C:\Windows\system32\Gfxres.tr-TR.resources, 2/17/2012 09:26:34, 143155 bytes
             Driver: C:\Windows\system32\Gfxres.zh-CN.resources, 2/17/2012 09:26:34, 123467 bytes
             Driver: C:\Windows\system32\Gfxres.zh-TW.resources, 2/17/2012 09:26:36, 124962 bytes
             Driver: C:\Windows\system32\ig4icd64.dll, 2/17/2012 09:40:00, 18124800 bytes
             Driver: C:\Windows\SysWow64\ig4icd32.dll, 2/17/2012 09:29:28, 13209600 bytes
             Driver: C:\Windows\system32\igfxCoIn_v2656.dll, 1.02.0030.0000 (English), 2/17/2012 10:35:32, 90112 bytes
          DirectShow Filters
          DirectShow Filters:
          WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
          WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
          WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
          MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
          Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
          WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
          WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
          Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
          Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
          DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
          Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
          WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
          Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
          AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
          VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
          SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
          Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
          AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
          StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
          Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
          MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
          CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
          MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
          SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
          VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
          MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
          Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
          SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
          Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
          Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
          MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
          PlayReady DMO Wrapper,0x00600002,1,1,PRDMOW~1.DLL,1.03.2297.0000
          DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
          Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
          MS PR Source Filter,0x00200000,0,2,PRSource.dll,1.03.2297.0000
          Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
          ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
          Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
          MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
          Line 21 Decoder,0x00600000,1,1,,
          Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
          Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
          VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
          WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
          VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
          File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
          iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
          iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
          VDP Renderer,0x00200000,1,0,vdpsnka.dll,1.00.0000.0049
          DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17713
          Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
          Overlay Mixer2,0x00200000,1,1,,
          RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
          Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
          WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
          MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
          DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
          SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
          Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
          MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
          Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
          StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
          Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
          Overlay Mixer,0x00200000,0,0,,
          AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
          NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
          AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
          Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
          MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
          Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
          File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
          Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
          StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
          AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
          Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
          File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
          File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
          Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
          AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
          AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
          SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
          Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
          Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
          BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
          MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
          WDM Streaming Tee/Splitter Devices:
          Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
          Video Compressors:
          WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
          WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
          MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
          DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
          MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
          Audio Compressors:
          WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
          WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
          IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
          Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
          GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
          CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
          CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
          MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
          Audio Capture Sources:
          Microphone (Realtek High Defini,0x00200000,0,0,qcap.dll,6.06.7601.17514
          PBDA CP Filters:
          PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
          PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
          PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
          Midi Renderers:
          Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
          Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
          WDM Streaming Capture Devices:
          ,0x00000000,0,0,,
          Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
          ,0x00000000,0,0,,
          Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
          USB2.0 UVC 1.3M Webcam,0x00200000,1,2,ksproxy.ax,6.01.7601.17514
          WDM Streaming Rendering Devices:
          Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
          Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
          BDA Network Providers:
          Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
          Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
          Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
          Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
          Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
          Video Capture Sources:
          VDP Source,0x00200000,0,1,vdpsrca.dll,1.00.0000.0049
          Multi-Instance Capable VBI Codecs:
          BDA Transport Information Renderers:
          BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
          MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
          BDA CP/CA Filters:
          Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
          Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
          PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
          XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
          WDM Streaming Communication Transforms:
          Audio Renderers:
          Speakers (Realtek High Definiti,0x00200000,1,0,quartz.dll,6.06.7601.17713
          Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
          Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
          DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
          DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
          Realtek Digital Output (Realtek,0x00200000,1,0,quartz.dll,6.06.7601.17713
          EVR Power Information
          Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
            Quality Flags: 2576
              Enabled:
              Force throttling
              Allow half deinterlace
              Allow scaling
              Decode Power Usage: 100
            Balanced Flags: 1424
              Enabled:
              Force throttling
              Allow batching
              Force half deinterlace
              Force scaling
              Decode Power Usage: 50
            PowerFlags: 1424
              Enabled:
              Force throttling
              Allow batching
              Force scaling
              Decode Power Usage: 0
          • 2. Re: Video investigation with Flash Player 11.2.202.228
            dacct Level 1
            1. Firefox exhibit green bands; IE stops working
            2. disbabling HW Acceleration fixes the issue OR forcing Firefox and IE to use the Integrated Graphics
            3. http://vimeo.com/37254322
            4. see bellow
            note: driver update directly from NVIDIA is not an option at the moment since I run high-end 3D applications requiring computer manufaturer qualified drivers.
            System Information
            Time of this report: 4/9/2012, 15:53:46
                   Machine name: DF-M4600
               Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.111118-2330)
            System Manufacturer: Dell Inc.
                   System Model: Precision M4600
                           BIOS: Default System BIOS
                      Processor: Intel(R) Core(TM) i7-2760QM CPU @ 2.40GHz (8 CPUs), ~2.4GHz
                         Memory: 8192MB RAM
            Available OS Memory: 8072MB RAM
                      Page File: 3065MB used, 13078MB available
               User DPI Setting: 96 DPI (100 percent)
                 DxDiag Version: 6.01.7601.17514 32bit Unicode
            DxDiag Notes
            Display Devices
                      Card name: Intel(R) HD Graphics Family
                       DAC type: Internal
                     Device Key: Enum\PCI\VEN_8086&DEV_0126&SUBSYS_04A31028&REV_09
                     Monitor Id: SEC5448
                    Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumdx32,igd10umd32,igd10umd32
            Driver File Version: 8.15.0010.2418 (English)
                 Driver Version: 8.15.10.2418
                    DDI Version: 10.1
               Driver Date/Size: 6/11/2011 03:16:04, 8292352 bytes
                    WHQL Logo'd: Yes
                WHQL Date Stamp:
              Device Identifier: {D7B78E66-4266-11CF-EA7A-A924A9C2C535}
                      Vendor ID: 0x8086
                      Device ID: 0x0126
                      SubSys ID: 0x04A31028
                    Revision ID: 0x0009
            Driver Strong Name: oem48.inf:Intel.Mfg.NTamd64.6.1:iSNBM0:8.15.10.2418:pci\ven_8086&dev_0126&subsys_04a31028
                 Rank Of Driver: 00E60001
                        DXVA-HD: Supported
                     D3D Status: Enabled
                     AGP Status: Enabled
            Sound Devices
                        Description: Speakers / Headphones (IDT High Definition Audio CODEC)
                        Hardware ID: HDAUDIO\FUNC_01&VEN_111D&DEV_76E7&SUBSYS_102804A3&REV_1001
                    Manufacturer ID: 1
                         Product ID: 100
                               Type: WDM
                        Driver Name: stwrt64.sys
                     Driver Version: 6.10.6320.0000 (English)
                        WHQL Logo'd: Yes
                      Date and Size: 1/7/2011 11:32:52, 520192 bytes
                        Other Files:
                    Driver Provider: IDT
                          Cap Flags: 0xF1F
                          HW Memory: 0
                        Description: Communications Headphones (IDT High Definition Audio CODEC)
                    Manufacturer ID: 1
                         Product ID: 100
                               Type: WDM
                        WHQL Logo'd: Yes
                        Other Files:
                          Cap Flags: 0xF1F
                          HW Memory: 0
                        Description: Microphone Array (IDT High Definition Audio CODEC)
              Default Voice Capture: No
                          Cap Flags: 0x1
                        Description: Dock Mic (IDT High Definition Audio CODEC)
              Default Sound Capture: No
                          Cap Flags: 0x1
                        Description: Rec. Playback (IDT High Definition Audio CODEC)
                          Cap Flags: 0x1
                        Description: Microphone / Line In (IDT High Definition Audio CODEC)
                          Cap Flags: 0x1
            DirectInput Devices
                  Device Name: Mouse
                     Attached: 1
                Controller ID: n/a
                    FF Driver: n/a
                     Attached: 1
                Controller ID: n/a
                    FF Driver: n/a
                  Device Name: USB Receiver
                     Attached: 1
                Controller ID: 0x0
            Vendor/Product ID: 0x046D, 0xC52B
                    FF Driver: n/a
                     Attached: 1
                Controller ID: 0x0
                    FF Driver: n/a
                     Attached: 1
                Controller ID: 0x0
                    FF Driver: n/a
                  Device Name: Cordless Receiver
                     Attached: 1
                Controller ID: 0x0
                    FF Driver: n/a
                     Attached: 1
                Controller ID: 0x0
                    FF Driver: n/a
            USB Devices
            + USB Root Hub
            | Vendor/Product ID: 0x8086, 0x1C2D
            | Service: usbhub
            +-+ Generic USB Hub
            | | Service: usbhub
            Gameport Devices
            PS/2 Devices
            | Service: i8042prt
            + HID Keyboard Device
            | Matching Device ID: hid_device_system_keyboard
            | Service: kbdhid
            | Service: TermDD
            + Dell Touchpad
            | Matching Device ID: acpi\dll04a3
            | Upper Filters: ApfiltrService
            | Service: i8042prt
            + HID-compliant mouse
            | Matching Device ID: hid_device_system_mouse
            | Service: mouhid
            + Logitech HID-compliant Unifying mouse
            | Matching Device ID: hid\vid_046d&class_0004
            | Upper Filters: LMouFilt
            | Lower Filters: LHidFilt
            | Service: mouhid
            | Service: TermDD
                  Drive: C:
            Free Space: 18.7 GB
            Total Space: 351.7 GB
            File System: NTFS
                  Model: ST9750420AS
                  Drive: D:
            Free Space: 1.9 GB
            File System: NTFS
                  Model: ST9750420AS
                  Drive: E:
                  Model: HL-DT-ST DVD+-RW GS30N
                 Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), , 0 bytes
            System Devices
            Device ID: PCI\VEN_8086&DEV_1C26&SUBSYS_04A31028&REV_04\3&11583659&0&E8
               Driver: n/a
                 Name: Intel(R) 82579LM Gigabit Network Connection
            Device ID: PCI\VEN_8086&DEV_1502&SUBSYS_04A31028&REV_04\3&11583659&0&C8
               Driver: n/a
            Device ID: PCI\VEN_8086&DEV_1C22&SUBSYS_04A31028&REV_04\3&11583659&0&FB
               Driver: n/a
                 Name: Intel(R) HD Graphics Family
            Device ID: PCI\VEN_8086&DEV_0126&SUBSYS_04A31028&REV_09\3&11583659&0&10
               Driver: n/a
            Device ID: PCI\VEN_1033&DEV_0194&SUBSYS_04A31028&REV_04\4&869802D&0&00E3
               Driver: n/a
            Device ID: PCI\VEN_8086&DEV_1C20&SUBSYS_04A31028&REV_04\3&11583659&0&D8
               Driver: n/a
            Device ID: PCI\VEN_8086&DEV_0104&SUBSYS_04A31028&REV_09\3&11583659&0&00
               Driver: n/a
                 Name: Intel(R) Centrino(R) Ultimate-N 6300 AGN
            Device ID: PCI\VEN_8086&DEV_422B&SUBSYS_11218086&REV_35\4&366A6158&0&00E1
               Driver: n/a
                 Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 8 - 1C1E
            Device ID: PCI\VEN_8086&DEV_1C1E&SUBSYS_04A31028&REV_B4\3&11583659&0&E7
               Driver: n/a
            Device ID: PCI\VEN_8086&DEV_0101&SUBSYS_04A31028&REV_09\3&11583659&0&08
               Driver: n/a
                 Name: Intel(R) Mobile Express Chipset SATA RAID Controller
            Device ID: PCI\VEN_8086&DEV_282A&SUBSYS_04A31028&REV_04\3&11583659&0&FA
               Driver: n/a
            Device ID: PCI\VEN_8086&DEV_1C16&SUBSYS_04A31028&REV_B4\3&11583659&0&E3
               Driver: n/a
                 Name: O2Micro Integrated MS/MSPRO/xD Controller
            Device ID: PCI\VEN_1217&DEV_8330&SUBSYS_04A31028&REV_05\4&3A23FE2&0&02E7
               Driver: n/a
                 Name: Intel(R) QM67 Express Chipset Family LPC Interface Controller - 1C4F
            Device ID: PCI\VEN_8086&DEV_1C4F&SUBSYS_04A31028&REV_04\3&11583659&0&F8
               Driver: n/a
                 Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 3 - 1C14
            Device ID: PCI\VEN_8086&DEV_1C14&SUBSYS_04A31028&REV_B4\3&11583659&0&E2
               Driver: n/a
                 Name: O2Micro Integrated MMC/SD controller
            Device ID: PCI\VEN_1217&DEV_8320&SUBSYS_04A31028&REV_05\4&3A23FE2&0&01E7
               Driver: n/a
                 Name: Intel(R) Management Engine Interface
            Device ID: PCI\VEN_8086&DEV_1C3A&SUBSYS_04A31028&REV_04\3&11583659&0&B0
               Driver: n/a
            Device ID: PCI\VEN_8086&DEV_1C12&SUBSYS_04A31028&REV_B4\3&11583659&0&E1
               Driver: n/a
                 Name: 1394 OHCI Compliant Host Controller
            Device ID: PCI\VEN_1217&DEV_11F7&SUBSYS_04A31028&REV_05\4&3A23FE2&0&00E7
               Driver: n/a
            Device ID: PCI\VEN_8086&DEV_1C2D&SUBSYS_04A31028&REV_04\3&11583659&0&D0
               Driver: n/a
            Device ID: PCI\VEN_8086&DEV_1C10&SUBSYS_04A31028&REV_B4\3&11583659&0&E0
               Driver: n/a
                 Name: NVIDIA Quadro 2000M
            Device ID: PCI\VEN_10DE&DEV_0DDA&SUBSYS_14A31028&REV_A1\4&2BFF4559&0&0008
               Driver: n/a
            DirectShow Filters
            DirectShow Filters:
            Blackmagic Design Decoder (DMO),0x00200000,1,1,dmobmd.dll,9.01.0000.0000
            Annodex Mux Filter,0x00200000,1,0,dsfAnxMux.dll,0.80.15035.0000
            CMML Decode Filter,0x00800002,1,1,dsfCMMLDecoder.dll,0.80.15035.0000
            CMML Raw Source Filter,0x00600000,0,0,dsfCMMLRawSource.dll,0.80.15035.0000
            FLAC Decode Filter,0x00600000,1,1,dsfFLACDecoder.dll,0.80.15035.0000
            FLAC Encode Filter,0x00200000,1,1,dsfFLACEncoder.dll,0.80.15035.0000
            Native FLAC Source Filter,0x00600000,0,0,dsfNativeFLACSource.dll,0.80.15035.0000
            Ogg Demux Packet Source Filter,0x00600000,0,0,dsfOggDemux2.dll,0.80.15035.0000
            Ogg Mux Filter,0x00200000,1,0,dsfOggMux.dll,0.80.15035.0000
            OGM Decode Filter,0x00600000,1,1,dsfOGMDecoder.dll,0.80.15035.0000
            Speex Decode Filter,0x00600000,1,1,dsfSpeexDecoder.dll,0.80.15035.0000
            Speex Encode Filter,0x00200000,1,1,dsfSpeexEncoder.dll,0.80.15035.0000
            Subtitle VMR9 Filter,0x00800002,1,1,dsfSubtitleVMR9.dll,0.80.15035.0000
            Theora Decode Filter,0x00600000,1,1,dsfTheoraDecoder.dll,0.80.15035.0000
            Theora Encode Filter,0x00200000,1,1,dsfTheoraEncoder.dll,0.80.15035.0000
            Vorbis Encode Filter,0x00200000,1,1,dsfVorbisEncoder.dll,0.80.15035.0000
            CyberLink Audio Effect (PDVD9),0x00200000,1,1,ClAudFx.ax,6.00.0000.8417
            Vorbis Decode Filter,0x00600000,1,1,dsfVorbisDecoder.dll,0.80.15035.0000
            ROXIO VCFDvrSupport 3.0,0x00200000,1,1,DvrSupportFilt.ax,12.02.0001.0071
            ROXIO Image/Colour Source 3.0,0x00200000,0,1,RoxVideo.ax,12.02.0001.0071
            WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
            Record Queue,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
            WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
            WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,15.04.3538.0513
            WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
            WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,15.04.3538.0513
            WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
            Roxio MPEG2 Encoder,0x00000000,0,0,,
            VCG Null Renderer 3.0,0x00200000,1,0,VideoCompositing.ax,12.02.0001.0071
            ROXIO WAV Dest 3.0,0x00200000,0,0,,
            ROXIO MPEG Writer,0x00000000,0,0,,
            ROXIO Scene Detector 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            Roxio Plasma CrossGraph Renderer,0x00200000,1,0,PlasmaCGFilter.ax,12.02.0001.0071
            ROXIO Video Resampler 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            CyberLink Digest Filter (PDVD9),0x00200000,2,2,DigestFilter.dll,1.00.0000.3314
            CyberLink TimeStretch Filter (PDVD9),0x00200000,1,1,clauts.ax,2.00.0000.3404
            ROXIO Audio Source 3.0,0x00200000,0,1,roxaudio.ax,10.00.0000.0000
            roxio DCFilters Subpicture Mixer,0x00000000,0,0,,
            VCGImageSource,0x00200000,0,1,VideoCompositing.ax,12.02.0001.0071
            Roxio MPEG1 Audio Encoder,0x00000000,0,0,,
            CyberLink Tzan Filter (PDVD9),0x00200000,1,1,CLTzan.ax,3.05.0000.3606
            Creative Video Processing Filter,0x00200000,1,1,VidProcU.ax,1.00.0009.0000
            ROXIO VideoCombine 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            Roxio Smart AVC Video Decode,0x00800000,1,2,,
            ROXIO DVDCrossGraphEx Source 3.0,0x00200000,0,1,RoxVideo.ax,12.02.0001.0071
            Roxio RealD to Stereo,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            ROXIO VideoTransition 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            CyberLink HD/BD Mixer (PDVD9),0x00200000,1,2,CLHBMixer.ax,2.00.0000.2422
            roxio DCFilters Audio Sync Filter 2,0x00000000,0,0,,
            CyberLink Video/SP Decoder (PDVD9),0x00602000,2,3,CLVsd.ax,8.04.0000.2308
            ROXIO CPU Regulator,0x00200000,1,1,CPURegulator.ax,10.00.0000.0000
            CyberLink AudioCD Filter (PDVD9),0x00200000,0,1,CLAudioCD.ax,5.00.0000.7823
            Roxio Vob Loader,0x00200000,0,1,VOBLoader.ax,12.02.0001.0071
            ROXIO LPCMSyncFilter,0x00000000,0,0,,
            ROXIO VCFStationLogo 1.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            ROXIO VideoInfo Transcoder 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            Cyberlink Demuxer 2.0,0x00200000,1,1,CLDemuxer2.ax,2.00.0006.2317
            roxio DCFilters MPEG Transcoder,0x00000000,0,0,,
            ROXIO DV Scene Detector Tee 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            CyberLink Audio Decoder (PDVD9),0x00201000,1,1,Claud.ax,8.04.0000.3630
            Cyberlink SubTitle Importor (PDVD9),0x00200000,2,1,CLSubTitle.ax,2.00.0000.0416
            ROXIO Field Splitter 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            ROXIO ThumbnailGrabber 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            roxio DCFilters DVD Reader,0x00000000,0,0,,
            Roxio Audio Stream Writer Filter,0x00000000,0,0,,
            CyberLink Line21 Decoder (PDVD9),0x00200000,0,2,CLLine21.ax,4.00.0000.10324
            Roxio Repacketizer Filter,0x00000000,0,0,,
            PSI Parser,0x00200000,0,0,RoxVideo.ax,12.02.0001.0071
            Roxio Audio Stream Reader Filter,0x00000000,0,0,,
            ROXIO Field Combiner 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            ROXIO QuickGrabber 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            ROXIO Video Effect 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            Roxio Anaglyph to Stereo,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            ROXIO VCFLatency 3.0,0x00200000,1,1,roxaudio.ax,10.00.0000.0000
            Roxio Video Rotater,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            CyberLink MPEG Splitter,0x00200000,1,2,CLSplter.ax,3.04.0000.4013
            roxio DCFilters Mpeg I/II Decoder,0x00000000,0,0,,
            Roxio Mp3 Encoder (SC),0x00000000,0,0,,
            Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17713
            ROXIO CrossGraphEx Renderer 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            VCG Video Mixer 3.0,0x00200000,0,1,VideoCompositing.ax,12.02.0001.0071
            Creative MJPEG Decoder 2,0x00200000,1,1,CtMJPGDec2.ax,1.00.0008.0000
            Cyberlink SubTitle Importor 2.0 (PDVD9),0x00200000,1,0,CLSubTitle.ax,2.00.0000.0416
            CyberLink FLV Splitter (PDVD9),0x00800001,1,1,CLFLVSplitter.ax,1.00.0000.1030
            ROXIO AudioConvert 3.0,0x00200000,1,1,roxaudio.ax,10.00.0000.0000
            Roxio Plasma CrossGraph Source,0x00200000,0,1,PlasmaCGFilter.ax,12.02.0001.0071
            ROXIO InputSelector 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            ROXIO LVM File Source (Async.),0x00200000,0,1,LVMAsync.ax,12.02.0001.0071
            Roxio Smart AVC Encode,0x00200000,2,1,,
            File Writer,0x00200000,1,0,WLXVAFilt.dll,15.04.3538.0513
            ROXIO Audio VCFLooper 3.0,0x00200000,1,1,roxaudio.ax,10.00.0000.0000
            CyberLink Audio Wizard,0x00201010,1,1,CLAudWizard.ax,1.00.0000.4414
            CyberLink Audio Spectrum Analyzer (PDVD9),0x00200000,1,1,CLAudSpa.ax,1.00.0000.7113
            Roxio Audio Source Filter,0x00000000,0,0,,
            Sonic MPEG-2 Video Decoder,0x00200000,2,2,c12oem_dec_mp2v_ds.ax,8.05.0000.19970
            Roxio MPEG1 Encoder,0x00000000,0,0,,
            ROXIO Pan Zoom 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            ROXIO Pin Tee,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            ROXIO Audio VCFChunker 3.0,0x00200000,1,1,roxaudio.ax,10.00.0000.0000
            Roxio MPEG2 Video Decoder,0x00000000,0,0,,
            CyberLink DVD Navigator (PDVD9),0x00200000,0,3,CLNavX.ax,8.01.0000.2931
            ROXIO Video VCFLooper 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            Decklink MJPEG Decompressor,0x00800000,1,1,DeckLink.dll,9.01.0000.0000
            CyberLink MPEG-4 Splitter (PDVD9),0x00200000,1,2,clm4splt.ax,1.01.0000.2906
            CyberLink RealMedia Splitter (PDVD9),0x00600000,1,1,CLRMSplitter.ax,1.00.0000.1103
            ROXIO InputSelectorNew 3.0,0x00200000,1,0,,
            ROXIO Sewer 3.0,0x00200000,1,0,MVWcDSutil.dll,12.02.0001.0071
            Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17713
            ROXIO Video Integrate,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            Roxio Smart Decoder,0x00000000,0,0,,
            Media Analyser,0x00200000,1,2,mediaanalyser.ax,12.02.0001.0071
            ROXIO VCFAudioMixer 3.0,0x00200000,1,1,roxaudio.ax,10.00.0000.0000
            Roxio Smart Encoder,0x00000000,0,0,,
            Sonic Cinemaster® Audio Decoder 4.3 (No Dolby),0x005ffffe,1,1,CinemasterAudioND.DLL,4.03.0000.0240
            AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713
            CyberLink HAM Decoder,0x00600000,0,1,CLCvd.ax,1.00.7190.3125
            ROXIO CrossGraphEx Source 3.0,0x00200000,0,1,RoxVideo.ax,12.02.0001.0071
            ROXIO ListImage Source 3.0,0x00200000,0,1,RoxVideo.ax,12.02.0001.0071
            ROXIO SceneRecorder 1.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            ROXIO VCFWaveform 1.0,0x00200000,1,0,roxaudio.ax,10.00.0000.0000
            LVMWriter,0x00200000,1,0,LVMWriter.ax,12.02.0001.0071
            Roxio MPEG Analyzer,0x00000000,0,0,,
            CyberLink RealAudio Decoder (PDVD9),0x00600000,1,1,CLRMAud.ax,1.00.0000.1225
            ROXIO ColorSpace Converter 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            Roxio File Writer Wrapper,0x00200000,1,0,RoxFileWriterWrapper.ax,1.00.0000.0001
            ROXIO VCFAlphaSplitter 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            roxio DCFilters Smart Resizer,0x00000000,0,0,,
            ROXIO AudioGrabber 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            CyberLink Video Decoder (PDVD9),0x00200000,1,2,CLCvd.ax,1.00.7190.3125
            VMR9 Wrapper 3.0,0x00200000,1,0,VideoCompositing.ax,12.02.0001.0071
            Sonic Audio Resampler,0x00200000,1,1,c12oem_trans_audio_samplerate_ds.ax,8.05.0000.19970
            ROXIO BDAV Smart Render 1.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            Roxio StereoSource Cropper,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            Decklink Still Sequence Source,0x00200000,0,1,DeckLink.dll,9.01.0000.0000
            Half Size to Stereo,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            roxio DCFilters DVD Splitter,0x00000000,0,0,,
            ROXIO DVDCrossGraphEx Renderer 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            Sonic Cinemaster® VideoDecoder 4.3 (EMC12),0x005ffffe,2,2,CinemasterVideo.DLL,4.03.0001.0279
            roxio DCFilters DVD Muxer,0x00000000,0,0,,
            CyberLink RealVideo Decoder (PDVD9),0x00600000,1,1,CLRMVD.ax,1.00.0000.1225
            Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17713
            Sonic HD Demuxer,0x005ffffe,1,2,SonicHDDemuxer.dll,4.03.0000.0134
            ROXIO SpyPos 3.0,0x00200000,1,1,MGINullIP.ax,12.02.0001.0071
            ROXIO InputSelectorNew 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0071
            roxio DCFilters Dragon Lair,0x00000000,0,0,,
            Decklink Still Sequence Sink,0x00200000,1,0,DeckLink.dll,9.01.0000.0000
            Sonic MPEG Multiplexer,0x00200000,1,1,c12oem_mux_mp2_ds.ax,8.05.0000.19970
            ROXIO VCFVideoCutList 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            ROXIO SubPicture Encoder,0x00000000,0,0,,
            Roxio MPEG2 Muxer,0x00000000,0,0,,
            ROXIO Deinterlace 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0071
            Roxio MPEG Stream Analyzer,0x00000000,0,0,,
            Roxio Transport Stream Source,0x00000000,0,0,,
            ROXIO VCFpeakmeter 3.0,0x00200000,1,1,roxaudio.ax,10.00.0000.0000
            Roxio MPEG1 Muxer,0x00000000,0,0,,
            Roxio VOB Formatter,0x00200000,1,1,VOBFormatter.ax,12.02.0001.0071
            ROXIO VCFHDVSceneDetect 1.0,0x00200000,2,1,RoxVideo.ax,12.02.0001.0071
            Roxio MPEG2 Demuxer,0x00000000,0,0,,
            Decklink Upsample,0x00200000,1,1,DeckLink.dll,9.01.0000.0000
            ROXIO QT Source,0x00200000,0,1,RoxVideo.ax,12.02.0001.0071
            ROXIO VCFDVSceneDetect 1.0,0x00200000,1,2,RoxVideo.ax,12.02.0001.0071
            CyberLink Matroska Splitter (PDVD9),0x00200000,1,2,CLMKVSplter.ax,1.00.0000.2811
            Video Compressors:
            Decklink MJPEG Compressor,0x00200000,1,1,DeckLink.dll,9.01.0000.0000
            Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
            Blackmagic HD 8 bit 4:2:2 Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
            Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
            Blackmagic 8 bit MJPEG Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
            Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
            Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
            Blackmagic 10 bit 4:4:4 Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
            Blackmagic SD 8 bit 4:2:2 Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
            Blackmagic 10 bit 4:2:2 Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
            Audio Compressors:
            Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.06.7601.17713
            Microphone Array (IDT High Defi,0x00200000,0,0,qcap.dll,6.06.7601.17514
            Decklink Audio Capture,0x00200000,0,1,DeckLink.dll,9.01.0000.0000
            Dock Mic (IDT High Definition A,0x00200000,0,0,qcap.dll,6.06.7601.17514
            Microphone / Line In (IDT High ,0x00200000,0,0,qcap.dll,6.06.7601.17514
            Rec. Playback (IDT High Definit,0x00200000,0,0,qcap.dll,6.06.7601.17514
            PBDA CP Filters:
            Midi Renderers:
            ,0x00000000,0,0,,
            MicIn2,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
            MuxedIn,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
            ,0x00000000,0,0,,
            Integrated Webcam,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
            HpOut,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
            ,0x00000000,0,0,,
            ,0x00000000,0,0,,
            Speaker/HP,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
            Decklink Video Capture,0x00200000,0,3,DeckLink.dll,9.01.0000.0000
            BDA CP/CA Filters:
            External Renderers:
            Decklink Video Render,0x00200000,1,0,DeckLink.dll,9.01.0000.0000
            Audio Renderers:
            Speakers / Headphones (IDT High,0x00200000,1,0,quartz.dll,6.06.7601.17713
            CyberLink Audio Renderer (PDVD9),0x00200000,1,0,cladr.ax,7.00.0000.3603
            Decklink Audio Render,0x00200000,1,0,DeckLink.dll,9.01.0000.0000
            Communications Headphones (IDT ,0x00200000,1,0,quartz.dll,6.06.7601.17713
            DirectSound: Communications Headphones (IDT High Definition Audio CODEC),0x00200000,1,0,quartz.dll,6.06.7601.17713
            DirectSound: Speakers / Headphones (IDT High Definition Audio CODEC),0x00200000,1,0,quartz.dll,6.06.7601.17713
              Quality Flags: 2576
                Enabled:
                Force throttling
                Allow scaling
                Enabled:
                Force throttling
                Allow batching
                Force scaling
              PowerFlags: 1424
                Enabled:
                Force throttling
                Allow batching
                Force scaling
            • 3. Re: Video investigation with Flash Player 11.2.202.228
              Adam Skovron Level 1
              • Confirmed video drivers are the latest
              • Problem: Green bar and color out of sync as per image
              • Disabling Flash's hardware acceleration fixes the problem
              • URL to view video: http://youtu.be/wkEDOFhA7Pw  [anything that is using the video player]
              • DxDiag report as follows:
              System Information
              Time of this report: 4/12/2012, 13:51:46
                     Machine name: T420S-4170CTO
                 Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120305-1505)
              System Manufacturer: LENOVO
                     System Model: 4170CTO
                        Processor: Intel(R) Core(TM) i7-2620M CPU @ 2.70GHz (4 CPUs), ~2.7GHz
                           Memory: 8192MB RAM
              Available OS Memory: 8074MB RAM
                        Page File: 5396MB used, 10750MB available
                 User DPI Setting: Using System DPI
              System DPI Setting: 96 DPI (100 percent)
              DxDiag Notes
                    Display Tab 2: No problems found.
                      Sound Tab 3: No problems found.
                      Sound Tab 4: No problems found.
              Display Devices
                         DAC type: Internal
                       Device Key: Enum\PCI\VEN_8086&DEV_0126&SUBSYS_21D317AA&REV_09
                     Current Mode: 1600 x 900 (32 bit) (60Hz)
                     Monitor Name: ThinkPad Display 1600x900
                       Monitor Id: LEN40A1
                      Native Mode: 1600 x 900(p) (60.000Hz)
              Driver File Version: 8.15.0010.2538 (English)
                   Driver Version: 8.15.10.2538
                      DDI Version: 10.1
                 Driver Date/Size: 9/26/2011 03:44:56, 8313856 bytes
                      WHQL Logo'd: Yes
                  WHQL Date Stamp:
                Device Identifier: {D7B78E66-4266-11CF-B369-DF01B7C2C535}
                        Vendor ID: 0x8086
                        Device ID: 0x0126
                        SubSys ID: 0x21D317AA
                      Revision ID: 0x0009
              Driver Strong Name: oem97.inf:IntelGfx.NTamd64.6.0:iSNBM0:8.15.10.2538:pci\ven_8086&dev_0126&subsys_21d317aa
                          DXVA-HD: Supported
                       D3D Status: Enabled
                       AGP Status: Enabled
                        Card name: NVIDIA NVS 4200M
                     Manufacturer: NVIDIA
                        Chip type: NVS 4200M
                         DAC type: Integrated RAMDAC
                       Device Key: Enum\PCI\VEN_10DE&DEV_1056&SUBSYS_21D317AA&REV_A1
                   Display Memory: 4065 MB
                 Dedicated Memory: 993 MB
                    Shared Memory: 3071 MB
                     Current Mode: 2560 x 1440 (32 bit) (59Hz)
                     Monitor Name: Dell U2711(DP)
                    Monitor Model: DELL U2711
                       Monitor Id: DELA057
                      Native Mode: 2560 x 1440(p) (59.951Hz)
                      Output Type: Displayport External
                      Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
              Driver File Version: 8.17.0012.7593 (English)
                   Driver Version: 8.17.12.7593
                      DDI Version: 11
                 Driver Date/Size: 8/13/2011 00:18:00, 15241832 bytes
                      WHQL Logo'd: Yes
                  WHQL Date Stamp:
                Device Identifier: {D7B71E3E-5316-11CF-B369-DF011FC2C535}
                        Vendor ID: 0x10DE
                        Device ID: 0x1056
                      Revision ID: 0x00A1
              Driver Strong Name: oem33.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section097:8.17.12.7593:pci\ven_10de&dev_1056&s ubsys_21d317aa
                      Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
                 Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                          DXVA-HD: Supported
                       D3D Status: Enabled
                       AGP Status: Enabled
              Sound Devices
                          Description: Speakers (MM-1)
                          Hardware ID: USB\VID_19B5&PID_0004&REV_0111&MI_00
                      Manufacturer ID: 65535
                           Product ID: 65535
                                 Type: WDM
                          Driver Name: USBAUDIO.sys
                       Driver Version: 6.01.7601.17514 (English)
                    Driver Attributes: Final Retail
                          WHQL Logo'd: Yes
                        Date and Size: 11/20/2010 23:23:47, 109696 bytes
                          Other Files:
                      Driver Provider: Microsoft
                            Cap Flags: 0xF1F
                            HW Memory: 0
                          Description: Speakers (4- Jabra PRO 9470)
                          Hardware ID: USB\VID_0B0E&PID_1041&REV_0305&MI_00
                           Product ID: 65535
                                 Type: WDM
                          WHQL Logo'd: Yes
                          Other Files:
                            Cap Flags: 0xF1F
                            HW Memory: 0
                          Description: Speakers (Conexant 20672 SmartAudio HD)
                          Hardware ID: HDAUDIO\FUNC_01&VEN_14F1&DEV_506E&SUBSYS_17AA21D2&REV_1000
                      Manufacturer ID: 1
                           Product ID: 100
                                 Type: WDM
                          Driver Name: CHDRT64.sys
                       Driver Version: 8.32.0023.0002 (English)
                          WHQL Logo'd: n/a
                        Date and Size: 10/3/2011 19:46:40, 1577088 bytes
                          Other Files:
                      Driver Provider: Conexant
                            Cap Flags: 0xF1F
                            HW Memory: 0
                          Description: DELL U2711-2 (NVIDIA High Definition Audio)
                          Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_001C&SUBSYS_17AA21D3&REV_1001
                      Manufacturer ID: 1
                           Product ID: 100
                                 Type: WDM
                          Driver Name: nvhda64v.sys
                       Driver Version: 1.02.0023.0003 (English)
                          WHQL Logo'd: Yes
                        Date and Size: 5/10/2011 15:11:28, 174184 bytes
                          Other Files:
                      Driver Provider: NVIDIA Corporation
                            Cap Flags: 0xF1F
                            HW Memory: 0
                          Description: Microphone (4- Jabra PRO 9470)
                            Cap Flags: 0x1
                          Description: Internal Microphone (Conexant 20672 SmartAudio HD)
                            Cap Flags: 0x1
                          Description: Microphone (HD Pro Webcam C910)
                            Cap Flags: 0x1
              DirectInput Devices
                    Device Name: Mouse
                       Attached: 1
                  Controller ID: n/a
                      FF Driver: n/a
                       Attached: 1
                  Controller ID: n/a
                      FF Driver: n/a
                       Attached: 1
                  Controller ID: 0x0
                      FF Driver: n/a
                       Attached: 1
                  Controller ID: 0x0
                      FF Driver: n/a
                       Attached: 1
                  Controller ID: 0x0
                      FF Driver: n/a
                       Attached: 1
                  Controller ID: 0x0
                      FF Driver: n/a
                       Attached: 1
                  Controller ID: 0x0
                      FF Driver: n/a
                       Attached: 1
                  Controller ID: 0x0
                      FF Driver: n/a
                    Device Name: Jabra PRO 9470
                       Attached: 1
                  Controller ID: 0x0
              Vendor/Product ID: 0x0B0E, 0x1041
                      FF Driver: n/a
                       Attached: 1
                  Controller ID: 0x0
                      FF Driver: n/a
                       Attached: 1
                  Controller ID: 0x0
                      FF Driver: n/a
                    Device Name: MM-1
                       Attached: 1
                  Controller ID: 0x0
              Vendor/Product ID: 0x19B5, 0x0004
                      FF Driver: n/a
              USB Devices
              + USB Root Hub
              | Service: usbhub
              +-+ Generic USB Hub
              | | Service: usbhub
              Gameport Devices
              PS/2 Devices
              | Service: i8042prt
              | Service: kbdhid
              | Service: TermDD
              + ThinkPad UltraNav Pointing Device
              | Matching Device ID: *len0015
              | Service: i8042prt
              | Service: mouhid
              | Service: TermDD
                    Drive: C:
              Free Space: 41.3 GB
              Total Space: 269.0 GB
              File System: NTFS
                    Model: INTEL SSDSA2CW300G3
                    Drive: Q:
              Free Space: 6.5 GB
              Total Space: 16.0 GB
              File System: NTFS
                    Drive: E:
                    Model: ROXIO DVD-ROM EMULATOR SCSI CdRom Device
              System Devices
              Device ID: PCI\VEN_8086&DEV_0101&SUBSYS_21D217AA&REV_09\3&42FFD25&0&08
                 Driver: n/a
                   Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 5 - 1C18
              Device ID: PCI\VEN_8086&DEV_1C18&SUBSYS_21D217AA&REV_B4\3&42FFD25&0&E4
                 Driver: n/a
                   Name: Intel(R) Centrino(R) Advanced-N 6250 AGN
              Device ID: PCI\VEN_8086&DEV_0089&SUBSYS_13118086&REV_5E\4&104CF0A&0&00E1
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1C16&SUBSYS_21D217AA&REV_B4\3&42FFD25&0&E3
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1C4F&SUBSYS_21D217AA&REV_04\3&42FFD25&0&F8
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1C12&SUBSYS_21D217AA&REV_B4\3&42FFD25&0&E1
                 Driver: n/a
                   Name: Intel(R) Active Management Technology - SOL (COM7)
              Device ID: PCI\VEN_8086&DEV_1C3D&SUBSYS_21D217AA&REV_04\3&42FFD25&0&B3
                 Driver: n/a
                   Name: NVIDIA NVS 4200M
              Device ID: PCI\VEN_10DE&DEV_1056&SUBSYS_21D317AA&REV_A1\4&16E83063&0&0008
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1C10&SUBSYS_21D217AA&REV_B4\3&42FFD25&0&E0
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1C3A&SUBSYS_21D217AA&REV_04\3&42FFD25&0&B0
                 Driver: n/a
              Device ID: PCI\VEN_10DE&DEV_0E08&SUBSYS_21D317AA&REV_A1\4&16E83063&0&0108
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1C03&SUBSYS_21D217AA&REV_04\3&42FFD25&0&FA
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1C2D&SUBSYS_21D217AA&REV_04\3&42FFD25&0&D0
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1502&SUBSYS_21CE17AA&REV_04\3&42FFD25&0&C8
                 Driver: n/a
              Device ID: PCI\VEN_1033&DEV_0194&SUBSYS_21D217AA&REV_04\4&1540E4B9&0&00E4
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1C26&SUBSYS_21D217AA&REV_04\3&42FFD25&0&E8
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_0126&SUBSYS_21D317AA&REV_09\3&42FFD25&0&10
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1C22&SUBSYS_21D217AA&REV_04\3&42FFD25&0&FB
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_0104&SUBSYS_21D217AA&REV_09\3&42FFD25&0&00
                 Driver: n/a
              Device ID: PCI\VEN_8086&DEV_1C20&SUBSYS_21D217AA&REV_04\3&42FFD25&0&D8
                 Driver: n/a
              DirectShow Filters
              DirectShow Filters:
              G2M Session Decoder,0x00600000,1,1,G2M.dll,5.01.0000.0880
              MS ATC Screen Decoder 1,0x00600800,1,1,scdec.dll,4.00.7577.0000
              WD Secure Source Filter,0x00200000,0,1,WDSecureSourceFilter.dll,2.01.0041.0000
              Ulead DV Writer,0x00000000,0,0,,
              InterVideo Video Decoder,0x00700000,2,5,IVIVIDEO.ax,10.00.0005.0828
              Roxio Vob Loader,0x00200000,0,1,VOBLoader.ax,12.02.0001.0082
              WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
              Record Queue,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
              WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
              WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,15.04.3508.1109
              WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
              WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,15.04.3508.1109
              WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109
              Ulead Ogg Parser,0x00600000,1,1,ulOggParserFilter.ax,1.00.0000.0002
              Roxio Plasma CrossGraph Renderer,0x00200000,1,0,PlasmaCGFilter.ax,12.02.0001.0082
              MainConcept (Sonic) DV Video Decoder,0x00600000,1,1,sonicmcdsdv.ax,2.01.0000.0004
              MainConcept (Sonic) DV Video Encoder,0x00200000,1,1,sonicmcdsdv.ax,2.01.0000.0004
              ROXIO VCFVideoCutList 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              ROXIO Image/Colour Source 3.0,0x00200000,0,1,RoxVideo.ax,12.02.0001.0082
              MainConcept MPEG Demultiplexer,0x00800100,1,2,mc_demux_mp2_ds.ax,8.05.0000.14265
              Roxio Smart AVC Encode,0x00200000,2,1,RoxioSmartAVCenc.ax,7.05.0000.0000
              Sonic MPEG-4 Video Decoder,0x00200000,1,1,sonic765m4vd.ax,7.05.0000.46181
              MainConcept AMR Decoder,0x00800000,1,1,mc_dec_amr_ds.ax,8.05.0000.14265
              Ulead Push Source Filter,0x00000000,0,0,,
              Ulead Sub-Picture Push Source Filter,0x00000000,0,0,,
              Ulead DVSD Push Source Filter,0x00000000,0,0,,
              MainConcept AAC Decoder,0x00800000,1,1,mc_dec_aac_ds.ax,8.05.0000.14265
              ROXIO SpyPos 3.0,0x00200000,1,1,MGINullIP.ax,12.02.0001.0082
              ROXIO LVM File Source (Async.),0x00200000,0,1,LVMAsync.ax,12.02.0001.0082
              DV V/A Source Filter,0x00000000,0,0,,
              Sonic AMR Decoder,0x00200000,1,1,sonic765amrd.ax,7.03.0000.46181
              Sonic Cinemaster® Audio Decoder 4.3,0x005ffffe,1,1,CinemasterAudio.DLL,4.03.0000.0238
              VCG Video Mixer 3.0,0x00200000,0,1,VideoCompositing.ax,12.02.0001.0088
              DS Video Buffer Filter,0x00200000,1,1,DSBuffer_Video.ax,2.01.0041.0000
              Sonic HD Demuxer,0x005ffffe,1,2,SonicHDDemuxer.dll,5.00.0000.0134
              MainConcept Color Space Converter,0x00600000,1,1,mc_trans_video_colorspace_ds.ax,8.05.0000.14265
              MainConcept MP4 Demultiplexer,0x00800101,1,2,mc_demux_mp4_ds.ax,8.05.0000.14265
              ROXIO InputSelectorNew 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              Ulead DVD Navigator,0x00000000,0,0,UleadDVDNavigator.ax,1.00.0002.0001
              MainConcept Layer II Audio Decoder,0x00600000,1,1,mc_dec_mpa_ds.ax,8.05.0000.14265
              LVMWriter,0x00200000,1,0,LVMWriter.ax,12.02.0001.0082
              MainConcept AAC Encoder,0x00100000,1,1,mc_enc_aac_ds.ax,8.00.0000.43595
              Ulead Video Deinterlace Filter,0x00000000,0,0,,
              ROXIO QuickGrabber 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              ROXIO SceneRecorder 1.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              ROXIO Video Resampler 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              DV V/A ACM Source Filter,0x00000000,0,0,,
              Sonic AVC/H.264 Video Decoder,0x00800000,1,2,sonic765avcvd.ax,7.05.0000.46181
              ROXIO VCFHDVSceneDetect 1.0,0x00200000,2,1,RoxVideo.ax,12.02.0001.0082
              ROXIO Video VCFLooper 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              DV Video Source Filter,0x00000000,0,0,,
              AVS Video Out,0x00200000,0,1,AVSVideoOutFilter3.ax,1.00.0000.0248
              Sonic MPEG Demultiplexer,0x00200000,1,2,sonic765mpgdmx.ax,7.03.0000.46181
              ROXIO ColorSpace Converter 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              MainConcept (Consumer) AVC/H.264 Video Decoder,0x00400000,1,2,,
              VMR9 Wrapper 3.0,0x00200000,1,0,VideoCompositing.ax,12.02.0001.0088
              ROXIO DV Scene Detector Tee 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              Roxio AMR File Writer,0x00000000,0,0,,
              XviD MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,
              ROXIO AudioGrabber 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              ROXIO FLV Splitter,0x00200000,1,1,RoxFlvSplitter.ax,1.00.0000.0001
              Roxio Plasma CrossGraph Source,0x00200000,0,1,PlasmaCGFilter.ax,12.02.0001.0082
              Ulead DV Scene Detect,0x00000000,0,0,,
              ROXIO Deinterlace 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              ROXIO VCFDVSceneDetect 1.0,0x00200000,1,2,RoxVideo.ax,12.02.0001.0082
              ROXIO Pin Tee,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              ROXIO VCFDvrSupport 3.0,0x00200000,1,1,DvrSupportFilt.ax,12.02.0001.0082
              SmartSound Soundtrack,0x00400000,0,1,DirectQX.dll,3.00.0008.0000
              SmartSound SDS Reader,0x00400000,0,1,SDSReader.dll,3.00.0008.0000
              ROXIO VideoInfo Transcoder 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              ROXIO ThumbnailGrabber 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              ROXIO Sewer 3.0,0x00200000,1,0,MVWcDSutil.dll,12.02.0001.0082
              Media Analyser,0x00200000,1,2,mediaanalyser.ax,12.02.0001.0082
              File Writer,0x00200000,1,0,WLXVAFilt.dll,15.04.3508.1109
              ROXIO Field Combiner 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              Ulead DVD Video decoder 2,0x00000000,0,0,,
              MainConcept Audio Converter,0x00200000,1,1,mc_trans_audio_converter_ds.ax,8.05.0000.14265
              MainConcept Audio Resampler,0x00200000,1,1,mc_trans_audio_samplerate_ds.ax,8.05.0000.14265
              ROXIO Video Effect 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              InterVideo Audio Decoder,0x00400000,1,1,iviaudio.ax,10.00.0005.0828
              Sonic AAC Decoder,0x00200000,1,1,sonic765daac.ax,7.06.0000.46181
              Dib Output,0x00000000,0,0,,
              Dib Receive,0x00000000,0,0,,
              Sonic MP4 Demultiplexer,0x00200000,1,2,sonic765mp4demux.ax,7.07.0000.46181
              VCGImageSource,0x00200000,0,1,VideoCompositing.ax,12.02.0001.0088
              ROXIO VideoTransition 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              PSI Parser,0x00200000,0,0,RoxVideo.ax,12.02.0001.0082
              Intel® Mux Renderer,0x00200000,2,0,IntelMux.dll,2.01.0041.0000
              Menu Source Bitmap Filter,0x00200000,0,1,MenuDShowSource11.ax,12.02.0001.0099
              MainConcept AVC/H.264 Video Decoder,0x00800001,1,2,mc_dec_avc_ds.ax,8.05.0000.14265
              Ulead OggVorbis Encoder,0x00400000,1,1,ulOggVorbisEncoderFilter.ax,1.00.0000.0001
              Ulead MPEG Transcoder,0x00000000,0,0,,
              ULead Infinite Pin Tee,0x00200000,1,1,UInfTee.ax,1.00.0000.0011
              Roxio Smart AVC Video Decode,0x00800000,1,2,RoxioSmartAVCdec.ax,7.05.0000.0000
              Ulead MPEG-4 Encoder,0x00000000,0,0,,
              Ulead MPEG-4 Splitter,0x00000000,0,0,,
              Ulead MPEG-4 Audio Decoder,0x00000000,0,0,,
              Ulead MPEG-4 Video Decoder,0x00000000,0,0,,
              Ulead AMR Audio Decoder,0x00000000,0,0,,
              Ulead MPEG-4 ASP Video Decoder,0x00000000,0,0,,
              MainConcept Frame Rate Converter,0x00400000,1,1,mc_trans_video_framerate_ds.ax,8.05.0000.14265
              ROXIO BDAV Smart Render 1.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              Ulead DVD Audio decoder 2,0x00200001,1,1,ulDVDAudio.ax,2.00.0000.0057
              ROXIO ListImage Source 3.0,0x00200000,0,1,RoxVideo.ax,12.02.0001.0082
              Sonic MPEG-2 Video Decoder,0x00200000,2,2,sonic765m2vd.ax,7.05.0000.46181
              ROXIO DVDCrossGraphEx Source 3.0,0x00200000,0,1,RoxVideo.ax,12.02.0001.0082
              Ulead DVD Parser,0x00000000,0,0,,
              MainConcept MPEG-2 Video Decoder,0x00800001,2,2,mc_dec_mp2v_ds.ax,8.05.0000.14265
              Roxio AMR Splitter,0x00000000,0,0,,
              MainConcept ImageScaler,0x00400000,1,1,mc_trans_video_imagescaler_ds.ax,8.05.0000.14265
              Roxio VOB Formatter,0x00200000,1,1,VOBFormatter.ax,12.02.0001.0082
              Sonic Cinemaster® VideoDecoder 4.3 (EMC12),0x005ffffe,2,2,CinemasterVideo.DLL,4.03.0001.0274
              Sonic Stream Parser,0x00200000,1,2,sonic765mpgdmx.ax,7.03.0000.46181
              ROXIO CrossGraphEx Renderer 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              MainConcept Sink Filter,0x00200000,1,0,mc_render_fileindex_ds.ax,8.05.0000.14265
              Sonic HD Demuxer,0x005ffffe,1,2,SonicHDDemuxer.dll,4.03.0000.0131
              Ulead MPEG Splitter,0x00200002,1,2,ulspmpeg.ax,1.00.0000.0147
              Ulead MPEG Audio Decoder,0x00400000,1,1,ulDVDAudio.ax,2.00.0000.0057
              Ulead MPEG Video Decoder,0x00400000,1,1,uldsmpeg.ax,1.00.0000.0090
              Ulead MPEG Encoder,0x00000000,0,0,,
              Ulead MPEG Audio Encoder,0x00200000,1,1,uleaMPEG.ax,1.00.0000.0022
              Ulead MPEG Muxer,0x00000000,0,0,,
              ULead File Writer,0x00000000,0,0,,
              ULead File Source (Async.),0x00400000,0,1,ulasync.ax,1.00.0000.0018
              Ulead H264 Decoder,0x00000000,0,0,,
              WD Audio Filter,0x00200000,0,1,WDAudioFilter.dll,2.01.0041.0000
              ROXIO Field Splitter 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              TechSmith File Source,0x00400000,0,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith SWF Writer,0x00200000,2,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith WMFSDK Writer,0x00200000,1,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Simple PIP,0x00200000,0,0,CamtasiaFilters.dll,7.01.0001.1785
              ImageSource,0x00200000,0,0,CamtasiaFilters.dll,7.01.0001.1785
              TitleSource,0x00200000,0,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Time Adjust,0x00200000,1,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Splitter Filter,0x00200000,1,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Frame Skip Filter,0x00200000,1,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Perf Skip Filter,0x00200000,1,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith ZoomPIP Filter,0x00200000,2,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith PushVMR Source,0x00200000,0,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith PushBitmap Source,0x00200000,0,2,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith SimplePushBitmap Source,0x00200000,0,2,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Wave Dest,0x00200000,0,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Overlay,0x00200000,1,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Wave Buffer,0x00200000,1,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith ForceColor 8,0x00200000,0,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith ForceColor 555,0x00200000,0,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith ForceColor 565,0x00200000,0,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith ForceColor 24,0x00200000,0,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith ForceColor 32,0x00200000,0,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Force Color32A,0x00200000,0,0,CamtasiaFilters.dll,7.01.0001.1785
              SSFileWriter,0x00200000,1,0,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Frame Rate Tuner,0x00200000,1,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Camera Adjust,0x00200000,1,1,CamtasiaFilters.dll,7.01.0001.1785
              Techsmith Quicktime MOV Source,0x00600000,0,2,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Sound Effects Filter,0x00200000,1,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Flv Key Frame Setter,0x00200000,1,1,CamtasiaFilters.dll,7.01.0001.1785
              TechSmith Floating Point Wave Filter,0x003fffff,1,1,CamtasiaFilters.dll,7.01.0001.1785
              Roxio FLV Video Decoder,0x00800000,1,1,RoxFLVDecoder.ax,1.00.0000.0001
              ROXIO VCFStationLogo 1.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              MainConcept Stream Parser,0x00400000,1,2,mc_demux_mp2_ds.ax,8.05.0000.14265
              ROXIO Pan Zoom 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              ROXIO VCFAlphaSplitter 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              ROXIO DVDCrossGraphEx Renderer 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              Ulead DV SubTitle Filter,0x00000000,0,0,,
              WDSource Filter,0x00200000,0,1,WDSourceFilter.dll,2.01.0041.0000
              ROXIO AC3 (5.1) Encoder,0x00200000,1,1,RoxioAC3EncEMC12.dll,1.00.0001.0004
              ROXIO CrossGraphEx Source 3.0,0x00200000,0,1,RoxVideo.ax,12.02.0001.0082
              LAME Audio Encoder,0x00100000,2,1,lame_dshow.ax,1.00.0054.50801
              ROXIO Scene Detector 3.0,0x00200000,1,1,RoxVideo.ax,12.02.0001.0082
              Ulead DVB Parser,0x00000000,0,0,,
              Ulead Audio Dual Channel Filter,0x00000000,0,0,,
              ROXIO InputSelector 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              Ulead OggVorbis Decoder,0x00400000,1,1,ulOggVorbisDecoderFilter.ax,1.00.0000.0001
              ROXIO QT Source,0x00200000,0,1,RoxVideo.ax,12.02.0001.0082
              Intel®WiDi H264 encoder,0x00200000,1,1,h264_enc_filter.dll,
              MainConcept MPEG-4 Video Decoder,0x00800000,1,1,mc_dec_mp4v_ds.ax,8.05.0000.14265
              VCG Null Renderer 3.0,0x00200000,1,0,VideoCompositing.ax,12.02.0001.0088
              ROXIO VideoCombine 3.0,0x00200000,1,0,RoxVideo.ax,12.02.0001.0082
              iZotope Vocal Enhancement,0x00200000,1,1,iZotope_VocalEnhancement.dll,1.00.0000.0024
              iZotope Consumer Restoration,0x00200000,1,1,iZotope_ConsumerRestoration.dll,1.00.0000.0024
              Video Compressors:
              Ligos MPEG-2 Encoder (Intel) v1.9-MT,0x00000000,1,1,LigosDMOVid.dll,2.01.0041.0000
              Logitech Video (I420),0x00200000,1,1,qcap.dll,6.06.7601.17514
              TechSmith Screen Capture Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
              XviD MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
              Audio Compressors:
              DV Audio -- NTSC,0x00200000,1,1,quartz.dll,6.06.7601.17713
              DV Audio -- PAL,0x00200000,1,1,quartz.dll,6.06.7601.17713
              MPEG Audio Layer3,0x00200000,1,1,quartz.dll,6.06.7601.17713
              Microphone (4- Jabra PRO 9470),0x00200000,0,0,qcap.dll,6.06.7601.17514
              Internal Microphone (Conexant 2,0x00200000,0,0,qcap.dll,6.06.7601.17514
              Microphone (HD Pro Webcam C910),0x00200000,0,0,qcap.dll,6.06.7601.17514
              PBDA CP Filters:
              Midi Renderers:
              ,0x00000000,0,0,,
              Conexant HD Audio capture,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
              ,0x00000000,0,0,,
              HD Pro Webcam C910,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
              Logitech HD Pro Webcam C910,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
              Integrated Camera,0x00200000,0,1,ksproxy.ax,6.01.7601.17514
              Jabra PRO 9470,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
              ,0x00000000,0,0,,
              ,0x00000000,0,0,,
              Conexant HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
              MM-1,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
              BDA CP/CA Filters:
              Audio Renderers:
              Speakers (MM-1),0x00200000,1,0,quartz.dll,6.06.7601.17713
              DELL U2711-2 (NVIDIA High Defin,0x00200000,1,0,quartz.dll,6.06.7601.17713
              DirectSound: DELL U2711-2 (NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
              DirectSound: Speakers (4- Jabra PRO 9470),0x00200000,1,0,quartz.dll,6.06.7601.17713
              DirectSound: Speakers (Conexant 20672 SmartAudio HD),0x00200000,1,0,quartz.dll,6.06.7601.17713
              DirectSound: Speakers (MM-1),0x00200000,1,0,quartz.dll,6.06.7601.17713
              Speakers (Conexant 20672 SmartA,0x00200000,1,0,quartz.dll,6.06.7601.17713
                Quality Flags: 2576
                  Enabled:
                  Force throttling
                  Allow scaling
                  Enabled:
                  Force throttling
                  Allow batching
                  Force scaling
                PowerFlags: 1424
                  Enabled:
                  Force throttling
                  Allow batching
                  Force scaling
              • 4. Re: Video investigation with Flash Player 11.2.202.228
                KenDude Level 1
                1 - Video with horizontal green bars or no video at all with green garbage
                2 - How do I disable Flash's hardware acceleration?
                3 - This video doesn't play (wait until after the commercial that plays first) : http://www.bing.com/videos/watch/video/man-launches-lego-shuttle-into-space/1jr25i6hr?q=di scovery%20science&from=en-us_msnhp&rel=msn&cpkey=6873d267-6f7a-4e16-b89b-3aaa1b11fa25%7cdi scovery+science%7cmsn%7c%7c
                Nvidia Driver - 285.66
                4 - DXDIAG Report:
                System Information
                Time of this report: 4/13/2012, 15:15:49
                       Machine name: KENPC12
                   Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120305-1505)
                           Language: English (Regional Setting: English)
                System Manufacturer: System manufacturer
                       System Model: System Product Name
                               BIOS: BIOS Date: 02/05/10 19:13:52 Ver: 08.00.10
                          Processor: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz (4 CPUs), ~3.3GHz
                             Memory: 8192MB RAM
                Available OS Memory: 8168MB RAM
                          Page File: 2502MB used, 13830MB available
                        Windows Dir: C:\Windows
                    DirectX Version: DirectX 11
                DX Setup Parameters: Not found
                    DWM DPI Scaling: Disabled
                DxDiag Notes
                      Display Tab 1: No problems found.
                        Sound Tab 1: No problems found.
                        Sound Tab 2: No problems found.
                          Input Tab: No problems found.
                DirectX Debug Levels
                Direct3D:    0/4 (retail)
                DirectDraw:  0/4 (retail)
                DirectInput: 0/5 (retail)
                DirectMusic: 0/5 (retail)
                DirectPlay:  0/9 (retail)
                DirectSound: 0/5 (retail)
                DirectShow:  0/6 (retail)
                Display Devices
                          Card name: NVIDIA GeForce GTX 570
                          Chip type: GeForce GTX 570
                         Device Key: Enum\PCI\VEN_10DE&DEV_1086&SUBSYS_15733842&REV_A1
                     Display Memory: 4064 MB
                   Dedicated Memory: 1248 MB
                      Shared Memory: 2815 MB
                       Current Mode: 1920 x 1080 (32 bit) (60Hz)
                       Monitor Name: Generic PnP Monitor
                      Monitor Model: HP 2511
                         Monitor Id: HWP293C
                        Native Mode: 1920 x 1080(p) (60.000Hz)
                        Output Type: DVI
                Driver File Version: 8.17.0012.8566 (English)
                     Driver Version: 8.17.12.8566
                        DDI Version: 11
                       Driver Model: WDDM 1.1
                   Driver Date/Size: 10/20/2011 04:50:00, 15694144 bytes
                        WHQL Logo'd: Yes
                    WHQL Date Stamp:
                  Device Identifier: {D7B71E3E-53C6-11CF-847A-7F351FC2C535}
                          Vendor ID: 0x10DE
                          Device ID: 0x1086
                          SubSys ID: 0x15733842
                        Revision ID: 0x00A1
                Driver Strong Name: oem37.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section005:8.17.12.8566:pci\ven_10de&dev_1086
                     Rank Of Driver: 00E62001
                                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                       D3D9 Overlay: Supported
                            DXVA-HD: Supported
                       DDraw Status: Enabled
                         D3D Status: Enabled
                         AGP Status: Enabled
                Sound Devices
                            Description: Speakers (Realtek High Definition Audio)
                Default Sound Playback: Yes
                Default Voice Playback: Yes
                            Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_10438410&REV_1003
                        Manufacturer ID: 1
                             Product ID: 100
                                   Type: WDM
                            Driver Name: RTKVHD64.sys
                         Driver Version: 6.00.0001.6251 (English)
                            WHQL Logo'd: Yes
                          Date and Size: 11/23/2010 05:16:56, 2565736 bytes
                            Other Files:
                        Driver Provider: Realtek Semiconductor Corp.
                         HW Accel Level: Basic
                              Cap Flags: 0xF1F
                    Min/Max Sample Rate: 100, 200000
                Static/Strm HW Mix Bufs: 1, 0
                Static/Strm HW 3D Bufs: 0, 0
                              HW Memory: 0
                       Voice Management: No
                EAX(tm) 2.0 Listen/Src: No, No
                   I3DL2(tm) Listen/Src: No, No
                Sensaura(tm) ZoomFX(tm): No
                            Description: Realtek Digital Output(Optical) (Realtek High Definition Audio)
                Default Sound Playback: No
                Default Voice Playback: No
                        Manufacturer ID: 1
                             Product ID: 100
                                   Type: WDM
                            WHQL Logo'd: Yes
                            Other Files:
                              Cap Flags: 0xF1F
                              HW Memory: 0
                            Description: Realtek Digital Output (Realtek High Definition Audio)
                        Manufacturer ID: 1
                             Product ID: 100
                                   Type: WDM
                            WHQL Logo'd: Yes
                            Other Files:
                              Cap Flags: 0xF1F
                              HW Memory: 0
                Sound Capture Devices
                DirectInput Devices
                      Device Name: Mouse
                         Attached: 1
                    Controller ID: n/a
                Vendor/Product ID: n/a
                        FF Driver: n/a
                      Device Name: Keyboard
                         Attached: 1
                    Controller ID: n/a
                        FF Driver: n/a
                      Device Name: HID-compliant consumer control device
                         Attached: 1
                    Controller ID: 0x0
                Vendor/Product ID: 0xFEEB, 0xDEEF
                        FF Driver: n/a
                      Device Name: Mass Storage Device
                         Attached: 1
                    Controller ID: 0x0
                Vendor/Product ID: 0x058F, 0x6364
                        FF Driver: n/a
                      Device Name: EP2
                         Attached: 1
                    Controller ID: 0x0
                Vendor/Product ID: 0x05A4, 0x9760
                        FF Driver: n/a
                      Device Name: EP2
                         Attached: 1
                    Controller ID: 0x0
                        FF Driver: n/a
                Poll w/ Interrupt: No
                USB Devices
                + USB Root Hub
                | Matching Device ID: usb\root_hub20
                | Service: usbhub
                +-+ Generic USB Hub
                | | Vendor/Product ID: 0x8087, 0x0024
                | | Matching Device ID: usb\class_09
                | | Service: usbhub
                Gameport Devices
                PS/2 Devices
                | Service: kbdhid
                + Terminal Server Keyboard Driver
                | Matching Device ID: root\rdp_kbd
                | Upper Filters: kbdclass
                | Service: TermDD
                | Vendor/Product ID: 0x1BCF, 0x0002
                | Service: mouhid
                + Terminal Server Mouse Driver
                | Matching Device ID: root\rdp_mou
                | Upper Filters: mouclass
                | Service: TermDD
                Disk & DVD/CD-ROM Drives
                      Drive: C:
                Free Space: 21.3 GB
                Total Space: 57.1 GB
                File System: NTFS
                      Model: OCZ-AGILITY3 ATA Device
                      Drive: D:
                Free Space: 889.1 GB
                Total Space: 953.9 GB
                File System: NTFS
                      Model: ST1000DM003-9YN162 ATA Device
                      Drive: E:
                      Model: HL-DT-ST BD-RE  WH12LS39 ATA Device
                System Devices
                     Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
                Device ID: PCI\VEN_8086&DEV_1C2D&SUBSYS_844D1043&REV_05\3&11583659&0&D0
                   Driver: n/a
                     Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 2 - 1C12
                Device ID: PCI\VEN_8086&DEV_1C12&SUBSYS_844D1043&REV_B5\3&11583659&0&E1
                   Driver: n/a
                     Name: ASMedia XHCI Controller
                Device ID: PCI\VEN_1B21&DEV_1042&SUBSYS_84881043&REV_00\4&108ABD8A&0&00E4
                   Driver: n/a
                     Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26
                Device ID: PCI\VEN_8086&DEV_1C26&SUBSYS_844D1043&REV_05\3&11583659&0&E8
                   Driver: n/a
                     Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 1 - 1C10
                Device ID: PCI\VEN_8086&DEV_1C10&SUBSYS_844D1043&REV_B5\3&11583659&0&E0
                   Driver: n/a
                     Name: JMicron JMB36X Controller
                Device ID: PCI\VEN_197B&DEV_2362&SUBSYS_84601043&REV_10\4&20221DEA&0&00E3
                   Driver: n/a
                     Name: Intel(R) 6 Series/C200 Series Chipset Family SMBus Controller - 1C22
                Device ID: PCI\VEN_8086&DEV_1C22&SUBSYS_844D1043&REV_05\3&11583659&0&FB
                   Driver: n/a
                     Name: Intel(R) 6 Series/C200 Series Chipset Family 6 Port SATA AHCI Controller - 1C02
                Device ID: PCI\VEN_8086&DEV_1C02&SUBSYS_844D1043&REV_05\3&11583659&0&FA
                   Driver: n/a
                     Name: NVIDIA GeForce GTX 570
                Device ID: PCI\VEN_10DE&DEV_1086&SUBSYS_15733842&REV_A1\4&80E7924&0&0008
                   Driver: n/a
                     Name: High Definition Audio Controller
                Device ID: PCI\VEN_8086&DEV_1C20&SUBSYS_84361043&REV_05\3&11583659&0&D8
                   Driver: n/a
                     Name: Intel(R) 82579V Gigabit Network Connection
                Device ID: PCI\VEN_8086&DEV_1503&SUBSYS_849C1043&REV_05\3&11583659&0&C8
                   Driver: n/a
                Device ID: PCI\VEN_10DE&DEV_0E09&SUBSYS_15733842&REV_A1\4&80E7924&0&0108
                   Driver: n/a
                Device ID: PCI\VEN_8086&DEV_1C1E&SUBSYS_844D1043&REV_B5\3&11583659&0&E7
                   Driver: n/a
                     Name: 2nd generation Intel(R) Core(TM) processor family PCI Express Controller - 0101
                Device ID: PCI\VEN_8086&DEV_0101&SUBSYS_844D1043&REV_09\3&11583659&0&08
                   Driver: n/a
                     Name: Intel(R) 82801 PCI Bridge - 244E
                Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_844D1043&REV_B5\3&11583659&0&E6
                   Driver: n/a
                Device ID: PCI\VEN_8086&DEV_1C18&SUBSYS_844D1043&REV_B5\3&11583659&0&E4
                   Driver: n/a
                     Name: 2nd generation Intel(R) Core(TM) processor family DRAM Controller - 0100
                Device ID: PCI\VEN_8086&DEV_0100&SUBSYS_844D1043&REV_09\3&11583659&0&00
                   Driver: n/a
                     Name: Intel(R) Z68 Express Chipset Family LPC Interface Controller - 1C44
                Device ID: PCI\VEN_8086&DEV_1C44&SUBSYS_844D1043&REV_05\3&11583659&0&F8
                   Driver: n/a
                     Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 4 - 1C16
                Device ID: PCI\VEN_8086&DEV_1C16&SUBSYS_844D1043&REV_B5\3&11583659&0&E3
                   Driver: n/a
                     Name: PCI standard PCI-to-PCI bridge
                Device ID: PCI\VEN_1B21&DEV_1080&SUBSYS_10801B21&REV_01\4&2B6CC657&0&00E6
                   Driver: n/a
                Device ID: PCI\VEN_8086&DEV_1C3A&SUBSYS_844D1043&REV_04\3&11583659&0&B0
                   Driver: n/a
                Device ID: PCI\VEN_8086&DEV_1C14&SUBSYS_844D1043&REV_B5\3&11583659&0&E2
                   Driver: n/a
                Device ID: PCI\VEN_1B21&DEV_1042&SUBSYS_84881043&REV_00\4&DDEC341&0&00E1
                   Driver: n/a
                DirectShow Filters
                DirectShow Filters:
                WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
                WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
                WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
                MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
                Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
                WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
                WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
                Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
                Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
                PP PCM Wrapper,0x00200000,1,1,ppPCMEnc.ax,1.01.0000.0321
                CyberLink AVCHD Navigator,0x00600000,0,3,CLAVCHDNav.ax,2.00.0000.3405
                CyberLink Audio Effect (PDVD9),0x00200000,1,1,ClAudFx.ax,6.00.0000.7209
                CyberLink MPEG Video Encoder,0x00200000,1,1,P2GVidEnc.ax,6.00.0001.2226
                CyberLink Editing Service 4.5 (Source),0x00200000,0,2,CLEdtKrn.dll,4.05.0000.3103
                Cyberlink Track Filter,0x00200000,1,1,YCTrack.ax,1.01.0000.0222
                CyberLink UltraSpeed/SVRT Demultiplexer,0x00200000,1,0,SE_CLEdtDemuxer.ax,1.02.0001.7003
                CyberLink MP3/WAV Wrapper,0x00200000,1,1,P2GMP3Wrap.ax,3.07.0000.1314
                PP Video Regulator,0x00200000,1,1,ppResample.ax,2.05.0000.1818
                PP TV Audio Decoder,0x00200000,1,1,claudTV.ax,6.00.0000.4104
                DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
                PP YUY2 Deinterlace,0x00200000,1,1,ppDItlYuY2.ax,2.05.0000.2703
                CyberLink Audio Decoder(PDVD9 UPnP),0x00200000,1,1,CLAud.ax,6.01.0000.3816
                CyberLink AudioCD Filter,0x00200000,0,1,P2GAudioCD.ax,5.00.0000.1321
                Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
                CyberLink TimeStretch Filter (PDVD9),0x00200000,1,1,clauts.ax,2.00.0000.2403
                CyberLink Audio Spectrum Analyzer(PDVD9 UPnP),0x00200000,1,1,CLAudSpa.ax,1.00.0000.0924
                WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
                Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
                AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
                VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
                SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
                PP IDM,0x00200000,1,1,ppIDMF.ax,1.00.0000.5113
                CyberLink Editing Service 3.0 (Source),0x00200000,0,2,P2GEdtKrn.dll,3.00.0000.2911
                CyberLink UltraSpeed/SVRT Demultiplexer,0x00200000,1,0,CLEdtDemuxer.ax,1.02.0001.7826
                Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
                PP Video Effect,0x00200000,1,1,ppVidFx.ax,1.00.0000.4602
                Cyberlink TS Information,0x00200000,1,0,ppTSInfo.ax,1.02.0001.3026
                AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
                CyberLink Tzan Filter (PDVD9),0x00200000,1,1,CLTzan.ax,3.05.0000.3119
                PP Video Decoder,0x00200000,2,3,ppGenericVSD.ax,6.00.0000.5608
                StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
                PP Audio Resampler,0x00200000,1,1,ppAuRsmpl.ax,2.00.0000.4301
                MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
                PP Dump Dispatch Filter,0x00200000,1,0,CLDumpDispatch.ax,1.02.0001.2412
                MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
                SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                P2G Video Decoder,0x00200000,2,3,P2GVSD.ax,6.00.0000.2310
                VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
                MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
                PP File Reader (Async.),0x00200000,0,1,ppReader.ax,2.00.0000.0812
                PP Snapshot Filter,0x00200000,1,0,ppSnapshot.ax,1.00.0000.0001
                Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
                YC_EVRWindow,0x00200000,0,0,YCEvr.dll,1.00.0001.4504
                SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
                PP Dump Filter,0x00200000,1,0,CLDump.ax,3.00.0000.10814
                CyberLink Push-Mode CLStream(PDVD9),0x00200000,0,1,CLStream(PushMode).ax,1.00.0000.1627
                CyberLink MPEG-4 Splitter,0x00200000,1,2,SE_clm4splt.ax,1.00.0000.5210
                Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
                PP DV Buffer,0x00200000,2,0,ppDVBuffer.ax,2.00.0000.1610
                CyberLink DV Buffer,0x00200000,0,1,ppDVDump.ax,2.00.0001.0002
                Cyberlink Demuxer 2.0,0x00200000,1,1,CLDemuxer2.ax,2.00.0006.1731
                CyberLink Audio Decoder (PDVD9),0x00201000,1,1,Claud.ax,8.04.0000.3223
                Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
                CyberLink Video Regulator,0x00200000,1,1,P2GRGL.ax,2.00.0000.3328
                P2G Audio Decoder,0x00200000,1,1,P2GAud.ax,6.01.0000.3601
                MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
                CyberLink Mux Push Source,0x00200000,0,1,SE_CLMuxPushSrc.ax,1.00.0000.3314
                PP DDR,0x00200000,1,0,ppRender.ax,2.00.0002.0026
                CyberLink Demultiplexer(PDVD9 UPnP),0x00200000,1,0,CLDemuxer.ax,1.00.0000.4513
                CyberLink MPEG Splitter,0x00200000,1,2,CLSplter.ax,3.01.0000.3022
                DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
                Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
                CyberLink Video Effect,0x00200000,1,1,P2GVidFx.ax,1.00.0000.2030
                PP TL MPEG Splitter,0x00200000,1,2,CLTLMSplter.ax,3.03.0000.1917
                PP M2V Writer,0x00200000,1,0,PPM2VWriter.ax,1.03.0000.2523
                CyberLink Audio Commercial Cut Analyzer,0x00200000,1,1,CLAudCM.ax,1.00.0000.1725
                PP DV TCR,0x00200000,1,1,ppDVTCR.ax,2.01.0000.6525
                Cyberlink Sub-Picture Filter,0x00200000,1,1,CLSubPic.ax,3.00.0000.0728
                CyberLink Audio Noise Reduction,0x00200000,1,1,P2GAuNRWrapper.ax,2.00.0000.1017
                PP Audio Encoder,0x00200000,2,0,CLAudEnc.ax,2.01.0000.1926
                Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
                CyberLink Load Image Filter,0x00200000,0,1,CLImage.ax,3.01.0000.2928
                CyberLink MPEG-2 Splitter,0x00200000,1,2,P2Gm2spliter.ax,2.04.0000.2301
                CyberLink MPEG Splitter,0x00200000,1,2,CLSplter.ax,3.04.0000.2906
                CyberLink Audio VolumeBooster,0x00200000,1,1,P2GVB.ax,1.00.0000.1008
                PP MPEG Muxer,0x00200000,2,1,MpgMux.ax,5.02.0000.2424
                CyberLink Video/SP Decoder(PDVD9 UPnP),0x00200000,2,3,CLVSD.ax,6.01.0000.0916
                ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
                CyberLink Frame Parser,0x00200000,2,0,CLFParser.ax,1.00.0000.3702
                Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
                MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
                Cyberlink Dump Dispatch Filter,0x00200000,1,0,P2GDumpDispatch.ax,1.02.0001.2412
                Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
                Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
                CyberLink MPEGV Analyzer,0x00200000,1,1,SE_CLMPEGVAnalyzer.ax,1.00.0000.2709
                CyberLink Audio Resampler,0x00200000,1,1,P2GAuRsmpl.ax,1.00.0000.2625
                CyberLink SBE Source Filter,0x00200000,0,0,CLSBESrc.ax,1.00.0000.3628
                Cyberlink Dump Dispatch Filter,0x00200000,1,0,SE_CLDumpDispatch.ax,1.03.0000.1003
                VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
                WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
                CyberLink MPEG-1 Splitter,0x00200000,1,2,P2Gm1spliter.ax,2.04.0000.2301
                CyberLink Stamp Effect,0x00200000,1,1,ppStampEffect.ax,1.00.0000.4125
                VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
                CyberLink Demultiplexer,0x00200000,1,0,cldemuxer.ax,1.00.0000.7830
                File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
                PP YUY2 Sub-Sampling,0x00200000,1,1,ppSubYUY2.ax,2.05.0000.2628
                CyberLink Streamming Filter(PDVD9),0x00200000,0,1,CLStream.ax,1.01.0000.2902
                iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
                iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
                Cyberlink File Reader (Async.),0x00200000,0,1,P2GReader.ax,3.00.0000.3016
                CyberLink TL MPEG Splitter,0x00200000,1,2,SE_CLTLMSplter.ax,3.02.0000.4805
                CyberLink M2V Writer,0x00200000,1,0,P2GM2VWriter.ax,1.03.0000.2017
                PP Audio Effect,0x00200000,1,1,CLAudFx.ax,6.01.0000.3122
                PP WAV Dest,0x00200000,0,0,PPWavDest.ax,1.00.0000.0002
                Cyberlink Dump Filter,0x00200000,1,0,P2GDump.ax,3.00.0000.7122
                CyberLink DVD Navigator (PDVD9),0x00200000,0,3,CLNavX.ax,8.01.0000.2006
                CyberLink Video Stabilizer,0x00200000,1,1,P2GVideoStabilizer.ax,1.00.0000.1017
                CyberLink TL MPEG Splitter,0x00200000,1,2,YCTLMSplter.ax,3.02.0000.2219
                CyberLink Audio Decoder,0x00200000,1,1,SE_claud.ax,8.01.0036.4505
                CyberLink WMV/WMA Demux(PDVD9),0x00600000,1,2,CLWMFDemux.ax,1.00.0000.1302
                CyberLink MPEG-4 Splitter (PDVD9),0x00200000,1,2,clm4splt.ax,1.01.0000.2911
                PP Audio Decoder,0x00200000,1,1,CLAud.ax,8.03.0000.2417
                CyberLink PCM Wrapper,0x00200000,1,1,P2GPCMEnc.ax,1.01.0000.0321
                DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17713
                CyberLink SnapShotTIP Filter,0x00200000,1,1,CLSShot.ax,1.00.0000.4022
                PP MPEG Splitter,0x00200000,1,2,ppSplter.ax,3.03.0000.1917
                Cyberlink Scene Detect Filter,0x00200000,1,1,ppScnDt.ax,1.00.0000.0813
                PP Audio Noise Reduction (CES),0x00200000,1,1,CLAuNRWrapper.ax,2.00.0000.1805
                CyberLink Tzan Filter,0x00200000,1,1,CLTzan.ax,2.00.0000.1521
                CyberLink H.264/AVC Decoder,0x00200000,1,2,cl264dec.ax,2.01.0000.1708
                CyberLink HAM Decoder,0x00600000,0,1,CLCvd.ax,1.00.7246.2926
                PP Gate Filter,0x00200000,1,1,ppGate.ax,1.00.0000.0001
                RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
                Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
                WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
                MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
                DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
                PP DV Dump Filter,0x00200000,1,0,ppDVDump.ax,2.00.0001.0002
                CyberLink Video Decoder (PDVD9),0x00200000,1,2,CLCvd.ax,1.00.7246.2926
                SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
                Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
                CyberLink WebCamera NULL Render,0x00200000,0,0,YCWEBCAMERARENDER.ax,2.00.10175.3910
                MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
                Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
                CyberLink Video Regulator,0x00200000,1,1,YCRgl.ax,3.00.0000.1228
                CyberLink MPEGV Analyzer,0x00200000,1,1,CLMPEGVAnalyzer.ax,1.00.0000.3618
                StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
                PowerProducer Double Tee,0x00200000,1,2,ppDoubleTee.ax,1.00.0000.1224
                CyberLink TimeStretch Filter (CES),0x00200000,1,1,P2Gauts.ax,1.00.0000.2212
                Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
                CyberLink TL MPEG Splitter,0x00200000,1,2,P2GTLMSplter.ax,3.02.0000.2219
                AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
                CyberLink MPEG Muxer,0x00200000,2,1,P2GMpgMux.ax,5.01.0000.1723
                PP Video Regulator,0x00200000,1,1,CLRGL.ax,3.00.0000.1716
                PP SnapShotTIP Filter,0x00200000,1,1,ppSShot.ax,1.00.0000.2617
                AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
                Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
                CyberLink WMV Dumper,0x00200000,2,0,YCWMVDump.ax,1.00.0000.2625
                CyberLink SBE Filter,0x00200000,0,0,CLSBE.ax,1.00.0000.3628
                CyberLink MPEG Muxer,0x00200000,2,1,SE_MpgMux.ax,5.01.0000.2014
                Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
                StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
                AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
                Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
                File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
                File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
                P2G Video Regulator,0x00200000,1,1,P2GResample.ax,2.05.0000.1818
                CyberLink MPEG-4 Muxer,0x00200000,1,1,SE_clm4muxer.ax,1.00.0000.3920
                PP Byte Counter,0x00200000,1,1,ppByteCounter.ax,1.00.0000.1224
                CyberLink AVI Audio Time Regulator,0x00200000,1,1,AVI_AudTR.ax,1.00.0000.1515
                P2G Audio Encoder,0x00200000,2,0,P2GAudEnc.ax,2.00.0000.4815
                PP MPEG Video Encoder,0x00200000,1,1,CLVidEnc.ax,6.04.0001.2702
                Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
                PP TimeStretch Filter (CES),0x00200000,1,1,clauts.ax,1.00.0000.4024
                Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
                CyberLink Matroska Splitter (PDVD9),0x00200000,1,2,CLMKVSplter.ax,1.00.0000.1204
                BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
                MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
                CyberLink MPEG Decoder,0x00200000,2,3,P2GMVD.ax,5.00.0000.0929
                CyberLink MPEG-4 Splitter,0x00200000,1,2,clm4splt.ax,1.00.0000.6622
                CyberLink MPEG-4 Muxer,0x00200000,1,1,clm4muxer.ax,1.00.0000.4724
                WDM Streaming Tee/Splitter Devices:
                Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                Video Compressors:
                WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
                WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
                MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
                DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
                MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
                Intel I
